SPECIFICATION
Part No.
PCB.SMAFST.2H.B.HT
Product Name
SMA (F) Jack 2 Hole Panel Mount with Solder Post
Termination
Feature
SMA(F) Jack
2 Hole Panel Mount with Solder Post Termination
Frequency Range: 0~12.4GHz
Finish: Nickel
Post Length: 2mm
Total Length: 11.52mm
RoHS Compliant
SPE-12-8-141/B/WY
Page 1 of 5
1. Introduction
The PCB.SMAFST.2H.A.HT connector was designed to be mounted on a PCB, it has a Solder Post
for connection and 2 Mounting holes. The connector pin is directly soldered onto pads on the PCB.
The connector is a standard SMA (F) Jack. The SMA connector is the most popular type
connector for RF applications. Taoglas connectors are all RoHS compliant.
2. Specification
ELECTRICAL
Impedance
50Ω
Frequency Range
0~12.4 GHz
Working Voltage
Max. 335 Vrms
Dielectric withstanding Voltage
≤1000 Vrms
Insulation Resistance
≥5000M Ω
MECHANICAL
Connector Dimension
11.52 X 15.88 mm
Connector Pin Diameter
1.27 mm
Connector Pin Height
2 mm
Connector Type
SMA (F)
ENVIRONMENTAL
RoHS compliant
Operating Temperature
-40°C to +85°C
SPE-12-8-141/B/WY
Page 2 of 5
3. Connector Drawing
Name
Material
Finish
QTY
1
Body
Brass
Nickel
1
2
Female Contact
Phosphor Bronze
Gold
1
3
Insulator
Teflon
White
1
SPE-12-8-141/B/WY
Page 3 of 5
4. Packaging (Unit: mm)
SPE-12-8-141/B/WY
Page 4 of 5
Taoglas makes no warranties based on the accuracy or comple teness of the contents of this document and reserves
the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to
third parties without express permission is strictly prohibited.
Copyright © 2012, Taoglas Ltd.
SPE-12-8-141/B/WY
Page 5 of 5
很抱歉,暂时无法提供与“PCB.SMAFST.2H.B.HT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+47.83320
- 200+19.09440
- 500+18.45720
- 1000+18.13320
