ED365/10
ED365/10
    OST
    插件,P=7.5mm
    7.5MM 排数:1 每排P数:10 直插
ED365/10 数据手册
ED360/X ED365/X 2-12 poles, Spacing 7.5 mm insert required no. of poles x 2-12 poles, Spacing 7.5 mm insert required no. of poles x How to order see page 5 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize 750 V 24 A (T60) 2.5 mm 2 3.0 kV 0.5 Nm/M3 Ratings Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 1.5 mm 2 1.5 mm 2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 1.5 mm 2 1.5 mm 2 Dimensions Spacing PCB Hole Diameter Stripped Length 7.5 mm 1.3 mm 6.0 mm Dimensions Spacing PCB Hole Diameter Stripped Length 7.5 mm 1.3 mm 6.0 mm Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Cu Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Cu Color Green 15 How to order see page 5 300V 16 A AWG 22-12 300V 16 A AWG 22-12 750 V 24 A (T60) 2.5 mm 2 3.0 kV 0.5 Nm/M3 Color Green ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 15
ED365/10 价格&库存
很抱歉,暂时无法提供与“ED365/10”相匹配的价格&库存,您可以联系我们找货
ED365/10
  • 50+32.3530150+4.19778
