09022326825
09022326825
    HARTING(浩亭)
    板对板连接器
09022326825 数据手册
Directory chapter 01 – DIN Signal (to 2 A) Page Technical characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 01.10 Type B connectors ................... 01.11 Type 2B connectors .................. 01.16 Type C connectors ................... 01.18 Pin shroud type C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 01.24 Application examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 01.25 Type 2C connectors .................. 01.26 Type M connectors . . . . . . . . . . . . . . . . . . . 01.28 Special contacts type M . . . . . . . . . . . . . . . 01.30 Type M-flat connectors . . . . . . . . . . . . . . . . 01.32 Type R connectors ................... 01.34 Type R (HE 11) connectors . . . . . . . . . . . . . 01.36 Type Q, 2Q and 2R connectors . . . . . . . . . . 01.38 Coding systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 01.42 DIN Signal to 2 A Types B, 2B, C, 2C, M, Q, 2Q, R, R (HE 11), 2R 01 . 01 Technical characteristics Number of contacts 16-96 Contact spacing (mm) 2.54 Working current 2 A max. 1 A with insulation displacement 40 A max. type M Clearance ≥ 1.2 mm Creepage ≥ 1.2 mm Current carrying capacity The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity curve is valid for continuous, non interrupted current loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60 512 Working voltage The working voltage also depends on the clearance and creepage dimensions of the pcb itself, and the associated wiring according to the safety regulations of the equipment Explanations see chapter 00 Test voltage Ur.m.s. 1 kV Contact resistance ≤ 15 mΩ for wire wrap connection ≤ 20 mΩ including crimp connection Insulation resistance ≥ 1012 Ω Temperature range – 55 °C … + 125 °C The higher temperature limit includes the local ambient and heating effects of the contacts under load Working current DIN Signal to 2 A see current carrying capacity chart Types B, 2B, C, 2C, M, Q, 2Q, R, R (HE 11), 2R Ambient temperature Degree of protection for crimp terminal IP 20 according to DIN 40 050 Electrical termination Male connector Female connector Solder pins for pcb connections Ø 1.0 ± 0.1 mm according to IEC 60 326-3 For pcb connection Ø 0.8 + 0.3 mm on request wrap posts 0.6 x 0.6 mm diagonal 0.79-0.86 mm wrap posts 0.6 x 0.6 mm diagonal 0.79-0.86 mm Solder pins for pcb connections Ø 1.0 ± 0.1 mm according to IEC 60 326-3 For pcb connection Ø 0.8 + 0.3 mm on request Crimp terminal 0.09-0.5 mm² Insulation displacement connection AWG 28/7 Pin shroud for female connectors with 0.6 x 0.6 mm pins A secure interfacing system for signals from the rear of 19” racks to connectors with wrap posts 0.6 x 0.6 mm is possible with the use of a pin shroud. The pin shroud protects the wrap posts on the rear side of the rack and can be screwed to the printed circuit board. After assembly the rear ends of the wire wrap posts become the mating areas of the type C male connector. This system can now accept: l l female connectors type C female connectors type R Insertion and withdrawal force 16way ≤ 15 N The locking levers provide security for the mated connectors. Fast and simple disconnection is possible. Materials Fitting and removing crimp contacts 32way ≤ 30 N 48way ≤ 45 N 64way ≤ 60 N 96way ≤ 90 N Mouldings Contacts Thermoplastic resin, glass-fibre filled, UL 94-V0 Copper alloy Contact surface Contact zone 1) 01 . 