20P-JMDSS-G-1-TF
20P-JMDSS-G-1-TF
    JST
    20P-JMDSS-G-1-TF
20P-JMDSS-G-1-TF 数据手册
JMD CONNECTOR 0.5mm Emboss Tape Board-to-board connectors (.020") pitch Features–––––––––––––––––––––––– • Smooth connection Thanks to the cantilever type contacts, mating is very smooth. • Distortion preventive construction Box-shaped plug housing has guide ribs on both ends, which prevents distortion. • Wide range of circuits No.of circuits available are from 20 to 100, every 10 circuiits. • Embossed taping for automatic mounting This connector is supplied in embossed tape packaging, for mounting by automatic placement machines. Specifications ––––––––––––––––––– • Current rating: 0.5A AC,DC • Voltage rating: 50V AC,DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/50m Ω max. After environmental testing/100m Ω max. • Insulation resistance: 50M Ω min. • Withstanding voltage: 100V AC/minute * Contact JST if Lead-Free product is required. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 375 JMD CONNECTOR Plug –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Top entry type Side entry type C B A 0.5 (.020) 2.3(.091) 0.2(.008) 0.2(.008) 2.3 (.091) 4.8(.189) C 0.5 (.020) A B 1.15(.045) Model No. Circuits Circuits Dimensions mm(in.) ModelTop No.entry type Top entry(.177") type 4.5mm 5.0mm (.197") 1.3(.051) Dimensions mm(in.) A B C C A B Side entry type Side entry type 6.0mm (.236") Q'ty / Q´ty reel/ reel 20 20P-JMDSS-G-1-TF – 20PS-JMDSS-G-1-TF 4.5(.177) 9.1( .358) 5.7( .224) 1,500 30 – 30P5.0-JMDSS-G-1-TF – 30PS-JMDSS-G-1-TF 7.0(.276) 11.6( .457) 8.2( .323) 1,500 40 40P-JMDSS-G-1-TF 40P5.0-JMDSS-G-1-TF – 40PS-JMDSS-G-1-TF 9.5(.374) 14.1( .555) 10.7( .421) 1,500 50 50P-JMDSS-G-1-TF – 50P6.0-JMDSS-G-1-TF 50PS-JMDSS-G-1-TF 12.0(.472) 16.6( .654) 13.2( .520) 1,500 60 60P-JMDSS-G-1-TF – 60P6.0-JMDSS-G-1-TF 60PS-JMDSS-G-1-TF 14.5(.571) 19.1( .752) 15.7( .618) 1,500 70 70P-JMDSS-G-1-TF – 70P6.0-JMDSS-G-1-TF 70PS-JMDSS-G-1-TF 17.0(.669) 21.6( .850) 18.2( .717) 1,500 80 80P-JMDSS-G-1-TF – – 80PS-JMDSS-G-1-TF 19.5(.768) 24.1( .949) 20.7( .815) 1,500 100 100P-JMDSS-G-1-TF – – 100PS-JMDSS-G-1-TF 24.5(.965) 29.1(1.146) 25.7(1.012) 1,500 – Material and Finish Contact: Phosphor bronze, gold-plated Housing: Polyamide, UL94V-0 Solder tab: Brass, copper-undercoated, tin/lead-plated Note: The products listed above are supplied on embossed-tape. Receptacle ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 0.2(.008) 3.1 (.122) C 2.3 (.091) 0.5 (.020) A B 376 1.7 (.067) Dimensions mm(in.) Model No. A B C Q'ty / reel 20 20R-JMDSS-G-1-TF 4.5(.177) 9.1( .358) 5.7( .224) 1,500 30 30R-JMDSS-G-1-TF 7.0(.276) 11.6( .457) 8.2( .323) 1,500 40 40R-JMDSS-G-1-TF 9.5(.374) 14.1( .555) 10.7( .421) 1,500 50 50R-JMDSS-G-1-TF 12.0(.472) 16.6( .654) 13.2( .520) 1,500 60 60R-JMDSS-G-1-TF 14.5(.571) 19.1( .752) 15.7( .618) 1,500 70 70R-JMDSS-G-1-TF 17.0(.669) 21.6( .850) 18.2( .717) 1,500 80 80R-JMDSS-G-1-TF 19.5(.768) 24.1( .949) 20.7( .815) 1,500 100 100R-JMDSS-G-1-TF 24.5(.965) 29.1(1.146) 25.7(1.012) 1,500 Material and