516-090-000-401
516-090-000-401
516-090-000-401 数据手册
ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. Contact Detail: 000-No Contacts Assembled ORIGINAL 1 2.718 69.04 1.234 31.34 Features • UL Recognized • .150 (3.81) Contact Spacing x .130 (3.30) or .150 (3.81) Row Spacing with Staggered Grid • Plug and Receptacle in 20, 38, 56, 90 or 120 Contact Sizes • Edacon Hermaphroditic Contact Mating Design • Contact Termination Options Include: Crimp, P.C. Tail, Wire Hole and Wire Wrap • Mating and Unmating Simplified with use of Actuating Screws • Optional Covers with Side or Top Entry Cable Clamp in Plastic or Metal Material Available for All Connector Sizes • Versatile Metal Cover Design Permits Assembly and Disassembly after Cabling is Complete plus Cable Entry Style Flexibility • Actuating Screws, Locknuts, Polarizing Hardware, Covers and Contacts Suitable for either Plug or Receptacle • Polarizing Hardware Adjustable for 288 Mating Combinations • Tools Available for Contact Installation, Removal and Crimping and Polarizing Changes See Accompanying Pages for: - PC Tail Layout - Cutout Panel Details - Cover Details Specifications • Insulator Material: Diallyl Phthalate or Thermo plastic Polyester, UL94V-0, Colour: Green, or Polycarbonate, Colour: Grey • Contact Material: Phosphor Bronze Alloy CA-510 • Contact Plating: Gold over Nickel for Entire Contact • Cover Material: Polycarbonate, Colour: Green, or DieCast Zinc, Finished with Grey Enamel Paint • Current Rating: 8.5 Amperes • Contact Resistance: 10 Milliohms Maximum • Dielectric Withstanding Voltage: 2000 V AC rms at Sea Level • Insulation Resistance: 5000 Megohms Minimum • Operating Temperature: -65 to +125 Degrees C • Insertion and Withdrawal Force: 2 to 16 oz (0.56 to 4.45 N) per Contact Position 516 Assembly Part Number: 516-090-000-401 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. 516 Assembly J.LEE DRAWN: CHECKED: SCALE: 1:1 DRAWING NUMBER 516 Assembly DATE: JUNE 18, 2009 DATE: SHEET 1 OF 4 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. (20) 0.040 1.02 Dia. Holes (38) 0.040 1.02 Dia. Holes 0.075 1.91 0.150 3.81 0.150 3.81 0.150 3.81 0.600 15.24 0.410 10.41 0.075 1.91 0.150 3.81 0.750 19.05 0.600 15.24 0.130 3.30 12 Row Spaces 20 Pin P.C. Tail Layout 0.150 3.81 1.190 30.23 0.130 3.30 12 Row Spaces 38 Pin P.C. Tail Layout (90) 0.040 1.02 Dia. Holes 0.150 3.81 0.150 3.81 1.710 43.43 56 Pin P.C. Tail Layout (120) 0.040 1.02 Dia. Holes 1.200 30.48 0.900 22.86 0.075 1.91 1 (56) 0.040 1.02 Dia. Holes 0.075 1.91 0.130 3.30 ORIGINAL 0.130 3.30 1.820 46.23 90 Pin P.C. Tail Layout 0.075 1.91 0.150 3.81 0.130 3.30 1.820 46.23 120 Pin P.C. Tail Layout 516 Assembly P.C. Tail Layout Details EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE ACAD REFERENCE NO. 516 Assembly J.LEE DRAWN: CHECKED: THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 1:1 DRAWING NUMBER 516 Assembly DATE: JUNE 18, 2009 DATE: SHEET 2 OF 4 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. (4) "A" Dia. Hole ORIGINAL 1 "G" Max. End Cut-Outs Optional Provide Access to Polarizing Hardware "B" "D" "C" "E" "F" 20 Pin 