570-290-741P40
570-290-741P40
570-290-741P40 数据手册
SERIES 572 Wire to Wire / Wire to Board 5.8mm Pitch ͻ ͻ ͻ ͻ ͻ ͻ ͻ ͻ ͻ Specifications: No. of Positions Pitch Rated Voltage Rated Current Withstanding Voltage Contact Resistance Insulation Resistance Temperature Range PCB Thickness Crimp Contact: 1, 2, 3 5.8mm 300V 10A max 1700V AC (rms) 10 mɏ max Housing Contact Housing PCB Header Contact Contact Plating Wire & Housing Seals -40°C to +105°C 1.6mm PBT, UL 94V-0 Ph. Brz. or Brass PBT with Glass, UL 94V-0 Brass Tin Plating Silicone Rubber Pcs/Reel 4,000 4,000 4,000 4,000 Female Contact (Socket) Part No (Material) AWG# Ins. Dia. 570-290-761 (Brass) 14 Max. Ø3.1 570-291-741 (Ph. Brz.) 20-16 Max. Ø3.1 570-290-741 (Brass) 20-16 Max. Ø3.1 570-291-721 (Ph. Brz.) 22-20 Max. Ø2.7 570-290-721 (Brass) 22-20 Max. Ø2.7 Pcs/Reel 4,000 4,000 4,000 4,000 4,000 **Crimp Contacts are also available in strips of 40pcs. Contact EDAC for more information. **Housing seals are already pre-assembled in the connector. Wire Seal: Part No. 570-260-001 570-260-002 570-260-003 570-260-004 Male Contact (Pin) Part No (Material) Ins. Dia. AWG# 570-290-751 (Brass) Max. Ø3.1 14 570-291-731 (Ph. Brz.) Max. Ø3.1 20-16 570-290-731 (Brass) 20-16 Max. Ø3.1 570-290-711 (Brass) 22-20 Max. Ø2.7 1000 MɏŵŝŶͬ͘ϱϬϬs Materials: Crimp & Poke 5.8mm Pitch, Rated Current: 10A max Fully Waterproof with Double Latch Solution Available in Wire-to-Wire and Wire-to-Board Options Seals preassembled into housing; no external sealing required available in 1, 2, or 3 Positions True Crimp and Poke Solution Internal Polarization to Prevent Mismating Available with wire already installed Wide range of wire sizes available Waterproof Grade IP67 Certified Wire O.D. Color Ø1.7~Ø2.1 Ø2.1~Ø2.7 Ø2.1~Ø2.7 Ø2.7~Ø3.1 Black Light Blue Blue Brown Ordering Guide: AWG# 22 22-20 22-20 20-14 Ø Dia. Ø 5.0 Ø 5.0 Ø 5.0 Ø 4.9 Height 6.0 6.0 6.7 5.0 570-260-001 570-260-002 570-260-004 570-260-003 Assembly Layout 572-002-000-100 47.0 SERIES: 572, WIRE TO WIRE WIRE TO BOARD NO. OF CONTACTS: 001 - 1 CONTACT 002 - 2 CONTACTS 003 - 3 CONTACTS STYLE: 101 - WHITE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 301 - BLUE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 100 - WHITE MALE HOUSING FOR CRIMP CONTACTS 300 - BLUE MALE HOUSING FOR CRIMP CONTACTS 200 - WHITE FEMALE HOUSING FOR CRIMP CONTACTS 400 - BLUE FEMALE HOUSING FOR CRIMP CONTACTS Page 1 30.5 Double Latch CONTACT CODE: 000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS) 420 - BOARD MOUNT CONTACTS www.edac.net SERIES 572 Wire to Wire / Wire to Board 5.8mm Pitch Male Housing: Female Housing: PCB Header 572-001-000-XXX 572-001-000-YYY 572-001-420-XXX 572-002-000-XXX 572-002-000-YYY 572-002-420-XXX 572-003-000-XXX 572-003-000-YYY 572-003-420-XXX Male Housing: Housing Color White Blue XXX 100 300 Female Housing: Housing Color White Blue YYY 200 400 PCB Header Housing Color White Blue XXX 101 301 www.edac.net Page 2 SERIES 572 Wire to Wire / Wire to Board 5.8mm Pitch Recommended PCB Layout www.edac.net Page 3
570-290-741P40 价格&库存
很抱歉,暂时无法提供与“570-290-741P40”相匹配的价格&库存,您可以联系我们找货
570-290-741P40
  • 1+82.154031+10.53791
  • 10+69.8026210+8.95359
  • 25+65.4241425+8.39196
  • 50+62.3007750+7.99133
  • 100+59.32737100+7.60993
  • 250+55.61453250+7.13369
  • 500+52.96219500+6.79347
  • 1000+50.436961000+6.46956
库存:82
570-290-741P40
  • 40+1.39442
库存:640
