560-003-000-411
560-003-000-411
560-003-000-411 数据手册
SERIES 560 Wire to Wire / Wire to Board 2.5mm Pitch ͻ ͻ ͻ ͻ ͻ ͻ ͻ ͻ ͻ Specifications: No. of Positions Pitch Rated Voltage Rated Current Withstanding Voltage Contact Resistance Insulation Resistance Temperature Range PCB Thickness Crimp Contact: 2, 3, 5 2.5mm 250V 3A max 1000V AC (rms) 15 mɏ max 1000 MɏŵŝŶͬ͘ϱϬϬs Housing Contact Housing PCB Header Contact Contact Plating Wire & Housing Seals Waterproofing Cap PBT, UL 94V-0 Phosphor Bronze PBT with Glass, UL 94V-0 Brass Tin Plating Silicone Rubber PBT, UL 94V-0 Waterproofing Cap: Part No. 565-200-100 Part No 565-290-731 565-290-711 Male Contact (Pin) AWG# Ins. Dia. 20-22 Max. Ø1.7 22-28 Max. Ø1.6 Part No 565-290-741 565-290-721 Female Contact (Socket) AWG# Ins. Dia. 20-22 Max. Ø1.7 22-28 Max. Ø1.6 Pcs/Reel 8,000 10,000 **Wire seals, housing seals and retainers are already pre-assembled in the connector. Rear Gasket (Wire Seal): Applicable Contact 565-290-711 565-290-721 565-290-731 565-290-741 Wire O.D. Ø1.00 to Ø1.30 Ø1.30 to Ø1.70 Color Yellow Orange Assembly Layout Ordering Code: Page 1 28.40 Double Latch 20.85 SERIES: 560, WIRE TO WIRE WIRE TO BOARD NO. OF CONTACTS: 002 - 2 CONTACTS 003 - 3 CONTACTS 005 - 5 CONTACTS CONTACT CODE: 000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS) 420 - BOARD MOUNT CONTACTS STYLE: 101 - WHITE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 301 - BLUE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 501 - ORANGE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 110 - WHITE MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 310 - BLUE MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 510 - ORANGE MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 111 - WHITE MALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 311 - BLUE MALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 511 - ORANGE MALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 210 - WHITE FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 410 - BLUE FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 610 - ORANGE FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 211 - WHITE FEMALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 411 - BLUE FEMALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 611 - ORANGE FEMALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 www.edac.net Pcs/Reel 8,000 8,000 **Crimp Contacts are also available in strips of 60pcs. Contact EDAC for more information. -40°C to +105°C 1.6mm Materials: Crimp & Poke 2.5mm Pitch, Rated Current: 3A max Fully Waterproof with Double Latch Solution Available in Wire-to-Wire and Wire-to-Board Options Seals Preassembled into Housing; No External Sealing Required available in 2, 3, or 5 Positions True Crimp and Poke Solution Waterproofing Cap available to Cover unused Positions Internal Polarization to Prevent Mismating Available with wire already installed Waterproof Grade IP67 Certified SERIES 560 Wire to Wire / Wire to Board 2.5mm Pitch Male Housing: Female Housing: PCB Header 560-002-000-XXX 560-002-000-XXX 560-002-420-XXX 560-003-000-XXX 560-003-000-XXX 560-003-420-XXX 560-005-000-XXX 560-005-000-XXX 560-005-420-XXX Male Housing: Ø Wire Insulation Ø1.00 to Ø1.30 Ø1.30 to Ø1.70 Housing Color White Blue White Blue Female Housing: XXX 110 310 111 311 Ø Wire Insulation Ø1.00 to Ø1.30 Ø1.30 to Ø1.70 Housing Color White Blue White Blue PCB Header: XXX 210 410 211 411 Housing Color White Blue XXX 101 301 Waterproofing Cap NOTE: Waterproofing Cap is installed at the wire seal end to cover the unused holes. Page 2 www.edac.net SERIES 560 Wire to Wire / Wire to Board 2.5mm Pitch Recommended PCB Layout www.edac.net Page 3
560-003-000-411 价格&库存
很抱歉,暂时无法提供与“560-003-000-411”相匹配的价格&库存,您可以联系我们找货
  • 1+8.834191+1.14434
  • 10+7.5117210+0.97303
  • 25+7.0392925+0.91184
  • 50+6.7027250+0.86824
  • 100+6.38305100+0.82683
  • 300+5.90640300+0.76509
  • 500+5.69713500+0.73798
  • 1000+5.425101000+0.70274
  • 2500+5.085452500+0.65875
库存:490
