CC69L-1620-01-T-SP
CC69L-1620-01-T-SP
    SAMTEC(申泰)
CC69L-1620-01-T-SP 数据手册
REVISION AD CC69X-XXXX-01-X-XX ALL DIMENSIONS ARE REFERENCE (SEE XC-169-XX-XX-X-XX FOR CONTROLLING PRINT) DO NOT SCALE FROM THIS PRINT MATERIAL SPECIFICATION -SP: STANDARD POWER *-HP: HIGH POWER SUPPLIED -L: LOOSE -R: REEL LEAD STYLE -2024 (20-24 AWG) -1620 (16-20 AWG) -2426 (24-26 AWG)(PTFE) -1618 (16-18 AWG) (PTFE) .080 SQ PLATING -T: TIN -L: 10μ" GOLD ON CONTACT, TIN ON TAIL -S: 30μ" GOLD ON CONTACT, TIN ON TAIL OPTION (INSULATION THICKNESS) -01 (SEE PP-C-169-XX-XX-X FOR PLATING INSTRUCTIONS) * = EXISTING CUSTOMERS ONLY AS OF REV P .617 .055 .070 .170 .757 "B" "A" .090 "B" "J" .388 "H"±.001 .272 "A" .050 .150 .075 .033 .105 .4250 FIG 1 (CC69X-XXXX-01-X-XX SHOWN) "B" 'C' "F" SECTION "A"-"A" SCALE 10 : 1 NOTES: 1. PLATED XC-169 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN ON SAMTEC REEL WITH VIEWPORTS,LABELED CC69R WITH APPROPRIATE PLATING CALLOUT AND LABEL PLACED AS SHOWN. 2. MAXIMUM No OF SPLICES PER REEL: 2. 3. SPLICES ARE NOT TO BE CONNECTED. 4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL. 5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS. 6. ALLOWABLE INTERLEAF SPLICES PER REEL: 3. 7. SECURELY CONNECT INTERLEAF SPLICE. 8. OUTER WRAP SHALL RECEIVE PROTECTIVE REEL BAND PER BELOW: RB-24-1.00-P. 9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT. 10. QTY PER REEL: 4,000 +100/-0 PCS. "C" R"D" R"G" (TYP 4 PLCS) "A" (SEE TABLE 1) .2125 .062 (TYP) "E" DETAIL 'C' SCALE 30 : 1 SECTION "B"-"B" SCALE 10 : 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS MATERIAL: ANGLES DO NOT SCALE DRAWING -SP: PHOS BRONZE -HP: HIGH COPPER ALLOY THICKNESS: .0100 F:\DWG\MISC\MKTG\CC69X-XXXX-01-X-XX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .165 IPBD CONTACT CC69X-XXXX-01-X-XX BY: BRATCHER 10/7/04 SHEET 1 OF 2 REVISION AD "L" "M" "K" "S" MAX (TAB LENGTH) "R" MAX (VESTIGE ALLOWANCE) INSULATOR STRIP LENGTH WIRE CRIMP SCALE 16 : 1 FIG 2 CARRIER TAB SPECIFCATION SCALE 4 : 1 RECOMENDED PROCESSING LABEL UP UNWINDING DIRECTION "P" HUB 5.50 .50 "Q" CARRIER OPPOSITE TO LABEL SIDE * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. "N" DO NOT SCALE DRAWING FIG 3 SHEET SCALE: 3:1 REEL SPECIFICATIONS F:\DWG\MISC\MKTG\CC69X-XXXX-01-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .165 IPBD CONTACT CC69X-XXXX-01-X-XX BY: BRATCHER 10/7/04 SHEET 2 OF 2
CC69L-1620-01-T-SP 价格&库存
很抱歉,暂时无法提供与“CC69L-1620-01-T-SP”相匹配的价格&库存,您可以联系我们找货
