519-036-000-402
519-036-000-402
519-036-000-402 数据手册
519 SERIES Rack And Panel Connectors Features: • • • • • • • • • • • 0.150” (3.81mm) contact spacing x 0.150” (3.81mm) row spacing suitable for automatic wire wrapping Plug and receptacle in 14 or 36 contact sizes Edacon hermaphroditic contact mating design Contact termination options include crimp, P.C. tail, wire hole and wire wrap Mating and unmating simplified with use of actuating screws Optional covers with side or top entry cable clamp in plastic or metal material available for all connector sizes Versatile metal cover design permits assembly or disassembly after cabling is complete plus cable entry style flexibility Actuating screws, locknuts, polarizing hardware, covers and contacts suitable for either plug or receptacle Polarizing hardware adjustable for 288 mating combinations Tools available for contact installation, removal, crimping and polarizing changes RoHS Compliant Specifications: Insulator Material Polycarbonate UL 94V-0 Color Grey Contact Material Copper Alloy Contact Plating Gold Plating over Nickel over entire contact Current Rating 8.5 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 2000 V AC rms at sea level Insulation Resistance 5000 megaohms minimum Operating Temperature -40°C to +105°C Insertion & Withdrawal Force 2 to 16 oz (0.56 to 4.45N) per contact position Example Part Number: 519-036-500-301 Series Total Number of Contacts Contact Code Connector style Cover Code Hardware Code Series: 519 Cover Code 1, 2, 3, 4: Description: 0 No Cover Assembled 1 Plastic Cover, Top Entry Standard Clamp 2 Plastic Cover, Side Entry Standard Clamp 3 Plastic Cover, Top Entry Large Clamp 4 Plastic Cover, Side Entry Large Clamp 5 Metal Cover, Side Entry Total Number of Contacts: 014, 036 Contact Code: Description: Tail Size: Tail Length "G": 000 No Contacts Assembled ------------ ------------ 500 Wire Hole .110 x .024 (2.79 x 0.61) .245 (6.22) 501 520 Taper Tail P.C. Tail .110 x .024 (2.79 x 0.61) .025 x .024 (0.64 x 0.61) .245 (6.22) .215 (5.46) 540 Wire Wrap .050 x .024 (1.27 x 0.61) .600 (15.24) 541 Wire Wrap .026 x .024 (0.66 x 0.61) .620 (15.70) 542 Wire Wrap .050 x .024 (1.27 x 0.61) .790 (20.07) Connector Style: Style: 3 Plug 4 Receptacle 6 Metal Cover, Top Entry Hardware Code 5: Description: 0 No Hardware 1 Actuating Screw & Polarizing Hardware 2 Locknut & Polarizing Hardware 5 Actuating Screw with No Polarizing Hardware 6 Locknut with No Polarizing Hardware Ordering Code Notes: 1) The 14 pin connector cover will not accept the length of wire wrap contacts. 2) Plastic covers with large clamps are only available for 36 Pin size connectors. 3) Metal covers with side entry may be converted to top entry by removing side plate and changing clamp orientation. 4) Covers may be ordered separately. 5) Insulator design prevents improper mating of individual plug and receptacle. Polarizing hardware enables specific plug and receptacle combinations. www.edac.net customerservice@edac.net 519 SERIES Rack And Panel Connectors www.edac.net customerservice@edac.net
519-036-000-402 价格&库存
很抱歉,暂时无法提供与“519-036-000-402”相匹配的价格&库存,您可以联系我们找货
