SERIES 572
Wire to Wire / Wire to Board 5.8mm Pitch
ͻ
ͻ
ͻ
ͻ
ͻ
ͻ
ͻ
ͻ
ͻ
Specifications:
No. of Positions
Pitch
Rated Voltage
Rated Current
Withstanding Voltage
Contact Resistance
Insulation Resistance
Temperature Range
PCB Thickness
Crimp Contact:
1, 2, 3
5.8mm
300V
10A max
1700V AC (rms)
10 mɏ max
Housing
Contact
Housing
PCB Header
Contact
Contact Plating
Wire & Housing Seals
-40°C to +105°C
1.6mm
PBT, UL 94V-0
Ph. Brz. or Brass
PBT with Glass, UL 94V-0
Brass
Tin Plating
Silicone Rubber
Pcs/Reel
4,000
4,000
4,000
4,000
Female Contact (Socket)
Part No (Material)
AWG#
Ins. Dia.
570-290-761 (Brass)
14
Max. Ø3.1
570-291-741 (Ph. Brz.)
20-16
Max. Ø3.1
570-290-741 (Brass)
20-16
Max. Ø3.1
570-291-721 (Ph. Brz.)
22-20
Max. Ø2.7
570-290-721 (Brass)
22-20
Max. Ø2.7
Pcs/Reel
4,000
4,000
4,000
4,000
4,000
**Crimp Contacts are also available in strips of 40pcs.
Contact EDAC for more information.
**Housing seals are already pre-assembled in the
connector.
Wire Seal:
Part No.
570-260-001
570-260-002
570-260-003
570-260-004
Male Contact (Pin)
Part No (Material)
Ins. Dia.
AWG#
570-290-751 (Brass)
Max. Ø3.1
14
570-291-731 (Ph. Brz.)
Max. Ø3.1
20-16
570-290-731 (Brass)
20-16
Max. Ø3.1
570-290-711 (Brass)
22-20
Max. Ø2.7
1000 MɏŵŝŶͬ͘ϱϬϬs
Materials:
Crimp &
Poke
5.8mm Pitch, Rated Current: 10A max
Fully Waterproof with Double Latch Solution
Available in Wire-to-Wire and Wire-to-Board Options
Seals preassembled into housing; no external sealing
required available in 1, 2, or 3 Positions
True Crimp and Poke Solution
Internal Polarization to Prevent Mismating
Available with wire already installed
Wide range of wire sizes available
Waterproof Grade IP67 Certified
Wire O.D.
Color
Ø1.7~Ø2.1
Ø2.1~Ø2.7
Ø2.1~Ø2.7
Ø2.7~Ø3.1
Black
Light Blue
Blue
Brown
Ordering Guide:
AWG#
22
22-20
22-20
20-14
Ø Dia.
Ø 5.0
Ø 5.0
Ø 5.0
Ø 4.9
Height
6.0
6.0
6.7
5.0
570-260-001
570-260-002
570-260-004
570-260-003
Assembly Layout
572-002-000-100
47.0
SERIES:
572, WIRE TO WIRE
WIRE TO BOARD
NO. OF CONTACTS:
001 - 1 CONTACT
002 - 2 CONTACTS
003 - 3 CONTACTS
STYLE:
101 - WHITE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS)
301 - BLUE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS)
100 - WHITE MALE HOUSING FOR CRIMP CONTACTS
300 - BLUE MALE HOUSING FOR CRIMP CONTACTS
200 - WHITE FEMALE HOUSING FOR CRIMP CONTACTS
400 - BLUE FEMALE HOUSING FOR CRIMP CONTACTS
Page 1
30.5
Double Latch
CONTACT CODE:
000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS)
420 - BOARD MOUNT CONTACTS
www.edac.net
SERIES 572
Male Housing:
Female Housing:
PCB Header
572-001-000-XXX
572-001-000-YYY
572-001-420-XXX
572-002-000-XXX
572-002-000-YYY
572-002-420-XXX
572-003-000-XXX
572-003-000-YYY
572-003-420-XXX
Male Housing:
Housing
Color
White
Blue
XXX
100
300
Female Housing:
Housing
Color
White
Blue
YYY
200
400
PCB Header
Housing
Color
White
Blue
XXX
101
301
www.edac.net
Page 2
SERIES 572
Recommended PCB Layout
www.edac.net
Page 3
很抱歉,暂时无法提供与“570-290-761P40”相匹配的价格&库存,您可以联系我们找货
