Connectivity for
Business-Critical Continuity
Johnson
SMPM Connectors
Emerson Network Power Connectivity Solutions offers the Johnson line of SMPM
connectors. The sub-miniature, push-on style micro interfaces are distinguished
for their size (about 35% smaller than the SMP design) and becoming increasingly
Key Features & Benefits
35% smaller than SMP connectors
DC-65 GHz
Bullet adapter provides Blind Mate
capabilities
Available in PC mount, End Launch and
Cabled styles
popular for the two-fold design benefit of allowing for a higher-density of
connection points and maintaining solid Return Loss performance from DC-level
frequencies up to 65 GHz.
The Johnson SMPM family includes PC mount and End Launch styles, straight and
right-angled, .047 cabled connectors and sealable flange mounts. All male
connectors are offered as full detent or smooth bore designs for your preference of
separation forces.
The SMPM bullet adapter provides the same coveted blind mate functionality as
the larger SMP size connectors, mitigating radial and axial misalignment with
negligible change to VSWR and other signal losses. The SMPM-series is perfect for
use in test equipment and racked-electronics where footprint space is a premium
and mating boards together is difficult.
For those systems with even tighter tolerance restrictions on center to center
spacing, multi-channel blocks for straight or right-angle interfaces can be designed
and quoted through Emerson Connectivity Solutions responsive product design
team.
SMPM Product Family
Part Number
Description
125-0801-201
Straight PC Mount, Female
125-0701-201
125-2701-201
Straight PC Mount Male, Full Detent
Straight PC Mount Male, Smooth Bore
125-0701-801
125-2701-801
End Launch Male, Full Detent
End Launch Male, Smooth Bore
125-0901-801
Bullet Adapter
125-0592-001
125-2592-001
Straight Male for .047” Cable, Full Detent
Straight Male for .047” Cable, Smooth Bore
125-0692-001
Straight Female for .047” Cable
125-0701-602
125-2701-602
142-1000-041
2-Hole Flange Mount Male Shroud, Full Detent
2-Hole Flange Mount Male Shroud, Smooth Bore
Hermetic Seal Feed-Thru
125-0000-900
125-0000-901
SMPM Extraction Tool for Cabled Connectors
SMPM Bullet Adapter Installation/Extraction Tool
The Johnson line of SMPM connectors are manufactured with high quality beryllium copper and brass components and designed to meet
MIL-PRF-39012 and MIL-PRF-39012 specifications.
Estimated spacing between two mated boards connected via
PC mount and bullet adapters
299 Johnson Ave.SW, Ste 100
Waseca, MN 56093
Ph: 507.833.8822
8 Port Connector Block
Connectivity Solutions (Shanghai) Co.,Ltd.
Building 1, No. 800 Shenfu Road,
Xinzhuang Industrial Park
Ph: 86 21 54427668
www.EmersonConnectivity.com
Emerson Network Power Connectivity Solutions, Ltd.
11Bilton Rd
Chelmsford
Essex CM1 2UP
Ph: +44 1245.359.515
很抱歉,暂时无法提供与“125-2592-001”相匹配的价格&库存,您可以联系我们找货
