SPECIFICATION
Part No.
EMPCB.SMAFSTJ.C.HT
Product Name
SMA (F) Jack For Edge PCB Mount
Feature
SMA(F) Jack
Straight Edge Mount PCB Jack
Frequency Range: 12.4GHz
Finish: Nickel
Leg Length: 3.8mm
Total Length: 13.3mm
RoHS Compliant
SPE-12-8-132/C/WY
Page 1 of 6
1. Introduction
The EMPCB.SMAFSTJ.C.HT connector was designed to be mounted on a PCB edge. The edge
mount configuration allows the connector to be easily slotted onto a PCB board; the maximum
thickness of PCB that the connector can be used with is 0.8mm. The connector pin is directly
soldered onto pads on the PCB. The connector is a standard SMA (F) Jack. The SMA connector is
the most popular type connector for RF applications. Taoglas connectors are all RoHS compliant.
2. Specification
ELECTRICAL
Impedance
50Ω
Frequency Range
0~12.4 GHz
Working Voltage
Max. 335 Vrms
Insulation Resistance
Min. 5000M ohms
MECHANICAL
Connector Dimension
6.35 X 6.35 X13.3 mm
Max. Thickness PCB acceptable
0.8 mm
Connector Pin Diameter
0.76 mm
Connector Type
SMA (F) to PCB Edge Mounted
ENVIRONMENTAL
RoHS compliant
Operating Temperature
-40°C to +85°C
SPE-12-8-132/C/WY
Page 2 of 6
3. Connector Drawing
Name
Material
Finish
QTY
1
Body
Brass
Nickel
1
2
Pin
Brass
Gold
1
3
Insulator
Teflon
White
1
SPE-12-8-132/C/WY
Page 3 of 6
3.1 Footprint
SPE-12-8-132/C/WY
Page 4 of 6
4. Packaging (Unit: mm)
SPE-12-8-132/C/WY
Page 5 of 6
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves
the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to
third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-12-8-132/C/WY
Page 6 of 6
很抱歉,暂时无法提供与“EMPCB.SMAFSTJ.C.HT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 39+27.47975
- 121+25.42338
- 484+23.63830
- 国内价格 香港价格
- 1+23.039051+2.98072
- 100+21.31650100+2.75786
- 国内价格
- 39+23.67419
- 121+22.48927
- 484+21.48572
- 国内价格 香港价格
- 100+19.04040100+2.46339
- 500+18.12308500+2.34471
- 1000+17.245651000+2.23119
- 2500+16.176772500+2.09290
- 国内价格 香港价格
- 1+33.650761+4.35363
- 10+28.6058110+3.70093
- 25+26.8163825+3.46942
- 50+25.5337850+3.30348
- 100+24.31419100+3.14569
- 250+22.79114250+2.94865
- 500+21.70345500+2.80792
- 1000+20.668111000+2.67398
- 2500+19.375332500+2.50672
- 国内价格 香港价格
- 100+19.34735100+2.50310
- 300+18.10075300+2.34182
- 500+17.80534500+2.30360
