HP75BNC9X
HP75BNC9X
    SWITCHCRAFT
    BNC
HP75BNC9X 数据手册
CRIMP ON THIS AREA 0.282 7.2 0.602 15.3 B A A B 0.319 8.1 0.157 4 GASKET RUBBER, RED WASHER SEE NOTES 2 AND 3 SHELL SEE NOTES 1 AND 3 RECOMMENDED CABLE STRIPPING DIMENSIONS FORMING SWITCHCRAFT STRIPPING TOOL #PTS1 BODY SEE NOTES 1 AND 3 0.488 12.4 B 0.571 14.5 0.152 3.9 0.326 8.3 ALTERNATE KNURL DESIGN 0.035 0.9 0.219 5.6 0.50 12.7 B 0.260 6.6 B RETAINER RING SEE NOTES 1 AND 3 SPRING SK5 SEE NOTE 4 0.953 24.2 SECTION A-A 0.059 B 1.5 0.053 1.34 FERRULE SEE NOTES 3 AND 7 CONTACT PIN SEE NOTES 1 & 5 INSULATOR NATURAL SEE NOTE 6 CUSTOMER DRAWING NOTES: FINISH (PLATING THICKNESS IN MICRO-INCHES) BRASS PER QQ-B-626 BRASS PER QQ-B-613 NICKEL PLATING 100 MIN THICK OVER COPPER STRIKE. NICKEL PLATING 200 MIN THICK OVER COPPER STRIKE. GOLD PLATING 50 MIN THICK OVER NICKEL PLATING 100 MIN THICK OVER COPPER STRIKE. 6. TEFLON MIL-P-19468 7. JIS H 3250, C 2600 8. CRIMPED FERRULE0 HEX CRIMP SIZE 0.255. 9. CRIMPED CONTACT PIN SQUARE CRIMP SIZE 0.042 OR HEX CRIMP SIZE 0.041. 10. ALL DIMENSIONS ARE FOR REFERENCE ONLY. 11. THIS PRODUCT IS RoHS COMPLIANT. 0.295 7.5 THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1. 2. 3. 4. 5. 1. ALL DIMENSIONS IN INCHES - TWO PLACE DECIMALS 0.01 - THREE PLACE DECIMALS 0.005 - ANGLES 1 - ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. B 26364 3-31-09 RS TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 26142 3-12-09 RF TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE REVISIONS BY APVD DO NOT SCALE DRAWING SolidWorks CAD File SIZE WIDTH MULT FINISH DATE DRAWN 10-31-06 B TEMPER MATERIAL SPEC No. FIRST USED ON NAME LBS/M BY RF SPEC No. SCALE 3:1 CHKD RF 10-31-06 APVD TJK 10-31-06 75 OHM BNC CONNECTOR 1505A CABLE, RoHS SHEET PART No. 1 OF 1 HP75BNC9X REV B
HP75BNC9X 价格&库存
很抱歉,暂时无法提供与“HP75BNC9X”相匹配的价格&库存,您可以联系我们找货
