131-8701-206
131-8701-206
    CINCH
    插件
    SMB
131-8701-206 数据手册
75 Ohm SMB PC Mount Straight Jack Receptacle GOLD PLATED NICKEL PLATED 131-8701-201 131-8701-206 INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST * For PC board thickness other than .062 inches, contact factory. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com Mini-75 Ohm SMB Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST ELECTRICAL RATINGS Impedence: 75 ohms Frequency Range: 0-2 GHz VSWR: f = GHz RG-179, RG-59, Belden 735A cable: Straight cabled connectors ............................ 1.25 + .04f Right angle cabled connectors ...................... 1.35 + .04f Adapters .......................................................................................... 1.20 + .04f Type N Adapters ............................................................................. 1.05 +. 01f Matching pad 50 ohm/75 ohm .......................................................... 1.05 + .1f Loads .............................................................................................. 1.05 + .01f Uncabled receptacles, opens, shorts ......................................................... N/A Working Voltage: (Vrms maximum)† Connectors for Cable Type Sea Level 70K Feet RG-179, RG-59, Belden 735A, uncabled receptacles, adapters ........................... 335 85 Open, shorts, loads, matching pad .......................... N/A N/A Dielectric Withstanding Voltage: (VRMS minimum at sea level)† Connectors for RG-179, RG-59, Belden 735A, uncabled receptacles, adapters ........................................................ 1000 Open, shorts, loads, matching pad ......................................................... N/A Corona Level: (Volts minimum at 70,000 feet)† Connectors for RG-179, RG-59, Belden 735A ....................................... 250 Uncabled receptacles, adapters, open, shorts, loads, matching pad: N/A Electrical Length: Open + 1.5o (+ 5.2o relative to short) Short + 1.5o (+ 5.2o relative to open) Adapters + 5.2o (N/A for Jack-Bulkhead Jack and N Types) Insertion Loss: (dB maximum, tested at 1.5 GHz) Straight cable connectors ............................................................... 0.30 dB Right angle cable connectors ......................................................... 0.60 dB Matching pad .......................................................................... 6 dB nominal Uncabled receptacles, adapters, opens, shorts, loads .......................... N/A Insulation Resistance: 1000 megohms minimum Contact Resistance: (milliohms maximum) After Initial Environmental Center contact (straight cabled connectors, uncabled receptacles, opens, shorts, loads) ....... 6.0 8.0 Center contact (right angle cabled connectors and adapters) .................................. 12.0 16.0 Outer contact (gold plated connectors) ................... 1.0 1.5 Outer contact (nickel plated connectors) ................ 2.5 3.5 Braid to body (gold plated connectors) ................... 1.0 N/A Braid to body (nickel plated connectors) ................. 2.5 N/A RF Leakage: (dB minimum tested at 2.5 GHz) Cable connectors .............................................................................. -55 dB Uncabled receptacles, adapters opens, shorts, loads,matching pad...N/A RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz)† Connectors for RG-179, RG-59, Belden 735A ....................................... 700 Uncabled receptacles and adapters ....................................................... 600 Opens, shorts, loads, matching pad ....................................................... N/A Power Rating: (Loads and matching pad only) 1.0 watt at +25 ° C derated linearly to .5 watt at +125° C MECHANICAL RATINGS Engagement Design: MIL-C-39012, Series SMB Engagement/Disengagment Force: 2 pounds minimum to 14 pounds maximum axial force Contact Retention: 4 lbs. minimum axial force (captivated contacts) 1 inch-ounce minimum torque (uncabled receptacles) Cable Retention: Axial Force* Torque (pounds) (in-oz) Connectors for RG-179, Belden 735A ............... 20 N/A Connectors for RG-59 ........................................ 40 N/A * or cable breaking strength whichever is less. Durability: 500 cycles minimum ENVIRONMENTAL RATINGS (Meets or exceed the applicable paragraph of MIL-C-39012) Temperature Range: - 65° C to +165° C -- Connectors and adapters - 65° C to +125° C -- Loads, matching pad 20° C to 26° C -- Opens, shorts Thermal Shock: MIL-STD-202, Method 107, Condition B (N/A opens, shorts, loads, matching pad) Corrosion: MIL-STD-202, Method 101, Condition B (N/A opens, shorts, loads, matching pad) Shock: MIL-STD-210, Method 213, Condition B (N/A opens, shorts, loads, matching pad) Vibration: MIL-STD-202, Method 204, Condition B (N/A opens, shorts, loads, matching pad) Temperature Coefficient: (Loads only) + 300 ppm/° C MATERIAL SPECIFICATIONS Bodies: Brass per QQ-B-626, gold plated** per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 N type adapters stainless steel per QQ-S-763, passivated per MIL-F-14072 Contacts: Male & Female - beryllium copper per QQ-C-530, gold plated per MIL-G-45204 .00003" min. Insulators: PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Crimp Sleeves: Copper per WW-T-799, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Mounting Hardware: Brass (nuts) per QQ-B-626 or phosphor bronze (lockwashers) QQ-B-750, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 ** All gold plated parts include a .00005" min. nickel underplate barrier layer. Avoid user injury due to misapplication. See safety advisory definitions inside front cover. MATING ENGAGEMENT FOR MINI-75 OHM SMB SERIES (INTERMATABLE WITH STANDARD 50 OHM SMB) Plug Jack Plug Jack NOTES: 1. ID of contact to meet VSWR, mating characteristics and connector durability when mated with a dia .019-.021 (0.48/0.53) male contact. 2. Must meet the force to engage and disengage when mated with mating part. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
131-8701-206 价格&库存
很抱歉,暂时无法提供与“131-8701-206”相匹配的价格&库存,您可以联系我们找货
  • 45+21.44944
  • 100+19.86552
  • 250+18.16069
  • 500+16.09313
  • 1000+13.45729
  • 5000+12.23610
  • 10000+11.29300
  • 25000+10.34990
库存:40077
131-8701-206
  • 1+46.347511+6.01666
