JED CONNECTOR
1.25mm
Board-to-board connectors
pitch
Feature –––––––––––––––––––––––––
• A compact design to meet today’s needs
This small connector has a 1.25mm pitch dual-in-line
construction at both the mating and printed circuit board sides.
It has a mounting height of only 7.0mm and a thickness of
4.6mm.
• Positive housing lock provides a highly
reliable connection
The high-pressure, double-sided, fork type contacts and a
housing lock feature ensure continuity even when the
connector is subjected to severe vibration or shock.
• Polarized shrouded header
The polarized shrouded header prevents misinsertion or
distortion of the receptacle housing during mating. The rigid
mating between the plug and receptacle guarantees high
reliability during vibration or shock.
This 1.25mm pitch dual-in-line, board-toboard connector. Double-sided, highpressure contacts and a housing locking
feature provide reliable connections.
Specifications –––––––––––––––––––
• Current rating: 1.0A AC, DC
• Voltage rating: 50V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/20m Ω max.
After environmental testing/40m Ω max.
• Insulation resistance: 300M Ω min.
• Withstanding voltage: 500V AC/minute
• Applicable PC board thickness: 0.8 to 1.0mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
Certified LR20812
1
JED
CONNECTOR
Plug ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Top entry type
Circuits
Model No.
Dimensions (mm)
Top entry type Side entry type
B
A
4.6
1.25
A
Q'ty / box
B
8
08P-JED
08PS-JED
3.75
5.95
500
16
16P-JED
16PS-JED
8.75
10.95
500
22
22P-JED
22PS-JED
12.50
14.70
500
Material and Finish
5.3
Contact: Brass, tin-plated(reflow treatment)
Housing: Glass-filled PA 66, UL94V-0
2.0
RoHS compliance
0.30
2.0
Side entry type
B
2.0
4.6
JST
1.25
4.15
2.0
A
Receptacle –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Dimensions (mm)
B
A
Circuits
Model No.
A
B
Q'ty / box
8
08R-JED
3.75
5.95
500
16
16R-JED
8.75
10.95
500
22
22R-JED
12.50
14.70
500
1.25
4.4
Material and Finish
RoHS compliance This product displays (LF)(SN) on a label.
2.0
1.7
0.30
2
2.0
Contact: Phosphor bronze, copper-undercoated, tin-plated(reflow treatment)
JED
CONNECTOR
PC board layout (viewed from soldering side) ––––––––––––––––––––––––––––––––––––––
Plug: top entry type
Receptacle
Plug: side entry type
1.1min.
1.25±0.05
1.1min.
2.0±0.05min.
2.0±0.05
1.3min.
φ0.50 +0.05
4.15min.
(5.85max.)
1.25±0.05
φ0.50 +0.05
Note:
1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline.
Assembly layout ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Top entry type
Side entry type
Daughter board
4.6
4.6
4.15
1.7
7.0
7.0
2.0
Daughter board
2.0
Mother board
2.0
Mother board
1.3
Note: The daughter board must be secured by means other than the connector.
Contact JST for more details.
3
很抱歉,暂时无法提供与“22R-JED(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.800041+1.00683
- 10+4.8060810+0.62037
- 50+4.2545750+0.54918
- 100+3.89564100+0.50285
- 500+3.82561500+0.49381
- 1000+3.764331000+0.48590
- 2000+3.738072000+0.48251
