A60-112-300P492
A60-112-300P492
    CONN MAGJACK 1PORT 1000 BASE-T
A60-112-300P492 数据手册
SERIES A6X STANDARD RJ45 MAGNETIC JACKS FEATURES: • • • • • • • • • • 10/100 or 1000 Base T options – Full IEEE 802.3 compliance Integrated Magnetics – Provides signal integrity, DC isolation and protection for PHY chip Integrated Design - Reduces component inventory and process costs Spring fingers on shells - Guaranteed advanced EMI/RFI suppression LED options available - Visual indication of port status and activity information for user Tab Up or Down options - Complete design for board and unit compatibility Available as Single or Stacked Multiport Options Mate with Modular Plug Conforming to FCC Part 68, Subpart F Applications: Telecommunications, Broadcast, Data Products RoHS Compliant Specifications: Housing Material Contact Material Contact Plating Shield Storage Temperature Wave Soldering Process Performance: CAT5 CAT5e CAT6a Thermoplastic, UL 94V-0 Copper Alloy Gold Plating on contact area and Tin Plating on tails with Nickel underplating all over Copper Alloy with Nickel Plating -40°C to +85°C 260°C ± 5°C, 5~10 Seconds 10/100 BASE-T 10/100/1000 BASE-T or Gigabit Ethernet 10 Gigabit Ethernet Example Part Number: SERIES: A60 - 10/100/1000 BASE T, 8 CORE A62 - 10/100 BASE T, 2 CORE A63 - 10/100 BASE T, 4 CORE A64 - 10/100 BASE T, 5 CORE A65 - 10 BASE T, 3 CORE A66 - 10 BASE T, 4 CORE A67 - 10/100 BASE T, POE A68 - 10/100 BASE T WITH USB TYPE A A69 - 100/1000 BASE T WITH USB TYPE A A70 - 100/1000 BASE T, POE A60-142-200P431 NO. OF PORTS: 1 4 STACK SIZE PORT PER STACK 11 - 1X1: 1 PORT, 21 - 2X1: 2 PORTS 12 - 1X2: 2 PORTS, 22 - 2X2: 4 PORTS 14 - 1X4: 4 PORTS, 24 - 2X4: 8 PORTS 18 - 1X8: 8 PORTS, 28 - 2X8: 16 PORTS 1A - 1+2USB: 1 PORT + 2 USB PORTS 1B - 1+2USB3.0: 1 PORT + 2 USB3.0 PORTS CONTACT PLATING: 2 - GOLD FLASH 3 - 15 MICROINCHES OF GOLD 4 - 30 MICROINCHES OF GOLD 5 - 50 MICROINCHES OF GOLD CONNECTOR TYPE: 2 - RIGHT ANGLE WITH TAB-UP 3 - RIGHT ANGLE WITH TAB-DOWN 4 - VERTICAL WITH TAB-UP 5 - VERTICAL WITH TAB-DOWN 6 - SMT WITH TAB-UP 7 - SMT WITH TAB-DOWN 8 - RIGHT ANGLE WITH TAB-UP AND PANEL STOP 9 - RIGHT ANGLE WITH TAB-DOWN AND PANEL STOP A - VERTICAL WITH TAB-UP AND PANEL STOP ELECTRICAL CIRCUIT TYPE: (SEE CIRCUIT TYPE PAGE FOR DETAILS) SHIELD TYPE: 0 - NO SHIELD 1 - SHIELDED, NO EMI FINGER 2 - SHIELDED, WITH EMI FINGER ON TOP 3 - SHIELDED, WITH EMI FINGER BOTH SIDES 4 - SHIELDED, WITH EMI FINGER ON THREE SIDES 5 - SHIELDED, WITH EMI FINGER ON FOUR SIDES 6 - SHIELDED, WITH EMI FINGER ON THREE SIDES, LED TAIL STAGGERED 7 - SHIELDED, WITH EMI FINGER ON THREE SIDES, 3 LEG TAIL LED HOUSING MATERIAL: P - PBT POLYESTER N - NYLON POLYESTER L - LCP RIGHT LED COLOR: 0 - NO LED 1 - YELLOW 2 - RED 3 - GREEN 4 - ORANGE 5 - GREEN/YELLOW BI-COLOR LEFT LED COLOR: 0 - NO LED 1 - YELLOW 2 - RED 3 - GREEN 4 - ORANGE 5 - GREEN/YELLOW BI-COLOR 6 7 8 9 - RED/GREEN BI-COLOR GREEN/ORANGE BI-COLOR RED/YELLOW BI-COLOR ORANGE/YELLOW BI-COLOR 6 7 8 9 - RED/GREEN BI-COLOR GREEN/ORANGE BI-COLOR RED/YELLOW BI-COLOR ORANGE/YELLOW BI-COLOR *Please consult EDAC for the availability of the modular or magnetic jack if the part no is created using this ordering guide. www.edac.net SERIES A6X STANDARD RJ45 MAGNETIC JACKS CONTACT EDAC FOR FURTHER INFORMATION ON VARIOUS OTHER CIRCUITS 70 TYPE 16 TYPE CONNECTOR SOLDER SIDE RJ45 CONTACT SIDE CONNECTOR SOLDER SIDE RJ45 CONTACT SIDE 1CT:1CT P1 J1 J4 0.1uF 75 P7 J5 P2 J2 J7 P8 1CT:1CT J8 1CT : 1CT TRANSMIT P1 P3 J3 0.1uF 75 J1 P6 J6 P2 75 OHM 1CT:1CT P4 J4 0.1uF J2 P3 1CT : 1CT RECEIVE P4 75 P5 J3 J5 1CT:1CT P5 P7 J7 0.1uF 75 OHM 75 J6 P6 P8 J8 1000 pF 2 Kv NOTE: 100 BASE-T MAGNETICS P9 1000pF 2 Kv Shield P10 Shield NOTE: GIGABIT ETHERNET (1000 BASE-T) MAGNETICS P1 TYPE: POWER OVER ETHERNET 13 TYPE: POWER OVER ETHERNET 1CT:1CT P2 J1 P5 PW- P3 J2 PW+ 1CT:1CT P4 J3 75? P8 P10 J6 J4 J5 J7 J8 P9 P6 P10 1000pF/2KV P9 P8 75? P7 J8 P6 J7 P5 J6 RXRX P4 P1 J5 P3 4*22nF J4 TX P2 J3 RX+ P1 4*75 OHM J2 TX- RJ45 FRONT VIEW P7 J1 TX+ NOTE: 100 BASE-T MAGNETICS NOTE: 100 BASE-T MAGNETICS CAP 1000pF 2KV SHIELD 32 TYPE CONNECTOR SOLDER SIDE RJ45 CONTACT SIDE 30 TYPE P10 P1 CAP 0.1uF J1 P5 1CT:1CT P2 J1 75 J2 P3 J2 P9 ICT : ICT P4 J3 1CT:1CT P4 J3 75 J6 P8 ICT : ICT J6 P5 P3 J4 1CT:1CT P6 J4 75 J5 P7 J5 P7 ICT : ICT P2 J7 1CT:1CT P8 J7 75 J8 P6 ICT : ICT J8 P9 1000pF 2 KV P1 SHIELD CAP 1000pF 2KV P10 NOTE: GIGABIT ETHERNET (1000 BASE-T) MAGNETICS www.edac.net NOTE: GIGABIT ETHERNET (1000 BASE-T) MAGNETICS
A60-112-300P492 价格&库存
很抱歉,暂时无法提供与“A60-112-300P492”相匹配的价格&库存,您可以联系我们找货
