ED104/XDS
ED105/XDS
2-12 poles, Spacing 5.0 mm
insert required no. of poles x
How to order see page 5
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Rated Torque/ScrewSize
250 V
32 A (T60)
2
4.0 mm
2.0 kV
0.8 Nm/M3
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Max. Rated Cross Section
Single Wire (solid)
Stranded Wire (flexible)
Stranded wire with Ferrules
4.0 mm
2
2.5 mm
2
1.5 mm
Single Wire (solid)
2.5 mm 2
1.5 mm 2
1.5 mm 2
Dimensions
Spacing
PCB Hole Diameter
Stripped Length
5.0 mm
2.0 mm x 2.8 mm
7.0 mm
Dimensions
Spacing
PCB Hole Diameter
Stripped Length
5.0 mm
1.3 mm
6.0 mm
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Wire Guard
PA
UL94 V-0
-30 C/+105 C
CuZn
Stainless Steel
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Wire Guard
PA
UL94 V-0
-30 C/+105 C
CuZn
Stainless Steel
Color
Grey
7
300V
15 A
AWG 22-14
2
300V
15 A
AWG 22-14
250 V
24 A (T60)
2.5 mm 2
2.0 kV
0.5 Nm/M3
Color
Blue
ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444
7
很抱歉,暂时无法提供与“ED104/8DS”相匹配的价格&库存,您可以联系我们找货