Finish Contact: Phosphor bronze, gold-plated Housing: Polyamide, UL94V-0 Solder tab: Brass, copper-undercoated, tin/lead-plated Note: The products listed above are supplied on embossed-tape. JMD CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– 380 ± 2.0(14.961 ±.079)dia. Feeding direction 1.55±0.05 (.061±.002)dia. 20 to 50 circuits W±0.3(.012) 12.0±0.1 (.472±.004) S±0.1(.004) 12.0±0.1 (.472±.004) 12.0±0.1 (.472±.004) Dimensions mm(in.) F S W W1 Q'ty / reel 20 7.5( .295) — 16.0( .630) 17.5( .689) 1,500 30 11.5( .453) — 24.0( .945) 25.5(1.004) 1,500 40 11.5( .453) — 24.0( .945) 25.5(1.004) 1,500 50 11.5( .453) — 24.0( .945) 25.5(1.004) 1,500 60 14.2( .559) 28.4(1.118) 32.0(1.260) 32.0(1.260) 1,500 70 14.2( .559) 28.4(1.118) 32.0(1.260) 32.0(1.260) 1,500 80 20.2( .795) 40.4(1.591) 44.0(1.732) 44.0(1.732) 1,500 100 20.2( .795) 40.4(1.591) 44.0(1.732) 44.0(1.732) 1,500 PC board layout (viewed from component side) –––––– 0.5±0.03 (.020±.001) 0.3±0.05 (.012±.002) Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. Note: 2. Specifications are subject to change without prior notice. Assembly layout––––––––––––––––––––– Top entry type 1.55 0.85 (.061) (.033) 4.3(.169) 1.4(.055) 0.5(.020) 2.9(.114) 5.8(.228)[ Receptacle] 5.6(.220) Plug: top entry type Receptacle 0.85 1.55 (.033) (.061) 0.5±0.03 (.020±.001) 0.3±0.05 (.012±.002) ( )P-JMDSS-G-1-TF : 4.5(.177) ( )P5.0-JMDSS-G-1-TF : 5.0(.197) ( )P6.0-JMDSS-G-1-TF : 6.0(.236) Circuits 1.55±0.05 (.061±.002)dia. 4±0.1 1.65±0.1 (.157±.004) (.065±.004) Feeding direction S±0.1(.004) 60 to 100 circuits W±0.3(.012) 1.55±0.05 (.061±.002)dia. Carrier tape F±0.1(.004) 2.0±0.1 (.079±.004) F±0.1(.004) 60 to 100 circuits 4±0.1 (.157±.004) 1.75±0.1 (.069±.004) Feeding direction Cover tape Carrier tape Cover tape W±0.3(.012) 12.0±0.1 (.472±.004) 1.75±0.1 (.069±.004) 20 to 50 circuits 4±0.1 1.65±0.1 (.157±.004) (.065±.004) 1.75±0.1 (.069±.004) Feding direction F±0.1(.004) Feeding direction Plug: side entry type F±0.1(.004) 4±0.1 2.0±0.1 (.157±.004) (.079±.004) 1.55±0.05 (.061±.002)dia. 1.75±0.1 (.069±.004) Plug: top entry type Receptacle Leader part 100(3.937)min. The end part Connector 160(6.299)min. mounting part 400(15.748)min. 2.0± 0.5 (.079± .020) W1 +2.5 -1.0 ( +.098 -.039) Cover tape leader W±0.3(.012) [13(.512)dia.] Feeding direction Carrier tape Side entry type Plug: side entry type 1.35 (.053) 5.6(.220) 3.05(.120) 1.35 (.053) 1.4 (.055) 2.6(.102) 4.8(.189) Note: 1. Tolerances are non-cumulative: ±0.03mm (±.001") for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 377
20P-JMDSS-G-1-TF 价格&库存
很抱歉,暂时无法提供与“20P-JMDSS-G-1-TF”相匹配的价格&库存,您可以联系我们找货
20P-JMDSS-G-1-TF
  • 1500+6.472571500+0.84113
  • 3000+6.163713000+0.80099
  • 4500+5.989984500+0.77842
  • 7500+5.778107500+0.75088
  • 10500+5.6427110500+0.73329
  • 15000+5.5026315000+0.71508
库存:10120
20P-JMDSS-G-1-TF
  • 1+10.838681+1.40852
  • 10+9.2187410+1.19800
  • 25+8.6440825+1.12332
  • 50+8.2297250+1.06948
  • 100+7.83678100+1.01841
  • 250+7.34532250+0.95455
  • 500+6.99437500+0.90894
库存:10120
