Additional Resources:
Product Page
date
12/07/2022
page 1 of 3
MODEL: PJ-050AH | DESCRIPTION: DC POWER JACK
FEATURES
• 2.0 mm center pin
• 5.0 A rating
• right-angle orientation
• through hole
• pick-n-place top
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
24
rated input current
contact resistance
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
units
Vdc
5.0
A
100
30
mΩ
mΩ
500
Vac
100
MΩ
insertion/withdrawal force
0.3
3
kg
operating temperature
-25
85
°C
life
5,000
flammability rating
UL94V-0
RoHS
yes
cycles
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
for max 5 seconds
255
260
265
°C
Pin Temperature
Component Temperature
A. Preheating
B. Soldering
C. Cooling
cuidevices.com
Product Page
CUI DEVICES | MODEL: PJ-050AH | DESCRIPTION: DC POWER JACK
date 12/07/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.20 mm
X.XX ±0.15 mm
X.XXX ±0.10 mm
PCB: ±0.05 mm
unless otherwise specified
DESCRIPTION
MATERIAL
PLATING/COLOR
center pin
copper alloy(H65)
nickel
terminal 1
C2680 t=0.35 mm
nickel-tin
terminal 2
C5210 t=0.25 mm
nickel-tin
terminal 3
C2680 t=0.30 mm
nickel-tin
housing
PA9T (UL94V-0)
black
cover
PA9T (UL94V-0)
black
Recommended PCB Layout
Top View
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 9.6 mm
Model
PJ-050AH
Center Pin
Ø2.0 mm
cuidevices.com
Product Page
date 12/07/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
07/30/2007
1.01
applied new spec template
01/03/2014
1.02
increased voltage rating
04/14/2016
1.03
brand update
10/29/2019
1.04
logo, datasheet style update
08/05/2022
1.05
product reengineered for improved manufacturability and production yield, see
PCN for details
12/07/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-050AH”相匹配的价格&库存,您可以联系我们找货
