516-235-138
516-235-138
516-235-138 数据手册
516 SERIES WITH EMI SHIELD ASSEMBLY SCREW SHIELD CABLE SHIELD PANEL GROUNDING DIMPLES CAPACITOR CAPACITOR RETAINER BUSHING 'E' 'H' BUSHING 'E' FLAT WASHER 'H' 'F' HEX NUT COMPONENTS ASSY 'A' NO SHIELD 'B' 'B' "A" "B" "C" "D" "E" "F" "H" inch (mm) inch (mm) inch (mm) inch (mm) inch (mm) inch (mm) inch (mm) 20 STANDARD 20 LOW 1.679(42.65) .673(17.09) 1.088(27.64) 1.200(30.48) .800(20.32) .777(19.74) 1.387(35.23) 38 STANDARD 38 LOW 2.360(59.94) 1.007(25.58) 1.258(31.96) 1.300(33.02) 1.100(27.94) .962(24.43) 56 STANDARD 56 LOW 2.975(75.57) 1.321(33.55) 1.258(31.96) 1.300(33.02) 1.100(27.94) .962(24.43) 2.679(68.05) 90 STANDARD 90 LOW 3.113(79.07) 1.383(35.30) 1.606(40.79) 1.300(33.02) 1.100(27.94) 1.311(33.30) 2.802(71.17) 120 STANDARD 120 LOW 3.145(79.88) 1.406(35.71) 1.897(48.18) 1.300(33.02) 1.100(27.94) 1.607(40.82) 2.827(71.81) NUMBER OF CONTACTS 'C' 'C' Ø'D' (2) SHIELD IN PLACE PANEL CUT-OUT AND SHIELD MOUNTING HOLES PANEL CUT-AWAY TO CLEAR CONNECTOR ø.190(ø4.83) EMI SHIELDING KIT ORDERING GUIDE: 516 - 235 - 156 SERIES SHIELDING KIT IDENTIFICATION CODE NOTE: PACKAGING TO PREVENT PLATING SCRATCHES AND SCRAPES IS REQUIRED. COVER TYPE SCREW (4) (METRIC OR UNIFIED) CAPACITOR BUSHING BUSHING KIT SIZE SHIELD PANEL (2) (STANDARD OR LOW PROFILE) PAGE 1 OF 2 516 SERIES SHIELDED METAL COVER ORDERING GUIDE: 516 - 235 - 156 COVER SIZE SERIES FIXED CLAMP (TOP ENTRY) SHIELDED COVER IDENTIFICATION CODE FIXED CLAMP (SIDE ENTRY) COVER TYPE NOTE: PACKAGING TO PREVENT PLATING SCRATCHES AND SCRAPES IS REQUIRED. SHIELDING CLAMP UNPAINTED COVER SUB-ASSEMBLY COMPONENTS CHART PAGE 2 OF 2
516-235-138 价格&库存
很抱歉,暂时无法提供与“516-235-138”相匹配的价格&库存,您可以联系我们找货
