EM322703
EM322703
    EATON(伊顿)
    插件,P=7.5mm
    接线端子 1x3P 7.5mm 直插 排数:单排 每排Pin数:3
EM322703 数据手册
Cage & Screw EM3227 Series EuroMag Terminal Blocks 35° Angle, 7.50 Centers; Modular SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.295” (7.50mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Material: Brass, Nickel-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths File E62622; CE Certified Agency Information: Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 15.0 22.5 33.0 37.5 45.0 52.5 60.0 67.5 75.0 82.5 90.0 97.5 14 15 16 17 18 19 20 21 22 23 24 105.0 112.5 120.0 127.5 133.0 142.5 150.0 157.5 165.0 172.5 180.0 Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks EM322705 Dimensions - mm (in) To convert to inches, divide by 25.4 Part Numbering System En Mn 3n 2n 2n 7 nn n Series # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors 46
EM322703 价格&库存
很抱歉,暂时无法提供与“EM322703”相匹配的价格&库存,您可以联系我们找货
EM322703
    • 1+2.49610
    • 200+0.99598
    • 500+0.96272
    • 1000+0.94630
