103-003-251-200
103-003-251-200
    CONNECTOR - PRINTED CIRCUIT
103-003-251-200 数据手册
100/103/105/106 Series Card Edge Connectors Features: • • • • • • • • 0.100” (2.54mm) or 0.200” (5.08mm) contact spacing for contacts on strips Other spacings accommodated with loose contacts Assemble into 0.062” (1.57mm) nominal thickness P.C. board by staking and/or soldering of contact tails Edacon hermaphroditic contact mating design Card guides, guide pins, guide sockets and polarizing sleeves to ensure correct alignment and mating design Handling and assembly simplified with contacts on strips Designed to mate with 100 series contacts in parallel or perpendicular board configurations RoHS Compliant Specifications: Contact Material Copper Alloy Contact Plating Gold Plating over Nickel for entire contact Current Rating 5 or 10 amps (see ordering code notes) Contact Resistance 10 milliohms maximum Insertion and Withdrawal Force 2 to 16 oz (0.56 to 4.45 N) per contact 103/105/106 CONTACTS ON STRIPS Example Part Number: 103-060-250-100 100 SERIES LOOSE CONTACTS Example Part Number: 100-290-208 Series & Pattern Series Total Number of Contacts Loose Contact Identification Code Contact Code Contact Code Spacing Code Series Pattern 5 103 105 Pattern Descriptions Contact Code 1,2,4 Pattern Contact Spacing Horizontal 201, 202, 203 105 .200 (5.08) 208 105 .100 (2.54) or .200 (5.08) 250, 251 103 or 106 .200 (5.08) 253 103 or 106 .100 (2.54) or .200 (5.08) Vertical 106 45 Degree Total Number of Contacts Spacing Code Contact Spacing 002, 003,...060 Descriptions .200 (5.08) 100 .100 (2.54) 002, 003,...120 .100 (2.54) 200 .200 (5.08)  1,2,3,4,6                   www.edac.net Ordering Code Notes: 1) Contact codes 208, 253 are rated for 5 amps current. All other contacts are rated for 10 amps. 2) Contact codes 208, 253 will mate together, but not with other contacts listed. 3) Pattern schematics are views towards the tip of the contact tails. 4) Consult with EDAC regarding double row staggered patterns for contact codes 250, 251. Available with up to 60 contacts per row, these patterns have .125 (3.18) row spacing for use on mother boards that mate with upper and lower tier daughter boards contacts. 5) All strip lengths up to 60 or 120 contacts (as determined by spacing and pattern) are available upon request. 6) Contact codes 210 and 258 are available loose only. customerservice@edac.net 100/103/105/106 Series Card Edge Connectors CONTACT SPACING CONTACT CODES 250, 251 .062 (1.57) NOMINAL THICKNESS BOARDS MOTHER BOARD -CONTACT CODES 250, 251 -.062 (1.57) NOMINAL THICKNESS BOARDS DAUGHTER BOARD -UPPER TIER CONTACT CODE 201 -LOWER TIER CONTACT CODES 202, 203 -.062 (1.57) NOMINAL THICKNESS BOARDS G G GUIDE SOCKET P/N 100-221-102 CARD GUIDE P/N 100-220-100 .100 (2.54) 45 DEGREE CONTACT PATTERN CARD GUIDE P/N 100-220-101 GUIDE PIN P/N 100-222-102 .438 (11.13) MATED ASSEMBLY .500 (12.70) UPPER TIER .330 (8.38) .084 (2.13) LOWER TIER PARALLEL P.C. BOARDS .100 (2.54) OR .200 (5.08) CONTACT SPACING CONTACT CODES 253 .062 (1.57) NOMINAL THICKNESS BOARDS .125 (3.18) .125 (3.17) .400 (10.16) G .100 (2.54) .200 (5.08) LOWER TIER G .230 (5.84) MATED ASSEMBLY GUIDE PIN P/N 100-222-104 .100 (2.54) OR .200 (5.08) 45 DEGREE CONTACT PATTERN .200 (5.08) UPPER TIER MOTHER/DAUGHTER BOARDS .200 (5.08) CONTACT SPACING MOTHER BOARD -CONTACT CODES 250, 251 -.062 (1.57) NOMINAL THICKNESS DAUGHTER BOARD -CONTACT CODES 201, 202, 203 -.062 (1.57) NOMINAL THICKNESS BOARDS GUIDE SOCKET P/N 100-221-104 CARD GUIDE P/N 100-220-100 MOTHER/DAUGHTER BOARDS .100 (2.54) OR .200 (5.08) CONTACT SPACING .200 (5.08) MOTHER BOARD -CONTACT CODES 253 DAUGHTER BOARD -CONTACT CODE 208 -.062 (1.57) NOMINAL THICKNESS BOARDS G CARD GUIDE P/N 100-220-101 .100 (2.54) OR .200 (5.08) POLARIZING SLEEVE P/N 100-240-318 OMIT MATING CONTACT .500 (12.70) G G GUIDE TUNNEL P/N 100-221-100 .312 (7.92) A B .200 (5.08) .100 (2.54) .190 (4.83) .041 (1.04) GUIDE PIN www.edac.net .082 (2.08) CONTACT CODE A B 201 .209 (5.31) .500 (12.70) 202, 203 .084 (2.13) .400 (10.16) .057 (1.45) customerservice@edac.net
103-003-251-200 价格&库存
很抱歉,暂时无法提供与“103-003-251-200”相匹配的价格&库存,您可以联系我们找货
  • 1+22.279101+2.88780
  • 10+19.4283010+2.51830
  • 25+18.6018025+2.41120
  • 100+17.30820100+2.24350
  • 300+15.65520300+2.02930
  • 500+14.45740500+1.87400
  • 1000+12.433201000+1.61160
  • 2500+11.594702500+1.50290
  • 5000+11.043705000+1.43150
库存:35