10 Selectively plated according to performance level1) Explanation performance levels see chapter 00 Mating conditions see chapter 00 see technical characteristics chapter 02 DIN 41 612 · Type B Number of contacts Male connectors Identification Male connector with angled solder pins Male connector with straight solder pins Number of contacts Contact arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 02 164 6921 02 364 6921b) c)09 02 664 6921c) 09 02 164 2921 b)09 64 09 02 164 7921 32 09 02 132 7921 09 02 132 6921 09 02 132 2921 32 09 02 132 7931 09 02 132 6931 09 02 132 2931 62 + 2s 09 02 164 7951 09 02 164 6951 09 02 164 2951 64 09 02 164 7922 09 02 164 6922 09 02 164 2922 32 09 02 132 7922 09 02 132 6922 09 02 132 2922 32 09 02 132 7932 09 02 132 6932 09 02 132 2932 62 + 2s 09 02 164 7952 09 02 164 6952 09 02 164 2952 DIN Signal to 2 A 64, 32 Dimensions Angled solder pins Straight solder pins Board drillings Mounting side Dimensions in mm s Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a32] Other contact arrangements on request b) Connectors with snap-in clips see chapter 00 c) Connectors with coding see page 01.42 01 . 11 DIN 41 612 · complementary to type B Number of contacts DIN Signal to 2 A 64 Interface connector U Identification Number of contacts Part No. Interface connector U with wrap posts 0.6 x 0.6 mm Drawing Dimensions in mm belong to scope of supply Performance level 1 acc. to IEC 60 603-2 64 09 02 064 2981 Locking screw 09 02 000 99231) 1) Order 2 pieces for one interface connector U Mounting example M 2.5 x 22 DIN EN ISO 1207 M 2.5 x 22 DIN EN ISO 1207 M 2.5 x 12 DIN EN ISO 1207 01 . 12 DIN 41 612 · Type B Number of contacts Female connectors Identification Female connector with solder pins 2.9 mm Female connector with solder pins 4.5 mm Female connector with wrap posts 13 mm Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 DIN Signal to 2 A 64 1 09 02 264 6824 02 464 6824b) c)09 02 764 6824c) b)09 64 Performance level 3 on request 64 09 02 264 6825 64 Performance level 1 on request 09 02 264 6821 Female connector with press-in pins Part Nos. and variants see chapter 04 Dimensions a 2.9 4.5 13 Solder pins Wrap posts row position Panel cut out all holes position Board drillings Mounting side row Identification strips for female connectors with wrap posts 09 02 000 9939 Wrap posts selectively gold plated on request Other contact arrangements on request b) Connectors with snap-in clips see chapter 00 c) Connectors with coding see page 01.42 Dimensions in mm 01 . 13 DIN 41 612 · Type B Number of contacts DIN Signal to 2 A 64 Female connectors Identification Number of contacts Part No. 64 Performance level 21) 09 02 264 6828 Drawing Dimensions in mm Female connector for insulation displacement Cable 1 Performance level 31) 09 02 264 7828 Cable 1 Cable 1 to contact 1 b Contact arrangement View from termination side Panel cut out Flat cable grey 1) AWG 28/7 grey grey colour coded twisted pair1) 50.00 m 150.00 m 30.48 m 30.48 m 64 64 64 64 09 18 064 7001 09 18 064 7004 09 18 064 7005 09 18 064 7006 Round flat cable2) 30 m 150 m 64 64 09 18 064 7007 09 18 064 7010 without screening 30 m 150 m 64 64 09 18 064 7008 09 18 064 7011 Bench press Base plate Important: always store reels vertically Wire (tinned) Cu Gauge AWG 28/7 Insulation material as per UL style PVC grey with screening 09 99 000 0114 09 99 000 0150 Cable cutter 09 99 000 0116 01 . 