ED700/X (5.0 mm)
EDZ700/X (5.08 mm)
ED705/X (5.0 mm)
EDZ705/X (5.08 mm)
2-12 poles, Spacing 5.0 mm and 5.08 mm
insert required no. of poles x
How to order see page 5
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Rated Torque/ScrewSize
250 V
24 A (T60)
2.5 mm 2
2.0 kV
0.5 Nm/M3
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Max. Rated Cross Section
Single Wire (solid)
Stranded Wire (flexible)
Stranded wire with Ferrules
4.0 mm 2
2.5 mm 2
2.5 mm 2
Single Wire (solid)
4.0 mm 2
2.5 mm 2
2.5 mm 2
Dimensions
Spacing
PCB Hole Diameter
Stripped Length
5.0 mm (5.08 mm)
1.3 mm
8.0 mm
Dimensions
Spacing
PCB Hole Diameter
Stripped Length
5.0 mm (5.08 mm)
1.3 mm
8.0 mm
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Wire Guard
PA
UL94 V-0
-30 C/+105 C
CuZn
Cu
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Wire Guard
PA
UL94 V-0
-30 C/+105 C
CuZn
Cu
Color
Green
23
300V
20 A
AWG 30-12
300 V
15 A
AWG 22-14
250 V
24 A (T60)
2.5 mm 2
2.0 kV
0.5 Nm/M3
Color
Green
ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444
23
很抱歉,暂时无法提供与“ED705/3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+13.0203250+1.68512
