565-290-731
565-290-731
565-290-731 数据手册
WATERPROOF CONNECTORS www.edac.net Waterproof D-Sub Connectors The EDAC D-Seal series of IP67 rated waterproof D-Subminiature connectors are available in both standard and high density packages. Plug & receptacles in 9, 15, 25, 26 and 44 pin versions are available as well as high power combo configurations. Vertical and right angle footprints, with a variety of termination styles, contact plating thicknesses, and mounting options are available. A solid performer in ruggedized applications and harsh environments. Features • Standard and high density plug and receptacles in 9, 15, 25, 26 and 44 contact pin sizes • Signal along with high power contacts up to 40 amps combined in one connector • Plug shell indents provide grounding and additional mating retention • Mounting options for panel mount or connector mating include threaded inserts and threaded standoffs • Epoxy sealed by special process providing zero ingress, no wicking up leads and a smooth molded finish with no air bubbles. Combined with solid O-ring seal to panel • Degree of Protection: IP67 as per IEC60529 www.edac.net Waterproof D-Sub Connectors Series No. of Contacts Plating Options No. of Contact Codes & Density Ins. Color Options Shell Plating Options Flange Mtg. Options 627W/628W 9-25 Flash30u” gold 4 Std. 1 1 3 629W/630W 9-25 Flash30u” gold 4 Std 1 1 3 633W/634W 15-44 Flash30u” gold 3 High 1 1 1 637W/638W 15-44 Flash- 3 High 1 1 1 M/F Widest range of options available to meet all design requirements Superior IP67 Waterproof solution that withstands harsh envrionments Waterproof Power Combo D-Sub Connectors Series No. of Contacts Plating Options No. of Contact Codes & Density Ins. Color Options Shell Plating Options Flange Mtg. Options M/F Power / Signal 627WC/628WC 1-5 / 0-20 Flash30u” gold 12 Std. 1 2 4 629WC/630WC 1-5 / 0-20 Flash30u” gold 12 Std. 1 2 6 For More Information www.edac.net Waterproof USB Connectors Waterproof panel mount USB connectors Type A and B standard and micro are available offering IP67 grade protection. Quarter turn twist and lock bayonet style system offers easy mating and ultra secure connections. IP67 Waterproof board mount USB connectors feature full epoxy sealing of the contacts and an O-ring seal to the panel. Features • Standard USB Type A, Micro USB, Mini USB & bayonet style are available • 1.2Mbps or 480Mbps communication speeds • 480Mbps communication speed compatible with USB 2.0 standard • Compatible with asynchronous and isochronous data transfer methods • Silicone rubber seals for tight seal to panel • Bayonet locking system for safe mating under severe vibration or shock conditions • Micro USB board mount and type C available with all rated IP 67 www.edac.net Waterproof USB Connectors Series No. of Contacts Plating Contact Codes Ins. Color Type 690W 4-5 Flash - 30u” RA & Cable End PBT/LCP A 2.0/Mini/Micro Solid waterproof connection with superior shock & vibration resistance. Built to withstand the most harsh envrionments. For More Information www.edac.net Waterproof HDMI Connectors E-seal waterproof HDMI connectors follow industry standards and are available with a quarter turn, twist and lock, bayonet locking system offering easy mating and an ultra secure connection. Fully sealed on the back end with an O-ring seal to the panel insures no water ingress. These IP67 rated connectors are fully submersible and deliver high speed video transmissions resulting in very high resolution images. Features • • • • • Plating options from gold flash to 30u" gold plating Quarter turn, twist and lock, bayonet style locking mechanism Silicone rubber seals and fully potted terminals Hot pluggable Synchronous or asynchronous high speed data transmissions www.edac.net Waterproof HDMI Connectors Series No. of Contacts Plating Options Contact Codes Ins. Material Type 694W 38 Flash-30u” Cable End LCP A Premium IP67 connector with secure locking mechanism IP67 waterproof connection with superior shock & vibration resistance! For More Information www.edac.net Waterproof Wire to Wire & Wire to Board The EDAC E-Inline family of waterproof plug and socket connectors provides a reliable interconnect solution in harsh environments. Single or double latch insulator designs insure superior shock and vibration resistance. A variety of styles are available for different wire gauge applications. These utilize simple crimp and poke contacts. Optional contact plugs are available for use when all contact positions are not required. Additional contacts/wires can then be added in the field. Features • Rated current from 3 to 10 Amps for use with wire sizes from 28 to 14 AWG • 560 and 572 series offer double latch solution • Available in wire-to-wire and wire-to-board options • True crimp and poke solution • Internal polarization to prevent mismating • Available with wire already installed • Waterproof grade IP52 and IP67 certified www.edac.net Waterproof Wire to Wire & Wire to Board Connectors Series No. of Contacts Pitch 560 2, 3 and 5 2.5mm 3 amps 565 2, 3 and 5 2.5mm 3 amps 566 2, 3, 4 and 6 2.0mm 2 amps Single Y Y IP67 567 2, 3, 4, 6 and 9 5.0mm X 5.9mm 8 amps Single Y N IP52 568 1 N/A 12 amps Single Y N IP52 570 1, 2 and 3 5.8mm 10 amps Single Y N IP67 572 1, 2 and 3 5.8mm 10 amps Double Y N IP67 Current Latch Type Rating Polarized Pre-Installed Seals WP Grade Double Y Y IP67 Single Y Y IP67 Premium Waterproof wire to wire or wire to board solution Optional Port Plugs allow circuits to be added in the field For More Information www.edac.net customerservice@edac.net Tel: +1 416 754 3322 customerservice@edac.net Established in 1966, EDAC soon became a world leader in providing connectors for Card Edge and Rack & Panel applications. Since then, we have expanded our product offering to include one of the widest ranges of interconnect solutions in the world. Products include D-Sub, Modular Jacks RJ45, USB, HDMI, Inline Plug & Socket, Headers, Waterproof Connectors and Custom Solutions. Our dedicated teams of engineering, customer service, field support, and global distribution partners allow EDAC the opportunity to support many unique applications globally. www.edac.net Connect with Us . . . Experience Makes the Difference
565-290-731 价格&库存
很抱歉,暂时无法提供与“565-290-731”相匹配的价格&库存,您可以联系我们找货
    • 1+0.67340
    • 10+0.58980
    • 25+0.52655
    • 100+0.42438
    • 250+0.40486
    • 500+0.39024
    • 1000+0.37479
    • 2500+0.35455
    • 8000+0.32856
    • 24000+0.30185
    库存:6753
    565-290-731
    • 8000+0.469498000+0.06086
    • 16000+0.4470616000+0.05795
    • 24000+0.4344624000+0.05632
    • 40000+0.4190740000+0.05432
    • 56000+0.4092456000+0.05305
    • 80000+0.3990880000+0.05173
    库存:100
    565-290-731
      • 1+0.883841+0.11457
      • 10+0.7571210+0.09814
      • 25+0.7045225+0.09132
      • 50+0.6727850+0.08721
      • 100+0.64020100+0.08299
      • 250+0.59986250+0.07776
      • 500+0.57115500+0.07404
      • 1000+0.543771000+0.07049
      • 2500+0.509692500+0.06607
      库存:100
