567 SERIES
WATERPROOF WIRE TO WIRE & CONNECTORS
Features:
5.0mm x 5.9mm pitch, rated current: 8A max
Splashproof solution available in 1, 2, 3, 4, 6, or 9 positions
Available in wire to wire options
True crimp and poke solution with various sized wire seals available
Available with wire already installed
Splash Proof Grade: IP52 (JIS C0920) Certified
Specifications:
No. of Positions
1, 2, 3, 4, 6, or 9
Pitch
5.0 mm x 5.9 mm
Rated Voltage
300 V
Rated Current
8 amps maximum
Dielectric Withstanding Voltage
1700 V AC (rms)
Contact Resistance
10 millihoms maximum
Insulation Resistance
1000 megaohms minimum/DC 500 V
Operating Temperature
-40°C to +105°C
Ordering Code:
Crimp Contact:
567-002-000-100
Male Contact (Pin)
SERIES:
567, WIRE TO WIRE
NO. OF CONTACTS:
001 - 1 CONTACT
002 - 2 CONTACTS
003 - 3 CONTACTS
004 - 4 CONTACTS
006 - 6 CONTACTS
009 - 9 CONTACTS
Part No (Material)
AWG#
Ins. Dia.
Pcs/Reel
Part No (Material)
AWG#
Ins. Dia.
Pcs/Reel
570-290-751 (Brass)
14
Max. Ø3.1
4,000
570-290-761 (Brass)
14
Max. Ø3.1
4,000
570-291-731 (Ph. Brz.)
20-16
Max. Ø3.1
4,000
570-291-741 (Ph. Brz.)
20-16
Max. Ø3.1
4,000
570-290-731 (Brass)
20-16
Max. Ø3.1
4,000
570-290-741 (Brass)
20-16
Max. Ø3.1
4,000
4,000
570-291-721 (Ph. Brz.)
22-20
Max. Ø2.7
4,000
570-290-721 (Brass)
22-20
Max. Ø2.7
4,000
570-290-711 (Brass)
CONTACT CODE:
000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS)
Female Contact (Socket)
22-20
Max. Ø2.7
STYLE:
310 - WHITE MALE HOUSING FOR CRIMP CONTACTS
410 - WHITE FEMALE HOUSING FOR CRIMP CONTACTS
Materials:
Housing
PBT, UL 94V-0
Contact
Ph. Brz. or Brass
Contact Plating
Tin Plating
Wire & Housing Seals
Silicone Rubber
Wire Seal:
Assembly Layout:
Part No.
Wire O.D.
Color
AWG#
Ø Dia.
Height
570-260-001
Ø1.7~Ø2.1
Black
22
Ø 5.0
6.0
570-260-002
Ø2.1~Ø2.7
Light Blue
22-20
Ø 5.0
6.0
570-260-003
Ø2.1~Ø2.7
Blue
22-20
Ø 5.0
6.7
570-260-004
Ø2.7~Ø3.1
Brown
20-14
Ø 4.9
5.0
570-260-002
570-260-001
www.edac.net
570-260-004
570-260-003
customerservice@edac.net
567 SERIES
Male Housing:
567-001-000-310
567-002-000-310
567-003-000-310
567-004-000-310
567-006-000-310
567-009-000-310
567-001-000-410
567-002-000-410
567-003-000-410
567-004-000-410
567-006-000-410
567-009-000-410
Female Housing:
www.edac.net
很抱歉,暂时无法提供与“567-001-000-410”相匹配的价格&库存,您可以联系我们找货
