100/103/105/106 Series
Card Edge Connectors
Features:
0.100” (2.54mm) or 0.200” (5.08mm) contact spacing for contacts on strips
Other spacings accommodated with loose contacts
Assemble into 0.062” (1.57mm) nominal thickness P.C. board by staking and/or soldering of contact tails
Edacon hermaphroditic contact mating design
Card guides, guide pins, guide sockets and polarizing sleeves to ensure correct alignment and mating design
Handling and assembly simplified with contacts on strips
Designed to mate with 100 series contacts in parallel or perpendicular board configurations
RoHS Compliant
Specifications:
Contact Material
Copper Alloy
Contact Plating
Gold Plating over Nickel for entire contact
Current Rating
5 or 10 amps (see ordering code notes)
Contact Resistance
10 milliohms maximum
Insertion and Withdrawal Force
2 to 16 oz (0.56 to 4.45 N) per contact
103/105/106 CONTACTS ON STRIPS
Example Part Number:
103-060-250-100
100 SERIES LOOSE CONTACTS
100-290-208
Series & Pattern
Series
Total Number of Contacts
Loose Contact Identification Code
Contact Code
Contact Code
Spacing Code
Series
Pattern 5
103
105
Pattern Descriptions
Contact Code 1,2,4
Pattern
Contact Spacing
Horizontal
201, 202, 203
105
.200 (5.08)
208
105
.100 (2.54) or .200 (5.08)
250, 251
103 or 106
.200 (5.08)
253
103 or 106
Vertical
106
45 Degree
Spacing Code
Contact Spacing
002, 003,...060
Descriptions
.200 (5.08)
100
.100 (2.54)
002, 003,...120
.100 (2.54)
200
.200 (5.08)
1,2,3,4,6
www.edac.net
Ordering Code Notes:
1) Contact codes 208, 253 are rated for 5 amps current. All other contacts are
rated for 10 amps.
2) Contact codes 208, 253 will mate together, but not with other contacts listed.
3) Pattern schematics are views towards the tip of the contact tails.
4) Consult with EDAC regarding double row staggered patterns for contact
codes 250, 251. Available with up to 60 contacts per row, these patterns have
.125 (3.18) row spacing for use on mother boards that mate with upper and
lower tier daughter boards contacts.
5) All strip lengths up to 60 or 120 contacts (as determined by spacing and
pattern) are available upon request.
6) Contact codes 210 and 258 are available loose only.
customerservice@edac.net
CONTACT SPACING
CONTACT CODES 250, 251
.062 (1.57) NOMINAL THICKNESS BOARDS
MOTHER BOARD -CONTACT CODES 250, 251
-.062 (1.57) NOMINAL THICKNESS BOARDS
DAUGHTER BOARD -UPPER TIER CONTACT CODE 201
-LOWER TIER CONTACT CODES 202, 203
G
G
GUIDE SOCKET
P/N 100-221-102
CARD GUIDE
P/N 100-220-100
.100
(2.54)
45 DEGREE
CONTACT
PATTERN
CARD GUIDE
P/N 100-220-101
GUIDE PIN
P/N 100-222-102
.438
(11.13)
MATED ASSEMBLY
.500 (12.70)
UPPER TIER
.330 (8.38)
.084 (2.13)
LOWER TIER
PARALLEL P.C. BOARDS .100 (2.54) OR .200 (5.08)
CONTACT SPACING
CONTACT CODES 253
.125 (3.18)
.125 (3.17)
.400
(10.16)
G
.100 (2.54)
.200 (5.08) LOWER TIER
G
.230 (5.84)
MATED ASSEMBLY
GUIDE PIN
P/N 100-222-104
.100 (2.54)
OR
.200 (5.08)
45 DEGREE
CONTACT
PATTERN
.200 (5.08) UPPER TIER
MOTHER/DAUGHTER BOARDS .200 (5.08)
CONTACT SPACING
DAUGHTER BOARD -CONTACT CODES 201, 202, 203
GUIDE SOCKET
P/N 100-221-104
CARD GUIDE
P/N 100-220-100
MOTHER/DAUGHTER BOARDS .100 (2.54) OR .200 (5.08)
CONTACT SPACING
.200 (5.08)
MOTHER BOARD -CONTACT CODES 253
DAUGHTER BOARD -CONTACT CODE 208
G
CARD GUIDE
P/N 100-220-101
.100 (2.54)
OR
.200 (5.08)
POLARIZING SLEEVE
P/N 100-240-318
OMIT MATING
CONTACT
.500 (12.70)
G
G
GUIDE TUNNEL
P/N 100-221-100
.312 (7.92)
A
B
.200 (5.08)
.100 (2.54)
.190 (4.83)
.041 (1.04)
GUIDE PIN
www.edac.net
.082 (2.08)
CONTACT CODE
A
B
201
.209 (5.31)
.500 (12.70)
202, 203
.084 (2.13)
.400 (10.16)
.057 (1.45)
很抱歉,暂时无法提供与“100-290-208”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+2.462011000+0.31944
