ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
Contact Detail:
000-No Contacts Assembled
ORIGINAL
1
2.750 69.85
1.525 38.74
Features
UL Recognized
.150 (3.81) Contact Spacing x .130 (3.30) or .150 (3.81) Row Spacing with
Staggered Grid
Plug and Receptacle in 20, 38, 56, 90 or 120 Contact Sizes
Edacon Hermaphroditic Contact Mating Design
Contact Termination Options Include: Crimp, P.C. Tail, Wire Hole and Wire Wrap
Mating and Unmating Simplified with use of Actuating Screws
Optional Covers with Side or Top Entry Cable Clamp in Plastic or Metal Material
Available for All Connector Sizes
Versatile Metal Cover Design Permits Assembly and Disassembly after Cabling is
Complete plus Cable Entry Style Flexibility
Actuating Screws, Locknuts, Polarizing Hardware, Covers and Contacts Suitable
for either Plug or Receptacle
Polarizing Hardware Adjustable for 288 Mating Combinations
Tools Available for Contact Installation, Removal and Crimping and Polarizing
Changes
See Accompanying Pages for:
- PC Tail Layout
- Cutout Panel Details
- Cover Details
Specifications
Insulator Material: Diallyl Phthalate or Thermo plastic
Polyester, UL94V-0, Colour: Green, or Polycarbonate,
Colour: Grey
Contact Material: Phosphor Bronze Alloy CA-510
Contact Plating: Gold over Nickel for Entire Contact
Cover Material: Polycarbonate, Colour: Green, or DieCast Zinc, Finished with Grey Enamel Paint
Current Rating: 8.5 Amperes
Contact Resistance: 10 Milliohms Maximum
Dielectric Withstanding Voltage: 2000 V AC rms at
Sea Level
Insulation Resistance: 5000 Megohms Minimum
Operating Temperature: -65 to +125 Degrees C
Insertion and Withdrawal Force: 2 to 16 oz (0.56 to
4.45 N) per Contact Position
516 Assembly
Part Number: 516-120-000-101
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO. 516 Assembly
J.LEE
DRAWN:
CHECKED:
SCALE:
1:1
DRAWING NUMBER
516 Assembly
DATE: JUNE 18, 2009
DATE:
SHEET 1 OF 4
ISSUE
1
ISSUE NUMBER
(20)
0.040 1.02 Dia. Holes
(38)
0.075 1.91
0.150 3.81
0.150 3.81
0.150 3.81
0.600 15.24
0.410 10.41
0.075 1.91
0.150 3.81
0.750 19.05
0.600 15.24
0.130 3.30
12 Row Spaces
20 Pin
P.C. Tail Layout
0.150 3.81
1.190 30.23
0.130 3.30
12 Row Spaces
38 Pin
P.C. Tail Layout
(90)
0.150 3.81
0.150 3.81
1.710 43.43
56 Pin
P.C. Tail Layout
(120)
1.200 30.48
0.900 22.86
0.075 1.91
1
(56)
0.075 1.91
0.130 3.30
ORIGINAL
0.130 3.30
1.820 46.23
90 Pin
P.C. Tail Layout
0.075 1.91
0.150 3.81
0.130 3.30
1.820 46.23
120 Pin
P.C. Tail Layout
516 Assembly
P.C. Tail Layout Details
EDAC INC
TORONTO, ONTARIO
CANADA
J.LEE
DRAWN:
CHECKED:
SCALE:
1:1
DRAWING NUMBER
516 Assembly
DATE: JUNE 18, 2009
DATE:
SHEET 2 OF 4
ISSUE
1
ISSUE NUMBER
(4)
"A" Dia. Hole
ORIGINAL
1
"G" Max.