14 Spare parts Blade Cutting plate Termination area spacing = 508 mm 09 99 000 0179 09 99 000 0180 Further components and accessories for insulation displacement see interface catalogue, chapter 40 1) acc. to IEC 60 603-2 2) 0.089 mm² Termination area spacing = 100 mm colour coded DIN 41 612 · Type B Number of contacts DIN Signal to 2 A max. 64 Female connectors Identification Number of contacts Part No. 64 09 02 064 3214 Drawing Dimensions in mm Female connector for crimp contacts Order contacts separately Contact arrangement View from termination side Shell housing 09 02 064 0501 / 09 02 064 0502 see chapter 20 Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 2 1 Bandoliered contacts (approx. 5 ,000 pieces) 09 02 000 6484 09 02 000 6474 Bandoliered contacts (approx. 500 pieces) 09 02 000 8434 09 02 000 8444 Individual contacts1) 09 02 000 8484 09 02 000 8474 Identification Female crimp contacts BC Wire gauge mm² AWG Insulation ø mm 0.09 - 0.5 28 - 20 0.7 - 1.5 Bandoliered contacts Individual contacts 3.5 + 0.5 mm of insulation is stripped Insertion, removal and crimping tools see chapter 30 1) Packaging unit 1,000 pieces 01 . 15 DIN 41 612 · complementary type 2B Number of contacts DIN Signal to 2 A 32, 16 Male connectors Identification Male connector with angled solder pins Male connector with straight solder pins Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 22 132 6921 22 332 6921b) 09 22 132 2921 32 09 22 132 7921 16 09 22 116 7931 09 22 116 6931 09 22 116 2931 30 + 2s 09 22 132 7951 09 22 132 6951 09 22 132 2951 32 09 22 132 7922 09 22 132 6922 09 22 132 2922 16 09 22 116 7932 09 22 116 6932 09 22 116 2932 30 + 2s 09 22 132 7952 09 22 132 6952 09 22 132 2952 b)09 Dimensions Angled solder pins Straight solder pins Board drillings Mounting side 01 . 16 Dimensions in mm s Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a16] Other contact arrangements on request b) Connectors with snap-in clips see chapter 00 DIN 41 612 · complementary type 2B Number of contacts Female connectors Identification Female connector with solder pins 2.9 mm Female connector with solder pins 4.5 mm Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 DIN Signal to 2 A 32 1 09 22 232 6824 22 432 6824b) 32 b)09 Performance level 3 on request Performance level 1 on request 09 22 232 6825 22 432 6825b) 32 b)09 Female connector with press-in pins Part Nos. and variants see chapter 04 Dimensions row position Board drillings a 2.9 4.5 Solder pins all holes Mounting side position row Dimensions in mm Further components and accessories for insulation displacement see interface catalogue Other contact arrangements on request b) Connectors with snap-in clips see chapter 00 01 . 17 DIN 41 612 · Type C Number of contacts DIN Signal to 2 A 96, 64, 32 Male connectors Identification Male connector with angled solder pins Part No. Number Contact of contacts arrangement Male connector with straight solder pins 2 1 09 03 196 7921 03 396 7921b) b)09 09 03 196 6921 03 396 6921b) c)09 03 696 6921c) b)09 09 03 164 7921 03 364 7921b) b)09 09 03 164 6921 03 364 6921b) c)09 03 664 6921c) b)09 09 03 132 7921 03 332 7921b) b)09 96 b)09 64 b)09 32 Performance levels according to IEC 60 603-2. Explanation chapter 00 3 b)09 94 + 2s 09 03 196 7951 62 + 2s 09 03 132 6921 03 332 6921b) 09 03 196 2921 03 396 2921b) c)09 03 696 2921c) 09 03 164 2921 03 364 2921b) c)09 03 664 2921c) 09 03 132 2921 03 332 2921b) b)09 09 03 196 6951 03 396 6951b) 09 03 196 2951 09 03 164 7951 09 03 164 6951 09 03 164 2951 96 09 03 196 7922 09 03 196 6922 09 03 196 2922 64 09 03 164 7922 09 03 164 6922 09 03 164 2922 b)09 Dimensions Angled solder pins Straight solder pins Board drillings Mounting side 01 . 