516 SERIES
RACK AND PANEL CONNECTOR (PLUG AND RECEPTACLE)
• FEATURES:
• .150" (3.81mm) Contact Spacing x .130" (3.30mm) or .150" (3.81mm) Row
Spacing with staggered Grid
• Plug and Receptacle in 20, 38, 56, 90 and 120 Contact Sizes
• Edacon Hermaphroditic Contact Mating Design
• Contact Termination Options include Crimp, P.C. Tail, Wire Hole and Wire
Wrap
• Mating and Unmating Simplified with use of Actuating Screws
• Optional Covers with Side or Top Entry Cable Clamp in Plastic or Metal
material Available for all Connector Sizes
• Versatile Metal Cover Design permits Assembly or Disassembly After
Cabling is Complete plus Cable Entry Style Flexibility
• Actuating Screws, Locknuts, Polarizing Hardware, Covers and Contacts
Suitable for either Plug or Receptacle
• Polarizing Hardware Adjustable for 288 Mating Combinations
• Tools Available for Contact Installation, Removal and Crimping and
Polarizing Changes
• RoHS Compliant & UL Certified
Specifications:
Insulator Material
Color
Contact Material
Contact Plating
Current Rating
Contact Resistance
Withstanding Voltage
Insulation Resistance
Operating Temp
Operating Temp
Insertion & Withdrawal Force
Example Part Number:
Diallyl Phthalate, Thermoplastic Polyester or Polycarbonate UL 94V- 0
Green or Grey
Copper Alloy
Gold Plating over Nickel over entire contact
8.5 Amperes
10 milliohms maximum
2000 V AC rms at sea level
5000 Megaohms minimum
-40°C to +125°C (Diallyl Phthalate Only)
-40°C to +105°C
2 to 16 Oz (0.56 to 4.45N) per contact position
516-038-500-212
2
3
4
5
6
Series
Total Number of Contacts
Contact Code
Style and Material
Cover Code
Hardware Code
Series
Description
No Cover Assembly
Plastic Cover, Top Entry Standard Clamp
Plastic Cover, Side Entry Standard Clamp
Plastic Cover, Top Entry Large Clamp
Plastic Cover, Side Entry Large Clamp
Metal Cover, Side Entry
Metal Cover, Top Entry
516
Contact Code 1,2
000
500
520
540
541
542
Cover Code 4, 5, 6, 7
Description & Tail Size
Tail Length "G"
No Contacts Assembled
Wire Hole .110 x .024 (2.79 x 0.61)
P.C. Tail .25 x .024 (0.64 x 0.61)
Wire Wrap .050 x .024 (1.27 x 0.61)
Wire Wrap .026 x .024 (0.66 x 0.61)
Style & Material 3
1
2
3
4
5
6
Style
Plug
Receptacle
Plug
Receptacle
Plug
Receptacle
Hardware Code 8
020, 038, 056, 090 or 120
-----------.245 (6.22)
.215 (5.46)
.600 (15.24)
.620 (15.70)
.790 (20.07)
Insulator Material
Green Diallyl Phthalate
Grey Polycarbonate
Grey Polycarbonate
Green Polyester
Green Polyester
www.edac.net
Page 1
2
5
6
Description
No Hardware
Actuating Screw & Polarizing Hardware
Locknut & Polarizing Hardware
Actuating Screw with No Polarizing Hardware
Locknut with No Polarizing Hardware
516 SERIES
Ordering Code Notes
Crimp Characteristics
1) Crimp contacts are also available for 516 series connectors. Contacts may be
ordered separately for pre-wired or select position assembly.
Part Number
Description
Silhouette
516-290-500
Wire Hole
516-290-501
Taper Tail
516-290-520
P.C. Tail
516-290-540
Wire Wrap
516-290-541
Wire Wrap
516-290-542
Wire Wrap
516-290-590
Crimp (Loose)
516-294-571
Crimp - 1800 Contact
Per Reel
Contacts and Crimp Tool Accommodate from 28AWG to 18AWG, Solid
or Stranded Conductor Diameters from .012 (0.30) to .049 (1.25) and an
Insulation diameter up to 0.074 (1.88)
Multiple Smaller Gauge Wires may be Crimped Together
Crimp Resistance from 0.5 Milliohms (18AWG) to 1.5
Milliohms(28AWG)
Crimp Tensile Strength for Wire Sizes
18AWG - 40 lbs (178 N)
20AWG - 25 lbs (111 N)
22AWG - 15 lbs (67 N)
24AWG - 10 lbs (44 N)
26AWG - 5 lbs (22 N)
28AWG - 3 lbs (13 N)
Polarizing Codes
2) For contact installation, removal and crimping tools, Please contact EDAC. •
3) Grey Polycarbonate and Polyester insulator material are not available for •
120 pin size connector.
