133-3901-801
133-3901-801
    CINCH
133-3901-801 数据手册
MCX 50 Ohm Jack to Jack Adapter GOLD PLATED NICKEL PLATED 133-3901-801 133-3901-806 INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com MCX - 50 Ohm Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST ELECTRICAL RATINGS Impedance: 50 Ohms Frequency Range: Connectors .............................................. 0-6 GHz Dummy loads .......................................... 0-1 GHz VSWR: (f = GHz) Straight Cabled Right Angle Connectors Cabled Connectors RG-178 cable ................................... 1.17 + .04f 1.07 + .06f RG-316 and .086 semi-rigid cable ... 1.13 + .04f 1.07 + .04f Adapters .............................................................................. 1.13 + .04f Uncabled receptacles, Dummy loads ............................................ N/A Working Voltage: (Vrms maximum)† Connectors for Cable Type Sea Level 70K Feet RG-178 ................................................... 250 65 RG-316, .086 semi-rigid uncabled uncabled receptacles, adapters ............ 335 85 Dummy loads ............................................................................. N/A Dielectric Withstanding Voltage: (VRMS minimum at sea level) Connectors for RG-178 .............................................................. 750 Connectors for RG-316, .086 semi-rigid, uncabled receptacles, adapters ............................................ 1000 Dummy loads ............................................................................. N/A Corona Level: (Volts minimum at 70,000 feet) Connectors for RG-178 .............................................................. 190 Connectors for RG-316, .086 semi-rigid uncabled receptacles, adapters .............................................. 250 Dummy loads ............................................................................. N/A Insertion Loss: (dB maximum, tested at 1 GHz) Straight cable connectors and adapters ................................. 0.1 dB Right angle cable connectors ................................................. 0.2 dB Uncabled receptacles, dummy loads ......................................... N/A Insulation Resistance: 10,000 megohms minimum After Contact Resistance: (milliohms maximum) Initial Environmental Center contact (straight cabled connectors, uncabled receptacles and adapters) ................. 5.0 8.0 Center contact (right angle cabled connectors) .... 5.0 15.0 Outer contact ........................................................ 1.0 1.5 Braid to body (gold plated connectors) ................. 1.0 N/A Braid to body (nickel plated connectors) ............... 2.5 N/A RF Leakage: (dB typical tested at 2.5 GHz) Cable connectors .................................................................. -55 dB Uncabled receptacles and adapters, dummy loads ................... N/A Avoid user injury due to misapplication. See safety advisory definitions on page 2. ** All gold plated parts include a .00005" min. nickel underplate barrier layer. RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz) Connectors for RG178 ............................................................... 500 Connectors for RG316 and adapters ......................................... 700 .086 semi-rigid ............................................................................ 670 Uncabled receptacles ................................................................. 600 Dummy loads ............................................................................. N/A Power Rating (Dummy Load): 0.5 watt @ +25°C, derated to 0.25 watt @ +125°C MECHANICAL RATINGS Engagement Design: Compatible with CECC 22220, Series MCX Engagement Force: 5.6 pounds maximum axial force Disengagement Force: 8 pounds maximum axial force, 1 pound min. Contact Retention: 2.3 pounds min. axial force (captivated contacts) 1 inch-ounce min. torque (uncabled receptacles) Cable Retention: Axial Force* Torque (pounds) (in-oz) Connectors for RG178 ................................ 10 N/A Connectors for RG316 ................................ 20 N/A Connectors for RG316DS ........................... 25 N/A Connectors for .086 semi-rigid .................... 30 16 * or cable breaking strength whichever is less. ENVIRONMENTAL RATINGS (Meets or exceed the applicable paragraph of MIL-C-39012)Durability: 500 cycles minimum Temperature Range:Connectors ............................... - 65°C to + 165°C Dummy loads .......................... - 65°C to + 125°C Thermal Shock: MIL-STD-202, Method 107, Condition F (N/A dummy loads) Corrosion: MIL-STD-202, Method 101, Condition B (N/A dummy loads) Shock: MIL-STD-202, Method 213, Condition B (N/A dummy loads) Vibration: MIL-STD-202, Method 204, Condition B (N/A dummy loads) Moisture Resistance: MIL-STD-202, Method 106 (N/A dummy loads) MATERIAL SPECIFICATIONS Bodies: Brass per QQ-B-626 or zinc per ASTM B86-71, gold plated** per MIL-G-45204 .00001” min or nickel plated per QQ-N-290 or bright tin plated Contacts: Male - brass per QQ-B-626, gold plated per MIL-G-45204 .00003" min. Female - beryllium copper per QQ-C-530, gold plated per MIL-G45204 .00003" min. Insulators: PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Crimp Sleeves: Copper per WW-T-799, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Mounting Hardware: Brass (nuts) per QQ-B-626 or phosphor bronze (lockwashers) QQ-B-750, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 MATING ENGAGEMENT FOR MCX SERIES COMPATIBLE WITH CECC 22220 JACK JACK PLUG PLUG NOTES 1. ID of contact to meet VSWR mating characteristics and connector durability when mated with a dia. .019-.021 (0.48-0.53) male contact. 2. Must meet the force to engage and disengage when mated with mating part. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
133-3901-801 价格&库存
很抱歉,暂时无法提供与“133-3901-801”相匹配的价格&库存,您可以联系我们找货
