SERIES A00
STANDARD RJ45 MODULAR JACKS
FEATURES:
Top performance for high speed networking, voice and data
applications
Meet FCC PART 68, Subpart F requirements
Industry standard footprint and height with low profile
options available
Available with or without shielding
Ganged and/or stacked for multiple port requirements
Advanced EMI / RFI protection with Grounding options (PCB
or Panel)
Both plugs and jacks can be fully or partially loaded
Available in Tab-up (inverted latch) or Tab-down (standard l)
for single port
Applications: Telecommunications, Broadcast, Data Products
RoHS Compliant
Note: Registered Jack (RJ11) has only 6 contacts
Specifications:
Housing Material
Contact Material
Contact Plating
Current Rating
Voltage Rating
Contact Resistance
Dielectric Withstanding Voltage
Insulation Resistance
Durability
Operating Temperature
Wave Soldering Process
EXAMPLE PART NUMBER:
PBT Polyester, UL 94V-0
Phosphor Bronze
Gold Plating on contact area and Tin Plating on tails with Nickel underplating all over
1.5A @25°C
125V AC
20 mΩ maximum
1000VAC
500 MΩ minimum
750 cycles minimum
-40°C to +85°C
260°C ± 5°C, 5~10 Seconds
A00-108-260-450
SERIES:
MODULAR JACK
REGISTERED JACK
NO. OF PORTS:
1 - 1 PORT
2 - 2 PORTS
8 - 8 PORTS
NO. OF CONTACTS
08 - 8 CONTACTS ON 1PORT
16 - 16 CONTACTS ON 2 PORTS
64 - 64 CONTACTS ON 8 PORTS
AA - 128 CONTACTS ON DUAL ROW 8 PORTS
CONTACT PLATING:
2 - GOLD FLASH
3 - 15 MICROINCHES OF GOLD
6 - 30 MICROINCHES OF GOLD
9 - 50 MICROINCHES OF GOLD
CONNECTOR TYPE:
1 - ADAPTER
2- VERTICAL
5 - R/ANGLE SINGLE ROW WITH STOP
6 - R/ANGLE SINGLE ROW
7 - R/ANGLE TWO ROWS
8 - R/ANGLE SINGLE ROW HIGH PROFILE
9 - SURFACE MOUNT
0 - LOW PROFILE R/ANGLE (.460")
A - R/ANGLE SINGLE ROW WITH OPTIONAL PANEL STOP
B - MICROPIERCING CONNECTOR
CONTACT ARRANGEMENT:
KEY HIGH/LOW PANEL
PROFILE STOP
0NO LOW **
NO
1YES LOW **
NO
2NO HIGH
NO
3YES HIGH
NO
4NO HIGH
YES
5YES HIGH
YES
6NO LOW
YES
7YES LOW
YES
* - FLANGE ON VERTICAL ONLY
** - VERTICAL AVAILABLE IN HIGH PROFILE ONLY
RJ TYPE:
43- CAT 3 (WITH LATCH FOR ADAPTERS ONLY)
44 - CATEGORY 5e (WITH LATCH FOR ADAPTERS ONLY)
45 - CATEGORY 5 (WITH LATCH FOR ADAPTERS ONLY)
46 - CATEGORY 5 (NO LATCH FOR ADAPTERS ONLY)
11 - RJ11 (WITH LATCH FOR ADAPTERS ONLY)
12 - RJ11 (NO LATCH FOR ADAPTERS ONLY)
SHIELDING:
0 - NO SHIELD
1 - METAL SHIELD (GRND BACK)
2 - METAL SHIELD (GRND FRONT)
3 - HALF METAL SHIELD
4 - METAL SHIELD ADAPTER
5 - METAL SHIELD (GRND BACK) WITH TOP PANEL GRND
6 - METAL SHIELD (GRND FRONT) WITH TOP PANEL GRND
7 - METAL SHIELD (GRND BACK) WITH TOP AND SIDE PANEL GRND
8 - METAL SHIELD (GRND FRONT) WITH TOP AND SIDE PANEL GRND
9 - METAL SHIELD (GRND FRONT) WITH BOTTOM PANEL GRND
A- METAL SHIELD(GRN BACK) WITH BOTTOM PANEL GRND
B- METAL SHIELD(GRN FRONT) WITH BOTTOM & TOP PANEL GRND
C- METAL SHIELD(GRN BACK) WITH BOTTOM & TOP PANEL GRND
*Please consult EDAC for the availability of the modular or magnetic jack if
the part no is created using this ordering guide.
www.edac.net
很抱歉,暂时无法提供与“A00-108-262-450”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+29.059051+3.77318
