516-230-138
516-230-138
516-230-138 数据手册
516 SERIES Rack and Panel Connectors: Metal and Plastic Covers Features: • • • • • • • Available in metal (die-cast zinc finished with grey enamel paint) or plastic (green polycarbonate) material Covers with top and side entry cable clamp Orientation of clamp on metal covers may be changed by the customer Versatile metal cover design permits assembly or disassembly after cabling is complete 516 covers also accommodates 519 series connectors Screws for securing cover to 516 or 519 series connectors supplied RoHS Compliant & UL Certified Example Part Number: 516-230-556 Series Cover Identification Code cover Type Cover Size Series: 516 Cover Identification Code: 230 Cover Type 1,2,3: Description: 1 Plastic Cover, Side Entry Standard Clamp 2 Plastic Cover, Top Entry Standard Clamp 3 Plastic Cover, Side Entry Large Clamp 4 Plastic Cover, Top Entry Large Clamp 5 Metal Cover, Side Entry 6 Metal Cover, Top Entry 7 Metal Cover, Large Clamp Cover Size: Fits Connector: 12 516 Series 120 Pin 20 516 Series 20 Pin and 519 Series 14 Pin 38 516 Series 38 Pin and 519 Series 36 Pin 56 516 Series 56 Pin 90 516 Series 90 Pin Ordering Code Notes 1) Plastic Covers with Large Clamps are only Available for 38 and 56 Pin Connectors. 2) Metal Covers with side entry may be converted to top entry by removing side plate and changing clamp orientation. 3) For 90 pin size top entry plastic cover must use P/N:516-230-890. www.edac.net customerservice@edac.net
516-230-138 价格&库存
很抱歉,暂时无法提供与“516-230-138”相匹配的价格&库存,您可以联系我们找货
  • 25+135.2028925+17.48773
