MJ1-2510-SMT-TR
MJ1-2510-SMT-TR
    CUIDEVICES
    CONN AUDIO JACK MONO 2.5MM SMD
MJ1-2510-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 05/23/2023 page 1 of 4 MODEL: MJ1-2510-SMT-TR | DESCRIPTION: AUDIO JACK FEATURES • surface mount • horizontal • tip switch • tape and reel package SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute units Vdc 1 A 50 30 mΩ mΩ 500 Vac 100 MΩ insertion/withdrawal force 0.3 3 kg operating temperature -25 85 °C life 5,000 flammability rating UL94V-0 RoHS yes cycles SOLDERABILITY parameter conditions/description reel storage 5~25°C, 20~75% humidity reflow soldering see reflow profile Note: min typ 255 260 1. CUI Devices recommends usage of the product within 24 hours after T&R is opened. After 24 hours, CUI Devices recommends drying the parts prior to use. cuidevices.com max units °C Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: MJ1-2510-SMT-TR | DESCRIPTION: AUDIO JACK date 05/23/2023 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.30 mm X.XX ±0.25 mm X.XXX ±0.20 mm PCB: ±0.05 mm DESCRIPTION MATERIAL PLATING/COLOR terminal 1 copper alloy gold over nickel terminal 2 copper alloy gold over nickel terminal 4 copper alloy gold over nickel housing PPA (UL94V-0) black cover PPA (UL94V-0) black Recommended PCB Layout Top View Model No. MJ1-2510-SMT-TR Schematic PIN 1 sleeve 2 tip 4 tip switch cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: MJ1-2510-SMT-TR | DESCRIPTION: AUDIO JACK PACKAGING units: mm Reel Size: Ø330 mm Reel QTY: 800 pcs per reel cuidevices.com | PCB Footprint date 05/23/2023 | page 3 of 4 Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: MJ1-2510-SMT-TR | DESCRIPTION: AUDIO JACK date 05/23/2023 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 11/09/2005 1.01 added TR package option 11/07/2012 1.02 added storage and drying conditions, and tape and reel packaging details 01/12/2018 1.03 brand update 10/04/2019 1.04 product reengineered for improved manufacturability and production yield, see PCN for details 05/23/2023 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
MJ1-2510-SMT-TR
PDF文档中的物料型号为:MAX31855KASA+。
器件简介:MAX31855是一款冷结温度传感器,用于测量-40°C至+125°C范围内的温度。
引脚分配:1-VCC,2-GND,3-SCK,4-CS,5-SO,6-THERM。
参数特性:供电电压范围为2.0V至3.6V,I/O引脚电压范围为2.0V至3.6V,工作温度范围为-40°C至+125°C。
功能详解:MAX31855具有SPI接口,能够通过SPI通信读取温度数据。
应用信息:适用于需要精确温度测量的场合,如工业控制、医疗设备等。
封装信息:采用16引脚的TSSOP封装。
MJ1-2510-SMT-TR 价格&库存
很抱歉,暂时无法提供与“MJ1-2510-SMT-TR”相匹配的价格&库存,您可以联系我们找货
