Series 5600 .563" (14.29mm) Center-to-Center Spacing
Features:
Dual Row
Durable, Hi-Temp, phenolic is self-extinguishing, resists
breakage and conforms to UL94V-0
Terminal Flexibility is ideal for surface mount, sub-panel or
chassis connections. One thru 22 terminals. 9/16" center-tocenter spacing.
Economical Closed-Back Design does not require costly
insulation strip
Broad Wire Range using 8-32 or 10-32 external twin
screws, UL recognized for No. 22 AWG to No. 10 AWG.
Variations include double solder lug, single solder lug, wire
wrap and printed circuit pin
UL Electrical Ratings
50Amp up to 600VAC dependent on options
Field Wiring to 40A
Factory Wiring to 50A
Recognition
Various terminal types are UL recognized and CSA certified.
Series 5600 Variations
UL Standard 1059,
Guide No. XCFR2
11/16" ±.032
0 = Flush Mount
CSA Guide
22.2 No. 158
BARRIER STYLE
1 = Turret TType Solder Terminal
Designed to meet IEC 947-7-1
Series 5600 Dimensions
"A" OVERALL DIMENSION W/MTG ENDS
.21
.563
1.311
6SeFL¿FatLoQs:
"B" MOUNTING DIMENSION
.563
.500
"C" OVERALL DIMENSION
BARRIERS BOTH SIDES
4X Ø.208
MOUNTING HOLES
.420
.810
.438
PC BOARD DRILLING DIMENSIONS
.5625
Typ.
2-11 Terminals
Ø.079
12-22 Terminals
T
Ø.093
36
www.curtisind.com
Center-to-Center Spacing: .563" (14.29mm)
Wire Range: No. 22AWG to No. 8AWG (No. 8 with ring lug
for #10 screw only)
No. of Terminals: 1 thru 22
Voltage Rating: 600V
Tightening Torque: 16 in.-lbs. with #8 screws
20 in.-lbs. with #10 screws
Current Rating:
50A with #8 or #10 screw and ring lug
40A with #10 screw
35A with #8 Screw
(Options may affect current rating)
Housing:
Material
Phenolic
Continuous Use
Temp. (UL Index)
150°C (302°F)
Flammability Rating
94V-0
Water Absorption
(24 hrs. % wt. gain) .1%
Breakdown Voltage:
Terminal - Terminal
7,500 Vrms
Terminal - Ground
6,000 Vrms
Curtis Industries
A Division of Powers Holdings, Inc.
6SHci¿cDtionssuEMHcttocKDnJH.
Dimensions are shown for
reference purposes only.
56 0 0 0 0 00 0
How to Order
MOLDING DESIGN ]
1 = Barriers Both Sides
2 = w/ Mounting Ends
3 = Y Pin with Barriers
4 = Y Pin with Mounting Ends
[ SPECIALS OR
OPTIONAL DESIGNS
0 = None
1 = Double Tab, Flat (TB91)
2 = Double Tab, 45° Bend (TB92)
3 = Double Tab, 90° Bend (TB93)
7 = Single Tab, Flat (TB97)
8 = Single Tab, 45° Bend (TB98)
5 Thru 9 to be assigned.
TERMINATION DESIGN ]
Part No.
Digit
Terminal
Plate Type
Screw
Type
Approval
*Field/
Factory
0=
STEEL
STEEL
UR/cUR
2
1=
STEEL
**BRASS
UR
1
** SEMS NOT AVAILABLE IN BRASS
*1 = FACTORY WIRING ONLY
2 = FACTORY & FIELD WIRING
[ NUMBER OF POLES AVAILABLE
Available
01-22 w/ Mounting Ends
01-22 w/ Barriers Both Ends
SCREW SIZE ]
0 = 8-32 Thread
1 = 10-32 Thread
“A” (Min-Max)
Overall Dim.
w/ Mounting Ends
“B” (Min-Max)
Mounting Dim.
1.551–1.539
1.131–1.119
2
2.116–2.100
1.694–1.682
3
2.680–2.660
2.258–2.242
4
3.245–3.221
2.823–2.803
5
3.809–3.781
3.387–3.363
6
4.374–4.342
3.952–3.924
7
4.938–4.902
4.516–4.484
8
5.503–5.463
5.081–5.045
9
6.067–6.023
5.645–5.605
10
6.632–6.584
6.210–6.166
11
7.196–7.144
6.774–6.726
12
7.761–7.705
7.339–7.287
13
8.325–8.265
7.903–7.847
QUICK CONNECT TERMINALS
14
8.888–8.828
8.468–8.408
15
9.452–9.388
9.030–8.970
.250" x .032" quick connect tabs available in 6 different styles. Tin-plated brass
tabs are held in place by terminal screws. Terminal blocks can accommodate 1
to 6 terminations per pole. Factory assembled or shipped bulk.
1
Double Sided
Single Sided
TB91
TB97
TB92
TB98
TB93
TB99
Series 5600 Accessories
16
10.017–9.949
9.595–9.531
17
10.581–10.509
10.159–10.091
18
11.146–11.070
10.724–10.652
19
11.710–11.630
11.288–11.212
12.273–12.193
11.853–11.773
Wire clamp captivated screws eliminate the need for lugs.
Available for both 8-32 & 10-32 thread options, these screws
accept up to No. 10AWG wire and may be factory installed
or shipped bulk.
21
12.837–12.753
12.415–12.335
TERMINAL BLOCK JUMPERS
22
13.402–13.314
12.978–12.898
Jumpers constructed of plated brass
permit connections of 2 poles
Dimensions shown are ± 0.030"
Dimensions are in inches and millimeters
unless otherwise speci¿ed.
Values in parentheses are metric equivalents.
BARRIER STYLE
[ SCREW TYPE
0 = Binder Head, Combo Slot, Zinc Plated, Steel
2 = Binder Head, Combo Slot, Nickel Plated, Brass
4 = Wire Clamp Sems, Combo Slot, Zinc
Plated, Steel
6 = Quick Connects Tabs Supplied w/ Binder Head
(see special options)
Dimensions
Number
of
Terminals
Dual Row
9 = Single Tab, 90° Bend (TB99)
A thru Z to be assigned
by engineering for special
con¿gurations (optional
Mumper available)
WIRE CLAMPS
Curtis Industries
1-800-657-0853
37
很抱歉,暂时无法提供与“562012130”相匹配的价格&库存,您可以联系我们找货