4) 120 pin size connector can only be supplied in DAP (Green and Grey). 120
pin part number ends with 3XX or 4XX are supplied in grey DAP.
5) The 20 pin connector cover will not accept the length of the wire wrap
contacts
6) Plastic covers with large clamps are only available for 38 and 56 pin sizes
only
7) Metal covers with side entry may be converted to top entry by removing
side plate and changing clamp orientation
8) Covers may be ordered separately
9) Insulator design prevents improper mating of individual plug and
receptacle. Polarizing hardware enables specific plug and receptacle
combinations
Polarizing Hardware Changes allow 288 Mating Combinations
Standard Code Supplied for Plugs PG1G1, for Receptacle RS1S1.
Connectors with Special Polarizing Codes Available upon Special
Request
Example Polarizing Code:
Large Diameter Hardware
G - Guidepin (at Contact Position "A" end)
H - Guidepin (at Last Contact Position end)
S - Socket (at Contact Position "A" end)
T - Socket (at Last Contact Position end)
Position of large Diameter Keyway - 1 Through 6
Small Diameter Hardware (Opposite end From Large Diameter)
G - Guidepin, S - Socket
Position of Small Diameter Keyway - 1 Through 6
This Example mates with Code RS4G2
www.edac.net
Page 2
P G 4 S 2
Type of Connector
P - Plug, R - Receptacle
516 SERIES
www.edac.net
Page 3
516 SERIES
METAL AND PLASTIC COVERS
• FEATURES:
• Available in Metal (Die-Cast Zinc Finished with Grey
enamel Paint) or Plastic (Green polycarbonate) Material
• Covers with Top and Side Entry Cable Clamp.
Orientation of Clamp on Metal Covers may be changed
by the Customer
• Versatile Metal Cover Design Permits Assembly or
Disassembly after Cabling is Complete
• Screws for Securing Cover to 516 or 519 Series
Connectors Supplied.
516-230-556
Series
Cover Identification Code
cover Type
Cover Size
Series
516
Cover Type 1, 2
1
2
3
4
5
6
7
Description
Metal Cover, Large Clamp
Cover Size
12
56
90
230
Fits Connector
516 Series 120 Pin
516 Series 20 Pin and 519 Series 14 Pin
516 Series 38 Pin and 519 Series 36 Pin
516 Series 56 Pin
516 Series 90 Pin
Ordering Code Notes
1) Plastic Covers with Large Clamps are only Available for
38 and 56 Pin Connectors.
2) Metal Covers with side entry may be converted to top
entry by removing side plate and changing clamp
orientation.
3) For 90 pin size top entry plastic cover must use P/N:516230-890.
www.edac.net
516 SERIES CRIMP MACHINE AND TOOLS
FEATURES:
CONTACT CRIMP MACHINE
Tooling part numbers: 516-280-700 (electric press) & 516-280-750 (contact applicator)
Crimp-style contact part number: 516-294-571 (supplied on 1800 pcs reels, ordered separately)
Guarded for operator safety
Quick access to the crimp setting adjustment mechanism
Foot switch operation
Cycle counter on the front panel
Each cycle crimps a contact, cuts the contact from the carrier strip and feeds a new contact into position
Adjustment settings for conductor and insulation
Crimp settings for common wires between 16 and 28 AWG (confirm application with factory before purchase)
Mounts to any flat surface
Electrically operated, specify requirements when ordering: 115V or 230V & 50HZ or 60HZ
Shipping weight: 450 lbs/204 kg gross
CONTACT HAND CRIMP TOOL
Part number 516-280-201
Crimps contact part number 516-290-590
Precise tool for hand crimping loose contacts
Built-in rachet to prevent under crimping
Part number: 516-280-750
Part number:516-280-201
CONTACT EJECTION TOOL
Part number 516-280-300
For use with all 516 series contact styles
Provides easy positive ejection without damage to the insulator
CRIMP CONTACT INSERTION TOOL
Part number 516-280-400
For installing 516-290-590 & -591, 516-294-571 crimp contacts
Wire groove locates the tool onto the end of the crimp form
POLARIZING HARDWARE ROUND NUT DRIVER
Part number 516-280-500
For removing and tightening round nuts when changing orientation of metal polarizing guide pins and sockets
WIRE WRAP & P.C. TAIL CONTACT INSERTION TOOL
Part number 516-280-600
For installing 516-290-520, -540, -541, -542, -501, and -521 contacts
Slender tube protects contact tail during insertion without interfering with adjacent contacts
www.edac.net
516 SERIES
RECOMMENDED PCB LAYOUT
1.688
1.125
.130
TYP.