End Cut-Outs Optional
Provide Access to
Polarizing Hardware
"B"
"D"
"C"
"E"
"F"
20 Pin
38 Pin
56 Pin
90 Pin
120 Pin
Dimension A
0.104 [2.64]
0.136 [3.45]
0.136 [3.45]
0.136 [3.45]
0.136 [3.45]
Dimension B
0.640 [16.26]
0.816 [20.73]
0.816 [20.73]
1.120 [28.45]
1.420 [36.07]
Dimension C
0.410 [10.41]
0.468 [11.89]
0.468 [11.89]
0.765 [19.43]
0.875 [22.23]
Dimension D
0.960 [24.38]
1.420 [36.07]
1.940 [49.28]
2.050 [52.07]
2.050 [52.07]
Dimension E
1.126 [28.60]
1.688 [42.88]
2.280 [57.91]
2.282 [57.96]
2.375 [60.33]
Dimension F
1.270 [32.26]
1.958 [49.73]
2.550 [64.77]
2.675 [67.95]
2.675 [67.95]
516 Assembly
Cut-Out Panel Detail
EDAC INC
TORONTO, ONTARIO
CANADA
Dimension G
R0.130 [R3.30]
R0.130 [R3.30]
R0.130 [R3.30]
R0.130 [R3.30]
R0.130 [R3.30]
DRAWN:
J.LEE
DATE: JUNE 18, 2009
CHECKED:
DATE:
SCALE:
SHEET 3 OF 4
DRAWING NUMBER
516 Assembly
ISSUE
1
ISSUE NUMBER
"E"
"B"
"D"
1
"F"
"G"
"C"
Top Entry
Cover for
Connector
20 Pin
20 Pin
38 Pin
38 Pin
38 Pin
56 Pin
56 Pin
56 Pin
90 Pin
90 Pin
120 Pin
120 Pin
ORIGINAL
Cover
Material
Plastic
Metal
Plastic
Plastic
Metal
Plastic
Plastic
Metal
Plastic
Metal
Plastic
Metal
Side Entry
Clamp
Size
Standard
Standard
Standard
Large
Standard
Standard
Large
Standard
Standard
Standard
Standard
Standard
Standard Clamp
Large Clamp
"A"
"B"
"C"
"D"
"E"
"F"
"G"
1.605 (40.77)
1.539 (39.09)
2.460 (62.48)
2.460 (62.48)
2.206 (56.03)
2.602 (66.09)
2.602 (66.09)
2.602 (66.09)
2.718 (69.04)
2.718 (69.04)
2.750 (69.85)
2.750 (69.85)
1.325 (33.66)
1.325 (33.66)
2.010 (51.05)
2.010 (51.05)
2.006 (50.95)
2.602 (66.09)
2.602 (66.09)
2.602 (66.09)
2.718 (69.04)
2.718 (69.04)
2.750 (69.85)
2.750 (69.85)
0.906 (23.01)
0.906 (23.01)
1.530 (38.86)
1.530 (38.86)
1.566 (39.78)
1.530 (38.86)
1.530 (38.86)
1.566 (39.78)
1.775 (45.09)
1.775 (45.09)
2.020 (51.31)
2.020 (51.31)
1.190 (30.23)
1.120 (28.45)
1.985 (50.42)
1.985 (50.42)
1.766 (44.86)
1.985 (50.42)
1.985 (50.42)
1.766 (44.86)
2.181 (55.40)
2.175 (55.25)
2.426 (61.62)
2.445 (62.10)
0.715 (18.16)
0.686 (17.42)
0.910 (23.11)
1.110 (28.19)
0.875 (22.23)
0.910 (23.11)
1.110 (28.19)
0.875 (22.23)
1.250 (31.75)
1.234 (31.34)
1.530 (38.86)
1.531 (38.89)
0.450 (11.43)
0.446 (11.33)
0.650 (16.51)
0.650 (16.51)
0.720 (18.29)
0.650 (16.51)
0.650 (16.51)
0.720 (18.29)
0.800 (20.32)
0.880 (22.35)
0.800 (20.32)
0.890 (22.61)
0.450 (11.43)
0.490 (12.45)
0.500 (12.70)
0.608 (15.44)
0.575 (14.61)
0.500 (12.70)
0.608 (15.44)
0.575 (14.61)
0.800 (20.32)
0.900 (22.86)
1.080 (27.43)
1.080 (27.43)
516 Assembly
EDAC INC
TORONTO, ONTARIO
CANADA
DRAWN:
J.LEE
DATE: JUNE 18, 2009
CHECKED:
DATE:
SCALE:
SHEET 4 OF 4
DRAWING NUMBER
516 Assembly
ISSUE
1
很抱歉,暂时无法提供与“516-120-000-101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+253.340511+32.81017
- 10+215.3138410+27.88533
- 25+201.8297225+26.13900
- 50+192.2004350+24.89191
- 100+183.03452100+23.70483
- 250+171.58746250+22.22232
- 500+163.40980500+21.16323
