EMPCB.MMCXFSTJ.A.HT
EMPCB.MMCXFSTJ.A.HT
    TAOGLASLIMITED
    EMPCB.MMCXFSTJ.A.HT
EMPCB.MMCXFSTJ.A.HT 数据手册
SPECIFICATION Part No. : EMPCB.MMCXFSTJ.A.HT Product Name : MMCX (F) Jack For Edge PCB Mount Feature : MMCX(F) Jack Straight Edge Mount PCB Jack Frequency Range: DC up to 6GHz Finish: Gold Leg Length: 2.9mm Total Length: 7.4mm RoHS Compliant SPE-12-8-135/B/WY Page 1 of 3 1. Introduction The EMPCB.MMCXFSTJ.A.HT connector was designed to be mounted on a PCB edge. The edge mount configuration allows the connector to be easily slotted onto a PCB board; the maximum thickness of PCB that the connector can be used with is 0.8mm. The connector pin is directly soldered onto pads on the PCB. Taoglas connectors are all RoHS compliant. 2. Specification ELECTRICAL Impedance 50Ω Frequency Range DC~6 GHz Working Voltage Max. ≤170 Vrms Dielectric withstanding Voltage 500 Vrms Insulation Resistance ≥1000M ohms MECHANICAL Connector Dimension 7.4mm*4.5 mm Max. Thickness PCB acceptable 0.8mm Connector Pin Diameter 0.7mm Connector Type MMCX(F) to PCB Edge Mounted ENVIRONMENTAL Operating Temperature -45°C to +85°C RoHS compliant SPE-12-8-135/B/WY Page 2 of 3 3. Connector Drawing Name Material Finish QTY 1 Body Brass Gold 1 2 Insulator Teflon White 1 3 Female Contact Phosphor Bronze Gold 1 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © 2012, Taoglas Ltd. SPE-12-8-135/B/WY Page 3 of 3
EMPCB.MMCXFSTJ.A.HT 价格&库存
很抱歉,暂时无法提供与“EMPCB.MMCXFSTJ.A.HT”相匹配的价格&库存,您可以联系我们找货
EMPCB.MMCXFSTJ.A.HT
    • 1+44.79840
    • 200+17.88480
    • 500+17.28000
    • 1000+16.98840
    EMPCB.MMCXFSTJ.A.HT
    • 1+51.891061+6.74428
    • 10+44.0849910+5.72972
    • 25+41.3190325+5.37023
    • 50+39.3458550+5.11378
    • 100+37.46765100+4.86967
    • 250+35.12169250+4.56476
    • 500+33.44619500+4.34700
    • 1000+31.851091000+4.13968
    • 2500+29.859282500+3.88081
    库存:773