.249
TYP.
.150
TYP.
Ø.2549
OPTIONAL
.187
TYP.
Ø.4255
OPTIONAL
.066
.5054
.4427
.410
1.2852
.600
.410
.468
.075
TYP.
.150
.8100
(4)
.093 DIA. HOLE
.075
TYP.
.150
TYP.
.150
.130
8 ROW SPACES
(20)
.042 DIA. HOLE
.750
1.190
38 PINS
20 PINS
2.280
1.8468
.150
TYP.
Ø.4255
OPTIONAL
.285
TYP.
.066
.5054
.600
.468
.075
TYP.
(4)
.125 DIA. HOLE
.150
.130
12 ROW SPACES
(56)
.042 DIA. HOLE
1.710
56 PINS
2.282
1.9656
.231
TYP.
.150
TYP.
.067
.8262
.900
.765
.075
TYP.
Ø.5098
OPTIONAL
.130
14 ROW SPACES
(4)
.125 DIA. HOLE
(90)
.042 DIA. HOLE
1.820
90 PINS
2.375
1.9656
.277
TYP.
.150
TYP.
.162
.9450
.075
TYP.
.875
1.200
.130
14 ROW SPACES
www.edac.net
Ø.5098
OPTIONAL
(4)
.144 DIA. HOLE
(120)
.042 DIA. HOLE
120 PINS
(4)
.125 DIA. HOLE
(38)
.042 DIA. HOLE
516 IDENTIFICATION
INSULATOR PLUG 20 CONTACTS
A
E
K
M
B
C
P
H
N
U
F
T
D
J
L
R
V
X
E
R
A
L
V
X
Z D
D
F
B
M
H
C
N
J
T
B
S
A
F
B
E
F
A
E
M
W
D
P
Y
H
H
T
M
T
L
S
L
S
K
R
K
R
J
P
J
P
K
U
C
C
N
N
E
R
a
A
L
W
e
F
S
b
k
u
B
M
X
h
p
H
T
l
v
C
N
Y
r
J
U
c
D
P
Z
s
K
V
d
m
f
j
t
C
C
x
B
B
w
A
n
y
J
J
A
H
z
F
N
N
E
M
D
M
H
L
F
L
E
K
D
K
Page 1
www.edac.net
S
W
INSULATOR PLUG 38 CONTACTS
INSULATOR PLUG 56 CONTACTS
C
T
D
Y
C
D
C
R
E
J
D
P
C
X
B
D
U
D
Z
C
E
C
S
B
B
J
Z
B
Y
E
K
D
R
C
Y
B
K
B
R
E
V
D
A
D
F
C
T
B
A
C
B
E
B
L
B
W
A
Z
E
L
D
S
C
H
F
W
D
B
D
E
M
D
T
J
H
X
D
C
D
E
N
D
U
K
J
Y
D
D
D
A
E
P
D
V
C
K
Z
D
E
D
L
C
U
E
R
D
W
C
B
C
B
V
A
C
C
D
B
K
B
B
C
C
U
A
A
A
N
C
J
B
Z
A
M
C
B
T
A
Y
A
A
L
S
B
B
B
P
H
F
A
A
X
A
E
A
W
A
A
A
V
A
D
A
H
A
S
F
L
A
E
F
D
M
C
V
B
F
B
M
A
T
E
S
D
X
C
C
C
P
B
X
A
C
A
J
B
E
H
D
N
C
W
B
H
B
N
A
U
F
R
E
E
D
P
P
W
A
N
D
V
A
M
A
L
A
A
U
C
U
A
L
A
B
A
T
A
A
K
A
B
C
D
C
T
A
Y
B
N
B
K
S
A
A
J
R
B
B
C
A
S
A
J
A
H
R
A
F
A
X
B
B
R
M
H
A
Z
P
Y
A
A
W
N
B
E
A
V
B
H
B
C
E
C
Page 2
X
A
M
A
A
P
B
Z B
N
B
E
B
D
M
F
L
B
B
K
B
B
J
