Crimp
1.2mm
ACH CONNECTOR
Emboss Tape
Disconnectable Crimp style connectors
(.047") pitch
Features ––––––––––––––––––––––––
• Top entry but side feed type
Wires come out from horizontal direction of connector
a Low profile {height: 1.4mm (.055")}
Socket is mated with header from vertical direction of connector
a Excellent workability
• Connector for DC power supply
In spite of compact and low profile type connector, rated current
is 2A for both 2-circuit and 3-circuit with wire size AWG #28.
• Corresponding to sucking nozzle of pick and
place machine
A sucking area on bottom of inside header is available.
This ACH connector is compact and low
profile type, height: 1.4mm (.055") and
width 4.3mm (.169"), 1.2mm (.047") pitch
wire-to-board connector.
Specifications –––––––––––––––––––
PU
SH
3
3
• Current rating: 2A AC, DC (AWG #28)
• Voltage rating: 50V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
100M Ω min.
• Withstanding voltage: 500V AC/minute
• Applicable wire: AWG #30 to #28
Insulation O.D./0.5 to 0.63mm (.020" to .025")
* Contact JST if Lead-Free product is required.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
0 Recognized E60389
18
ACH
CONNECTOR
Contact –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Model No.
2.95(.116)
1.45(.057)
SACH-003G-P0.2
1.2(.047)
0.7(.028)
Applicable wire
mm2
AWG#
0.05 to 0.08
30 to 28
Insulation O.D. mm(in.) Q'ty / reel
0.5 to 0.63(.020 to .025)
30,000
0.8(.031)
Material and Finish
0.6(.024)
Copper alloy, nickel-undercoated, gold-plated
Housing –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
B
Q'ty
/ bag
ACHR-02V-S
1.2(.047)
2.6(.102)
1,000
ACHR-03V-S
2.4(.094)
3.8(.150)
1,000
Model No.
2
3
PUSH
3
B
A
1.2(.047)
Circuit No.1 mark
Material
PBT, UL94V-0, natural (white)
0.3(.012)
1.2(.047)
3.5(.138)
Dimensions mm(in.)
A
Circuits
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
ACHR-02V-00S…natural (white)
K…black
Shrouded header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Circuits
Model No.
Q'ty / reel
2
BM02B-ACHSS-GAN-TF
BM03B-ACHSS-GAN-TF
4,500
Circuit No.1 mark
3
4,500
Material and Finish
B
A
1.2(.047)
Contact: Copper alloy, nickel-undercoated, gold-plated (nickel-stripe)
Housing: Heat resisting resin, UL94V-0, natural (ivory)
Solder tab: Copper alloy, copper-undercoated, tin-plated
3
1.4(.055)
4.3(.169)
ex.
BM02B-ACHSS-GAN-TFS…natural (ivory)
19
ACH
CONNECTOR
Taping specifications ––––––––––––––––––––––––––––––––––––––––––––––––––––––
Feeding direction
380±2.0(14.961±.079)dia.
Feeding direction
[13(.512)dia.]
2.5 +.098
(-.039 )
W1+-1.0
Carrier tape
Cover tape leader
Leader part
100(3.937)min.
The end part Connector
160(6.299)min. mounting part 400(15.748)min.
2.0±0.5(.079±.020)
F±0.1(.004)
8.0±0.1
(.315±.004)
Circuits
Dimensions mm(in.)
F
W
Reel dimensions mm(in.)
W1
W±0.3(.012)
2.0±0.1 1.55±0.05
(.079±.004) (.061±.002)dia.
1.75±0.1
(.069±.004)
Feeding direction
4.0±0.1
(.157±.004)
Cover tape
Carrier tape
Q'ty /
reel
2
5.5(.217)
12.0(.472)
13.5(.531)
4,500
3
7.5(.295)
16.0(.630)
17.5(.689)
4,500
Note:
1. Specifications conform to JIS C 0806. The tape width, connector loading
recess square hole dimensions, etc. are determined by the number of circuits
and external shape of the connector to be loaded.
2. Specifications are subject to change without prior notice.
0.8±0.05(.031±.002)
3.75±0.05(.148±.002)
0.6(.024)min.
0.7(.028) min.
0.85(.033) min.
Note: 1. Tolerances are non-cumulative: ±0.05mm (±.002") for all centers.
Note: 2. The dimensions above should serve as a guideline. Contact JST for details.
1.4(.055)
0.8±0.05(.031±.002)
Header outline
1.2±0.05
(.047±.002)
2 circuits: 1.2±0.05
(.047±.002)
3 circuits: 2.4±0.05
(.094±.002)
PC board layout (viewed from component side) and Assembly layout ––––––––––––––––––
ACH
CONNECTOR
Applicator for the semi-automatic press AP-K2N –––––––––––––––––––––––––––––––
Contact
SACH-003G-P0.2
Crimp applicator MKS-L-10-3
with safety cover
without safety cover
APLMK SACH003-02
APLNC SACH003-02
Compact crimp applicator MKS-LS
with safety cover
Strip-crimp applicator MKS-SC
with safety cover
21
MINI-SACH-003G-P0.2 价格&库存
很抱歉,暂时无法提供与“MINI-SACH-003G-P0.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+2.422241000+0.31489
- 2000+2.306522000+0.29984
- 3000+2.241463000+0.29139
- 5000+2.162115000+0.28107
- 7000+2.111377000+0.27447
- 10000+2.0589310000+0.26766
- 国内价格 香港价格
- 1+3.970811+0.51620
- 10+3.3538410+0.43599
- 25+3.1424925+0.40852
- 50+2.9941250+0.38923
- 100+2.85023100+0.37052
- 250+2.67141250+0.34728
- 500+2.54377500+0.33069
