A20-216-261-310
A20-216-261-310
    插件
A20-216-261-310 数据手册
SERIES A20 STANDARD RJ45 MODULAR JACKS WITH LED FEATURES: • • • • • • • • • • • Combined functionality of series A00 :RJ45 Cat.5 Jacks with the signal capabilities of independent LED's mounted within the jack housing. Each jack can have one or two LED's. LED's available as either a single color with matching colored lens, or as a bi-color variant that utilizes a clear lens. Bi-color LED's can be made to change color simply by reversing the voltage polarity. Custom LED color combinations are available, as well as, the selective loading of contacts, custom contact plating and special shielding. Right angle jacks can be made with a larger housing that allows custom specified filter components FCC Compliance: Part 68 Sub Part F Applications: Telecommunications, Broadcast, Data Products Performance: Cat3 (10 Base-T), Cat5 (10/100 Base-T), Cat 5e (10/100/1000 Base-T) or Gigabit Ethernet RoHS Compliant Specifications: Housing Material Contact Material Contact Plating Current Rating Voltage Rating Contact Resistance Dielectric Withstanding Voltage Insulation Resistance Durability Operating Temperature Wave Soldering Process EXAMPLE PART NUMBER: PBT Polyester, UL 94V-0 Phosphor Bronze Gold Plating on contact area and Tin Plating on tails with Nickel underplating all over 1.5A @25°C 125V AC 20 mΩ maximum 1000VAC 500 MΩ minimum 750 cycles minimum -40°C to +85°C 260°C ± 5°C, 5~10 Seconds A20-108-261-310 PORT TYPE: 0SINGLE ROW OF PORT 1TWO ROW OF PORTS SERIES: RJ45 MODULAR JACK W/ LED NO. OF PORTS: 1 - 1 PORT 2 - 2 PORTS . 8 - 8 PORTS SHIELDING: 0 - NO SHIELD 1 - METAL SHIELD NO. OF CONTACTS 08 - 8 CONTACTS ON 1PORT 16 - 16 CONTACTS ON 2 PORTS . 64 - 64 CONTACTS ON 8 PORTS AA - 128 CONTACTS ON DUAL ROW 8 PORTS CONTACT PLATING: 2 - GOLD FLASH 3 - 15 MICROINCHES OF GOLD 6 - 30 MICROINCHES OF GOLD 9 - 50 MICROINCHES OF GOLD CONTACT TAIL TYPE: 2 - VERTICAL 6 - RIGHT ANGLE 7 - VERTICAL SURFACE MOUNT 8 - RIGHT ANGLE SURFACE MOUNT 9 - SURFACE MOUNT ONLY IN SINGLE PORT www.edac.net LEFT LED RIGHT LED RIGHT LED COLOR: 0 - BLANK 1 - YELLOW 2 - RED 3 - GREEN 4 - BI-COLOR (GREEN/YELLOW) 5 - BI-COLOR (RED/GREEN) 6 - BI-COLOR (GREEN/ORANGE) 7 - BI-COLOR (RED/YELLOW) 8 - ORANGE LEFT LED COLOR: 0 - BLANK 1 - YELLOW 2 - RED 3 - GREEN 4 - BI-COLOR (GREEN/YELLOW) 5 - BI-COLOR (RED/GREEN) 6 - BI-COLOR (GREEN/ORANGE) 7 - BI-COLOR (RED/YELLOW) 8 - ORANGE
A20-216-261-310 价格&库存
很抱歉,暂时无法提供与“A20-216-261-310”相匹配的价格&库存,您可以联系我们找货
