Quick Connect Terminal Blocks
SPECIFICATIONS:
Rating: 40A, 600V
Center Spacing: .390" (9.91 mm)
Number Of Poles: 3
Circuits Per Foot: 28
Wire Range: AWG #8-22 CU
Screw Size: #8-32
Mounting Options: C-rail
Marking Tape: MT12-1/2
Torque Rating: 18 in-lb
Operating Temperature: 105°C
1.31
(33.32)
1.25
(31.75)
1.25
(31.75)
Single & Double Row
Filtered Connectors
NTQ23
1.25
(31.75)
Euro-MAG Series
PCB – Spring Clamp
BNQ21
SPECIFICATIONS:
Rating: 40A, 600V; UL/CSA
Center Spacing: .437" (11.10 mm)
Number Of Poles: 1
Circuits Per Foot: 24
Screw Size: #8-32
Quick Connects: .250" x .031"
Mounting Options: Base Mount
Stackable; End Piece (Part No. BQE)
is required for mounting. Mounting
screws recommended every 8 circuits.
#BQE
(end mtg. adaptor)
#8 mtg.
screw
.56
(14.28)
B
1.41
(35.81)
A
A
Base & Rail Mount
Connectors
1.47
(37.33)
B
(N+2) x .437
(N+1) x .437
N = Number of circuits
BQE
End Mounting Adapter Required
#BQE
(end mtg. adaptor)
#8 mtg.
screw
.56
(14.28)
1.47
(37.33)
B
1.41
(35.81)
A
A
BQE
B
(N+2) x .437
(N+1) x .437
127
WIRE MANAGEMENT PRODUCTS
SPECIFICATIONS:
Rating: 30A, 600V; UL/CSA
Number Of Poles: 1
Wire Range: For use with quick
connect terminals only.
Mounting Options: Base Mount,
Power Distribution Blocks
BQQ41
很抱歉,暂时无法提供与“NTQ23-WH”相匹配的价格&库存,您可以联系我们找货