B
X
C
M
V
B
C
B
C
B
C
B
C
W
B
S
B
D
C
C
V
C
B
U
C
A
T
C
L
C
K
U
J
T
C
Z
C
H
S
B
D
C
A
D
C
C
R
Z
C
C
P
Y
F
X
C
Y
C
N
C
www.edac.net
W
A
516 IDENTIFICATION
INSULATOR PLUG 90 CONTACTS
INSULATOR PLUG 120 CONTACTS
www.edac.net
Page 3
w
r
L
L
M
N
F
F
M
H
N
H
B
C
J
B
x
C
t
A
A
E
E
v
b
S
W
L
K
K
z
p
h
s
X
M
F
A
j
m
Y
T
H
B
e
c
U
N
C
f
Z
P
J
J
y
n
d
V
K
D
D
D
u
k
a
R
E
T
S
R
K
R
L
S
M
T
P
P
D
N
D
K
E
E
L
F
F
M
N
H
A
B
H
A
B
C
X
S
L
Y
M
F
A
V
T
N
H
B
W
P
J
C
C
U
K
D
J
J
Z
R
E
X
V
U
P
T
N
W
S
M
E
A
R
F
B
K
H
C
L
J
D
516 IDENTIFICATION
INSULATOR RECEPTACLE 20 CONTACTS
INSULATOR RECEPTACLE 38 CONTACTS
INSULATOR RECEPTACLE 56 CONTACTS
www.edac.net
Page 4
A
L
B
E
E
E
S
F
H
D
D
D
X
M
C
N
V
B
C
C
C
P
B
F
B
C
W
B
H
B
X
M
A
A
K
E
R
D
W
C
B
C
N
B
W
A
B
N
A
C
H
A
T
A
U
J
Z
D
E
D
L
C
U
B
E
B
L
A
S
J
E
P
D
V
C
A
C
M
V
A
A
A
F
Y
D
D
D
K
C
D
B
K
A
R
H
E
N
D
U
C
U
A
Z
E
X
D
C
D
J
C
C
B
J
A
P
F
E
M
D
T
C
T
A
Y
D
W
D
B
D
H
C
B
B
H
A
N
E
E
L
D
S
C
Z
B
L
B
S
A
X
C
V
D
A
D
F
C
T
B
A
B
F
A
M
D
E
K
D
R
C
Y
B
K
B
R
A
W
B
U
D
Z
C
E
C
S
B
Z
A
E
A
L
C
E
J
D
P
C
X
B
J
B
P
A
V
T
D
Y
C
D
C
R
B
Y
A
D
A
K
A
V
C
D
A
S
T
Z
C
C
B
C
B
M
A
A
A
R
L
C
K
V
L
B
U
C
C
C
B
C
W
B
N
J
A
U
D
C
B
F
B
X
D
M
D
E
C
C
C
X
P
B
B
B
R
H
B
C
B
B
Y
B
A
A
S
A
K
A
B
T
A
A
A
C
V
M
U
L
W
N
E
A
D
A
P
F
C
J
Y
C
U
B
A
H
A
T
C
T
X
P
R
C
C
H
C
Z
B
C
A
C
K
B
B
A
B
N
A
Y
L
E
W
A
A
B
F
S
J
B
P
A
Z
K
B
V
A
A
C
F
C
S
B
D
W
N
Y
A
M
A
X
H
C
B
J
B
B Z
E
R
A
516 IDENTIFICATION
INSULATOR RECEPTACLE 90 CONTACTS
INSULATOR RECEPTACLE 120 CONTACTS
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
EDAC:
516-280-300 516-235-120 516-235-138 516-235-156 516-236-438 516-250-038-111 516-250-091-111 516-251012-107 516-251-022-107 516-251-035-100 516-251-095-100 516-251-120-107 516-251-190-107 516-251-238-107
516-280-700G 516-280-700K 516-280-221