38 Pin 56 Pin 90 Pin 120 Pin Dimension A 0.104 [2.64] 0.136 [3.45] 0.136 [3.45] 0.136 [3.45] 0.136 [3.45] Dimension B 0.640 [16.26] 0.816 [20.73] 0.816 [20.73] 1.120 [28.45] 1.420 [36.07] Dimension C 0.410 [10.41] 0.468 [11.89] 0.468 [11.89] 0.765 [19.43] 0.875 [22.23] Dimension D 0.960 [24.38] 1.420 [36.07] 1.940 [49.28] 2.050 [52.07] 2.050 [52.07] Dimension E 1.126 [28.60] 1.688 [42.88] 2.280 [57.91] 2.282 [57.96] 2.375 [60.33] Dimension F 1.270 [32.26] 1.958 [49.73] 2.550 [64.77] 2.675 [67.95] 2.675 [67.95] 516 Assembly Cut-Out Panel Detail EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE Dimension G R0.130 [R3.30] R0.130 [R3.30] R0.130 [R3.30] R0.130 [R3.30] R0.130 [R3.30] ACAD REFERENCE NO. 516 Assembly DRAWN: THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. J.LEE DATE: JUNE 18, 2009 CHECKED: DATE: SCALE: SHEET 3 OF 4 DRAWING NUMBER 516 Assembly ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. "E" "B" "D" ORIGINAL 1 "F" "C" "G" Top Entry Cover for Connector 20 Pin 20 Pin 38 Pin 38 Pin 38 Pin 56 Pin 56 Pin 56 Pin 90 Pin 90 Pin 120 Pin 120 Pin Cover Material Plastic Metal Plastic Plastic Metal Plastic Plastic Metal Plastic Metal Plastic Metal Side Entry Clamp Size Standard Standard Standard Large Standard Standard Large Standard Standard Standard Standard Standard Standard Clamp Large Clamp "A" "B" "C" "D" "E" "F" "G" 1.605 (40.77) 1.539 (39.09) 2.460 (62.48) 2.460 (62.48) 2.206 (56.03) 2.602 (66.09) 2.602 (66.09) 2.602 (66.09) 2.718 (69.04) 2.718 (69.04) 2.750 (69.85) 2.750 (69.85) 1.325 (33.66) 1.325 (33.66) 2.010 (51.05) 2.010 (51.05) 2.006 (50.95) 2.602 (66.09) 2.602 (66.09) 2.602 (66.09) 2.718 (69.04) 2.718 (69.04) 2.750 (69.85) 2.750 (69.85) 0.906 (23.01) 0.906 (23.01) 1.530 (38.86) 1.530 (38.86) 1.566 (39.78) 1.530 (38.86) 1.530 (38.86) 1.566 (39.78) 1.775 (45.09) 1.775 (45.09) 2.020 (51.31) 2.020 (51.31) 1.190 (30.23) 1.120 (28.45) 1.985 (50.42) 1.985 (50.42) 1.766 (44.86) 1.985 (50.42) 1.985 (50.42) 1.766 (44.86) 2.181 (55.40) 2.175 (55.25) 2.426 (61.62) 2.445 (62.10) 0.715 (18.16) 0.686 (17.42) 0.910 (23.11) 1.110 (28.19) 0.875 (22.23) 0.910 (23.11) 1.110 (28.19) 0.875 (22.23) 1.250 (31.75) 1.234 (31.34) 1.530 (38.86) 1.531 (38.89) 0.450 (11.43) 0.446 (11.33) 0.650 (16.51) 0.650 (16.51) 0.720 (18.29) 0.650 (16.51) 0.650 (16.51) 0.720 (18.29) 0.800 (20.32) 0.880 (22.35) 0.800 (20.32) 0.890 (22.61) 0.450 (11.43) 0.490 (12.45) 0.500 (12.70) 0.608 (15.44) 0.575 (14.61) 0.500 (12.70) 0.608 (15.44) 0.575 (14.61) 0.800 (20.32) 0.900 (22.86) 1.080 (27.43) 1.080 (27.43) 516 Assembly Cut-Out Panel Detail EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE ACAD REFERENCE NO. 516 Assembly DRAWN: THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. J.LEE DATE: JUNE 18, 2009 CHECKED: DATE: SCALE: SHEET 4 OF 4 DRAWING NUMBER 516 Assembly ISSUE 1
516-090-000-401 价格&库存
很抱歉,暂时无法提供与“516-090-000-401”相匹配的价格&库存,您可以联系我们找货
  • 1+164.37201
  • 15+161.72689
  • 50+159.44626
  • 100+156.69701
库存:18
516-090-000-401
  • 1+275.846701+35.53850
  • 10+234.4477710+30.20490
  • 25+219.7125625+28.30650
  • 50+209.2751150+26.96180
  • 100+199.27622100+25.67360
