SPECIFICATION
Part No.
PCB.RPSMAFRA.HT
Product Name
RP-SMA(F)RA PCB Mount Jack Connector
Solder Attachment Through Hole
Feature
RP-SMA(F)RA Jack
Through Hole
Frequency Range: DC up to 6GHz
Finish: Gold
Dimensions: 13.75mm*15.1mm
RoHS Compliant
SPE-14-8-101/C/AD
Page 1 of 3
1. Introduction
The PCB.RPSMAFRA.HT connector was designed to be mounted on a PCB. The maximum
thickness of PCB that the connector can be used with is 0.4mm. The connector pin is directly
soldered onto pads on the PCB. The connector is a standard RP-SMA(F)RA Jack. Taoglas
connectors are all RoHS compliant.
2. Specification
ELECTRICAL
Impedance
50Ω
Frequency Range
DC~6 GHz
Working Voltage
Max. ≤170 Vrms
Dielectric withstanding Voltage
500 Vrms
Insulation Resistance
≥1000M MΩ
MECHANICAL
Connector Dimension
13.75mm*15.1mm
Connector Pin Diameter
1.25 mm
Connector Type
RP-SMA(F)RA Through Hole Jack
ENVIRONMENTAL
RoHS compliant
Operating Temperature
-40°C to +85°C
SPE-14-8-101/C/AD
Page 2 of 3
3. Connector Drawing
Name
Material
Finish
QTY
1
Body
Brass
Gold
1
2
Insulator
Teflon
White
1
3
Pin
Brass
Gold
1
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties
without express permission is strictly prohibited. Copyright © 2014, Taoglas Ltd.
SPE-14-8-101/C/AD
Page 3 of 3
很抱歉,暂时无法提供与“PCB.RPSMAFRA.HT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+39.154361+5.06566
- 10+33.2817410+4.30588
- 25+31.1969325+4.03616
- 50+29.7083650+3.84357
- 100+28.28862100+3.65989
- 250+26.51722250+3.43071
- 500+25.25190500+3.26701
- 1000+24.047491000+3.11119
- 2500+22.543362500+2.91659
- 国内价格 香港价格
- 1+20.611821+2.66669
- 10+20.4283510+2.64296
- 25+18.1470125+2.34780
- 50+17.9635550+2.32407
- 100+17.61257100+2.27866
- 250+17.00634250+2.20023
- 500+16.83883500+2.17856
- 1000+16.735141000+2.16514
- 国内价格 香港价格
- 100+21.18071100+2.74029
- 300+19.87163300+2.57093
- 500+19.57621500+2.53271
- 国内价格
- 1+52.09920
- 200+20.16360
- 500+19.45080
- 1000+19.10520
- 国内价格 香港价格
- 3+20.971323+2.71320
- 10+20.7846610+2.68905
- 25+18.4635325+2.38875
- 50+18.2768750+2.36460
- 100+17.91977100+2.31840
- 250+17.30297250+2.23860
- 500+17.13253500+2.21655
- 1000+17.027031000+2.20290
- 国内价格 香港价格
- 国内价格 香港价格
