WATERPROOF CONNECTORS
www.edac.net
Waterproof D-Sub Connectors
The EDAC D-Seal series of IP67 rated waterproof D-Subminiature
connectors are available in both standard and high density
packages. Plug & receptacles in 9, 15, 25, 26 and 44 pin versions
are available as well as high power combo configurations. Vertical
and right angle footprints, with a variety of termination styles,
contact plating thicknesses, and mounting options are available. A
solid performer in ruggedized applications and harsh environments.
Features
• Standard and high density plug and receptacles in 9, 15, 25, 26 and 44
contact pin sizes
• Signal along with high power contacts up to 40 amps combined in
one connector
• Plug shell indents provide grounding and additional mating retention
• Mounting options for panel mount or connector mating include threaded
inserts and threaded standoffs
• Epoxy sealed by special process providing zero ingress, no wicking up
leads and a smooth molded finish with no air bubbles. Combined with
solid O-ring seal to panel
• Degree of Protection: IP67 as per IEC60529
www.edac.net
Series
No. of
Contacts
Plating
Options
No. of
Contact
Codes &
Density
Ins. Color
Options
Shell Plating
Options
Flange Mtg.
Options
627W/628W
9-25
Flash30u” gold
4 Std.
1
1
3
629W/630W
9-25
Flash30u” gold
4 Std
1
1
3
633W/634W
15-44
Flash30u” gold
3 High
1
1
1
637W/638W
15-44
Flash-
3 High
1
1
1
M/F
Widest range of
options available to
meet all design
requirements
Superior IP67
Waterproof solution
that withstands
harsh envrionments
Waterproof Power Combo D-Sub Connectors
Series
No. of
Contacts
Plating
Options
No. of
Contact
Codes &
Density
Ins. Color
Options
Shell Plating
Options
Flange Mtg.
Options
M/F
Power / Signal
627WC/628WC
1-5 / 0-20
Flash30u” gold
12 Std.
1
2
4
629WC/630WC
1-5 / 0-20
Flash30u” gold
12 Std.
1
2
6
For More Information
www.edac.net
Waterproof USB Connectors
Waterproof panel mount USB connectors Type A and B standard
and micro are available offering IP67 grade protection. Quarter turn
twist and lock bayonet style system offers easy mating and ultra
secure connections. IP67 Waterproof board mount USB
connectors feature full epoxy sealing of the contacts and an O-ring
seal to the panel.
Features
• Standard USB Type A, Micro USB, Mini USB & bayonet
style are available
• 1.2Mbps or 480Mbps communication speeds
• 480Mbps communication speed compatible with
USB 2.0 standard
• Compatible with asynchronous and isochronous data
transfer methods
• Silicone rubber seals for tight seal to panel
• Bayonet locking system for safe mating under severe
vibration or shock conditions
• Micro USB board mount and type C available with all
rated IP 67
www.edac.net
Series
No. of
Contacts
Plating
Contact Codes
Ins. Color
Type
690W
4-5
Flash - 30u”
RA & Cable End
PBT/LCP
A 2.0/Mini/Micro
Solid waterproof
connection with
superior shock &
vibration resistance.
Built to withstand the
most harsh
envrionments.
www.edac.net
Waterproof HDMI Connectors
E-seal waterproof HDMI connectors follow industry standards and
are available with a quarter turn, twist and lock, bayonet locking
system offering easy mating and an ultra secure connection. Fully
sealed on the back end with an O-ring seal to the panel insures no
water ingress. These IP67 rated connectors are fully submersible
and deliver high speed video transmissions resulting in very high
resolution images.
Features
Plating options from gold flash to 30u" gold plating
Quarter turn, twist and lock, bayonet style locking mechanism
Silicone rubber seals and fully potted terminals
Hot pluggable
Synchronous or asynchronous high speed data transmissions
www.edac.net
Series
No. of
Contacts
Plating
Options
Contact Codes
Ins. Material
Type
694W
38
Flash-30u”
Cable End
LCP
A
Premium IP67
connector with
secure locking
mechanism
IP67 waterproof
connection with
superior shock &
vibration resistance!
www.edac.net
Waterproof Wire to Wire & Wire to Board
The EDAC E-Inline family of waterproof plug and socket
connectors provides a reliable interconnect solution in harsh
environments. Single or double latch insulator designs insure
superior shock and vibration resistance. A variety of styles are
available for different wire gauge applications. These utilize simple
crimp and poke contacts. Optional contact plugs are available for
use when all contact positions are not required. Additional
contacts/wires can then be added in the field.
Features
• Rated current from 3 to 10 Amps for use with wire sizes
from 28 to 14 AWG
• 560 and 572 series offer double latch solution
• Available in wire-to-wire and wire-to-board options
• True crimp and poke solution
• Internal polarization to prevent mismating
• Available with wire already installed
• Waterproof grade IP52 and IP67 certified
www.edac.net
Waterproof Wire to Wire & Wire to Board Connectors
Series
No. of
Contacts
Pitch
560
2, 3
and 5
2.5mm
3 amps
565
2, 3
and 5
2.5mm
3 amps
566
2, 3, 4
and 6
2.0mm
2 amps
Single
Y
Y
IP67
567
2, 3, 4, 6
and 9
5.0mm X
5.9mm
8 amps
Single
Y
N
IP52
568
1
N/A
12 amps
Single
Y
N
IP52
570
1, 2
and 3
5.8mm
10 amps
Single
Y
N
IP67
572
1, 2
and 3
5.8mm
10 amps
Double
Y
N
IP67
Current Latch Type
Rating
Polarized
Pre-Installed
Seals
WP Grade
Double
Y
Y
IP67
Single
Y
Y
IP67
Premium Waterproof
wire to wire or wire
to board solution
Optional Port Plugs
allow circuits to be
added in the field
www.edac.net
customerservice@edac.net
Tel: +1 416 754 3322
Established in 1966, EDAC soon became a world
leader in providing connectors for Card Edge and
Rack & Panel applications. Since then, we have
expanded our product offering to include one of
the widest ranges of interconnect solutions in the
world. Products include D-Sub, Modular Jacks
RJ45, USB, HDMI, Inline Plug & Socket, Headers,
Waterproof Connectors and Custom Solutions.
Our dedicated teams of engineering, customer
service, field support, and global distribution
partners allow EDAC the opportunity to support
many unique applications globally.
www.edac.net
Connect with Us . . . Experience Makes the Difference
很抱歉,暂时无法提供与“565-290-711P60”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+70.598651+9.15093
- 10+59.9683510+7.77304
- 25+56.2103425+7.28593
- 50+53.5241050+6.93775
- 100+50.96894100+6.60655
- 250+47.77930250+6.19311
- 500+45.50004500+5.89768
- 1000+43.330721000+5.61649
