REVISION AW
DESIGNED & DIMENSIONED IN MILLIMETERS
(INCHES FOR REFERENCE)
LSS-1XX-XX-XX-DV-XX-XX
NO OF POSITIONS
(No OF POS x 0.635[.0250]) +4.750[.1870] REF
LEAD STYLE
-01: 3 mm (SEE TABLE 3)
-02: 6 mm (SEE TABLE 3)
-03: 4 mm (SEE TABLE 3)
(No OF POS -1) x 0.635[.0250]
C
2.69 .106
REF
02
DO NOT
SCALE FROM
THIS PRINT
01
0.20 .008 REF
SEE NOTE 4
0.635 .0250
(TOL NON-ACCUM)
"A"
PLATING SPECIFICATION
-L: 10µ" AU IN CONTACT AREA,
MATTE TIN ON TAIL
(USE C-185-XX-LM)
-F: 3µ" AU IN CONTACT AREA,
MATTE TIN ON TAIL
(USE C-185-XX-FM)
-H: 30µ" AU IN THE CONTACT AREA,
3µ" AU ON TAIL
(USE C-185-XX-H)
*-LM: 10µ" AU IN CONTACT AREA,
ROW SPECIFICATION
MATTE TIN ON TAIL
-DV: DOUBLE VERTICAL
(USE C-185-XX-LM)
*-FM: 3µ" AU IN CONTACT AREA,
MATTE TIN ON TAIL
(USE C-185-XX-FM)
* = FOR EXISTING CUSTOMERS ONLY
C
"B"
REF
0.85 .033 REF
0.71 .028
REF (TYP)
OPTION
-K: POLYIMIDE FILM
(USE K-DOT-.138-.250-.005)
(SEE FIG 2, SHT 2)
-TR: TAPE & REEL (SEE NOTE 8)
(SEE FIG 4, SHT 2)
-FR: FULL REEL QTY. TAPE & REEL
(SEE NOTE 9)
OPTION
-A: ALIGNMENT PIN
(REQUIRED FOR -01 LEAD STYLE;
OPTIONAL FOR -02 & -03)
-LC: LOCKING CLIP
(-02 & -03 LEAD STYLES ONLY)
(USE LC-08-TM-01)
(SEE FIG 3, SHT 2)
(SEE NOTE 6)
-05, -10, 20, -30, -40, -50
(PER ROW)
+0.10
C
+.004
0.87 - 0.07 .034 - .003
(SEE NOTE 5)
+0.04
LSS-XX-01-DV-A
"A"
C
"A" ± .076[.0030]
(No OF POS x 0.635[.0250]) +1.500[.0591]
REF
C
"C" REF
0.10 [.004]
(SEE NOTE 2)
1.10 .043
REF
4.00 .157
REF
C-185-01-XX
0.80 .031
REF (TYP)
C
0.161±0.130 .0063±.0051
SECTION "A"-"A"
SCALE 5 : 1
4.600±0.130 .1811±.0051
C
0.14 .006
REF
C
3 MAX SWAY
(TYP)
NOTES:
+.002
0.67 - 0.10 .026 - .004
(SEE NOTE 5)
FIG 1
LSS-120-01-XX-DV-A SHOWN
1. C REPRESENTS A CRITICAL DIMENSION.
2. BREAKOFF BURR ALLOWANCE .054 [.0021].
3. MINIMUM PUSHOUT FORCE; TERMINALS: .5 LBS, CONTACTS: .5 LB.
4. PIN 01 WILL MATE WITH CONTACT 02 ON MATING CONNECTOR.
5. MEASURE FROM TOP OF VERTICAL WALL.
6. MINIMUM PULL OUT FORCE FOR -LC IS .75 LB.
7. FOR APPLICATIONS REQUIRING TWO OR MORE CONNECTORS PER BOARD,
CONTACT IPG@SAMTEC.COM.
8. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE
PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY
STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
9. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED
ON OPTIONS SELECTED.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
ANGLES
.X:
.3 [.01]
2
.XX: .13 [.005]
.XXX: .051 [.0020]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, COLOR: BLACK
CONTACT: PHOS BRONZE
F:\DWG\MISC\MKTG\LSS-1XX-XX-XX-DV-XX-XX-MKT.SLDDRW
SHEET SCALE: 4:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.635mm TERMINAL/SOCKET COMBO
DWG. NO.
BY: CHAD F
07/01/2002
SHEET 1 OF 2
REVISION AW
FIG 4
FIG 2
-K: POLYIMIDE FILM OPTION
C
"E" 0.50[.020]
C
POS 01
0.36±0.51 .014±.020
"D"
3.5 .14
"B"
"B"
TUBE: PT-1-24-13-09
PLUG: TP-24
"E" =((NO OF POS X 0.635 [.0250]) + 4.750 [.1870])/2) - 1.75 [.0689]
USER DIRECTION OF UN-REELING
POCKET NOT DETAILED
TUBE: PT-1-24-11-09
PLUG: TP-09
SECTION "B"-"B"
SCALE 1.5 : 1
FIG 3
LOAD PARTS WITH PIN #1 IN DIRECTION OF ARROW.
TAPE & REEL
-LC: LOCKING CLIP OPTION
(USE LC-08-TM-01)
(SEE NOTE 6, SHT. 1)
1.3966 .055 REF
PROPRIETARY NOTE
14.2000 .559 REF
(No OF POS x 0.635[.0250]) +1.500[.0600]
SHEET SCALE: 4:1
LC-08-TM-01
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: CHAD F
07/01/2002
SHEET 2 OF 2
LSS-130-02-L-DV-A-K 价格&库存
很抱歉,暂时无法提供与“LSS-130-02-L-DV-A-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 70+37.28865
- 140+33.86690
- 560+30.09451
- 1050+26.99921
- 2520+24.00064
- 4760+21.08671
- 国内价格
- 50+36.69600
- 100+33.38500
- 500+29.63400
- 1000+26.58700
- 国内价格 香港价格
- 1+40.602271+5.25253
- 25+38.0436025+4.92152
- 50+36.1898250+4.68171
- 100+32.92392100+4.25921
- 500+30.99292500+4.00941
- 国内价格
- 1+41.90400
- 10+40.75920
- 24+40.00320
