ED450/X (10.0 mm)
EDZ450/X (10.16 mm)
ED370/X
2-12 poles, Spacing 5.0 mm
insert required no. of poles x
2-12 poles, Spacing 10.0 mm and 10.16 mm
How to order see page 5
*factory wiring
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Rated Torque/ScrewSize
250 V
24 A (T60)
2.5 mm 2
2.0 kV
0.5 Nm/M3
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Max. Rated Cross Section
Single Wire (solid)
Stranded Wire (flexible)
Stranded wire with Ferrules
2.5 mm 2
1.5 mm 2
1.5 mm 2
Single Wire (solid)
2.5 mm 2
1.5 mm 2
1.5 mm 2
Dimensions
Spacing
PCB Hole Diameter
Stripped Length
5.0 mm
1.3 mm
6.0 mm
Dimensions
Spacing
PCB Hole Diameter
Stripped Length
10.0 mm (10.16 mm)
1.3 mm
6.0 mm
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Wire Guard
PA
UL94 V-0
-30 C/+105 C
CuZn
Cu
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Wire Guard
PA
UL94 V-0
-30 C/+105 C
CuZn
Cu
Color
Green
16
300V
16 A
AWG 22-12
300V
16 A
AWG* 28-12
1000 V
24 A (T60)
2.5 mm 2
3.5 kV
0.5 Nm/M3
Color
Green
ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444
16
很抱歉,暂时无法提供与“ED370/11”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+87.0996350+11.27381
