HRP-03-S
HRP-03-S
    JST
    P=2.5mm
    HRP-03-S
HRP-03-S 数据手册
HR CONNECTOR Radial RadialTape Tape 2.5 2.5 mm mm pitch/Disconnectable pitch/Disconnectable Crimp Crimp style style connectors connectors HR HR CONNECTOR CONNECTOR JS Specifications • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #26 to #22 • Applicable PC board thickness: 0.8 to 1.6 mm T5 * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. ● Thin design ● High reliability ● Interchangeability of wire side connector with EH connector and HR connector (IDC socket) Standards ® ® ® Recognized E60389 ® PC board layout and Assembly layout ® 2.5 min. 3.8 +0.1 (7.5) φ0.9  0 2.5 min. 0.6 (11.3) 2.5±0.05 +0.1 φ0.9 0 (13.5) 4.2 2.2 min. 2.5±0.05 Side entry type 4.1 6.7 min. Top entry type Top entry type on radial-tape +0.1 φ0.9 0 (11.8) 2.5 min. 2.2 min. 4.4 2.5±0.05 Note: 1 . The above figure is the figure viewed from the connector soldering side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimension differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 1 HR CONNECTOR HRコネクタ表-1 Contact Applicable wire Model No. SHR-001T-P0.6 8.2 AWG # 0.13~0.33 26~22 Insulation O.D. (mm) Q'ty/ reel 1.3~1.7 9,000 HR CONNECTOR Material and Finish 4.85 2.85 0.8 mm2 1.3 Phosphor bronze, tin-plated (reflow treatment) 2.1 RoHS2 compliance Contact 1.9 Crimping machine Crimp applicator SHR-001T-P0.6 AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SHR/MR-001-06 APLMK SHR/MR001-06 Note: Contact JST for fully automatic crimping applicator. HRコネクタ表-2 Housing No. of circuits 2 3 4 2.5 2.5 5 A 4.1 6 7 8 9 10.3 10 1 11 12 13 Model No. HRP-02-S HRP-03-S HRP-04-S HRP-05-S HRP-06-S HRP-07-S HRP-08-S HRP-09-S HRP-10-S HRP-11-S HRP-12-S HRP-13-S Dimensions (mm) A B Q'ty/ bag 2.5 7.5 2,000 5.0 10.0 2,000 7.5 12.5 1,000 10.0 15.0 1,000 12.5 17.5 1,000 15.0 20.0 500 17.5 22.5 500 20.0 25.0 500 22.5 27.5 500 25.0 30.0 500 27.5 32.5 500 30.0 35.0 250 Material and Finish JST PA 66, UL94V-0, natural (white) B RoHS2 compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. HRP-02-SS...natural (white) K...black R...red TR...tomato red E...blue L...lemon yellow M...green N...brown O...orange P...purple PK...pink LE...light blue Y...yellow FY...vivid yellow H...gray Shrouded header The shrouded headers are interchangeable with those of the EH crimp style and HR insulation displacement connectors. 2
HRP-03-S 价格&库存
很抱歉,暂时无法提供与“HRP-03-S”相匹配的价格&库存,您可以联系我们找货
HRP-03-S
    • 1+0.363951+0.04724
    • 500+0.33087500+0.04294
    • 1000+0.272971000+0.03543
    • 4000+0.239884000+0.03114
    • 5000+0.231615000+0.03006
    • 10000+0.2316110000+0.03006
    • 30000+0.2233430000+0.02899
    库存:814
    HRP-03-S
      • 1000+0.25300
      库存:29886
      HRP-03-S
        • 1+0.62150
        • 15000+0.46640
        • 30000+0.31130
        库存:1
        HRP-03-S
          • 1+0.487591+0.06328
          • 10+0.4092310+0.05311
          • 50+0.3395750+0.04407
          • 100+0.28733100+0.03729
          • 500+0.26121500+0.03390
          • 1000+0.243801000+0.03164
          • 2000+0.243802000+0.03164
          库存:14
          HRP-03-S
            • 1+0.496301+0.06441
            • 10+0.4179410+0.05424
            • 1000+0.252501000+0.03277
            库存:14
            HRP-03-S
            • 2000+0.371112000+0.04817
            HRP-03-S