18 Dimensions in mm s Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a32] High temperature connectors see chapter 05 b) Connectors with snap-in clips see chapter 00 c) Connectors with coding see page 01.42 DIN 41 612 · Type C Number of contacts DIN Signal to 2 A max. 96 Female connectors Identification Number of contacts Part No. Drawing Dimensions in mm Female connector for crimp contacts Order contacts separately 96 09 03 096 3214 03 596 3214c) c)09 Contact arrangement View from termination side Shell housing 09 03 096 0501 see chapter 20 Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 2 1 Bandoliered contacts (approx. 5 ,000 pieces) 09 02 000 6484 09 02 000 6474 Bandoliered contacts (approx. 500 pieces) 09 02 000 8434 09 02 000 8444 Individual contacts1) 09 02 000 8484 09 02 000 8474 Identification Female crimp contacts BC Wire gauge mm² AWG Insulation ø mm 0.09 - 0.5 28 - 20 0.7 - 1.5 Bandoliered contacts Individual contacts 3.5 + 0.5 mm of insulation is stripped from the wires to be crimped Insertion, removal and crimping tools see chapter 30 c) 1) Connectors with coding see page 01.42 Packaging unit 1,000 pieces 01 . 19 DIN 41 612 · Type C Number of contacts DIN Signal to 2 A 96, 64, 32 Female connectors Identification Female connector with solder pins 2.9 mm Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 09 03 296 7824 96 09 03 264 7824 Female connector with kinked solder pins1) 2.9 mm Female connector with solder pins 4.5 mm Female connector with kinked solder pins1) 4.5 mm Female connector with wrap posts 13 mm a+c b 5.2 mm 7.7 mm 1) 09 03 296 2824 03 496 2824b) 09 03 264 6824 03 464 6824b) c)09 03 764 6824c) b)09 09 03 264 2824 03 464 2824b) 09 03 232 6824 09 03 232 2824 96 09 03 296 7855 09 03 296 6855 09 03 296 2855 64 09 03 264 7855 09 03 264 6855 09 03 264 2855 32 09 03 232 7855 09 03 232 6855 09 03 232 2855 09 03 296 6825 03 496 6825b) c)09 03 796 6825c) 09 03 296 2825 09 03 264 6825 03 464 6825b) c)09 03 764 6825c) 09 03 264 2825 09 03 296 7825 03 496 7825b) c)09 09 03 264 7825 03 464 7825b) b)09 96 b)09 64 b)09 32 09 03 232 7825 09 03 232 6825 09 03 232 2825 96 09 03 296 7845 09 03 296 6845 09 03 296 2845 64 09 03 264 7845 09 03 264 6845 09 03 264 2845 32 09 03 232 7845 09 03 232 6845 09 03 232 2845 96 09 03 296 6821 03 796 6821c) 2)09 03 296 68782) c)09 09 03 264 6821 03 264 68782) 2)09 96 09 03 296 6823 64 09 03 264 6823 Kinked pins for fixing the connector onto the pcb see chapter 00 Wrap posts for interfacing, selectively gold-plated (performance level 3) b) Connectors with snap-in clips see chapter 00 c) Connectors with coding see page 01.42 2) b)09 09 03 232 7824 Female connector with press-in pins 01 . 20 09 03 296 6824 03 496 6824b) c)09 03 796 6824c) 32 64 Female connector with solder lugs b)09 b)09 64 1 Part Nos. and variants see chapter 04 DIN Signal to 2 A DIN 41 612 · Type C Identification Drawing Dimensions in mm Female connectors type C DIN 41 612 a 2.9 4.5 13 Standard Solder pins Wrap posts row Kinked pins position Solder pins a b 2.9 2.75 4.5 4.35 b= ^ Length of kinked pins Panel cut out Board drillings Mounting side all holes position row Identification strips for female connectors with wrap posts 09 03 000 9939 01 . 21 DIN 41 612 · Type C Number of contacts DIN Signal to 2 A 64 Female connectors Number of contacts Identification Part No. Drawing Dimensions in mm Female connector for insulation displacement Cable 1 21) 64 Performance level 09 03 264 6828 c)09 03 764 6828c) Cable 1 Performance level 31) 09 03 264 7828 Cable 1 to contact 1 c Contact arrangement View from termination side Panel cut out Mateable with 3 row male connector type C, no female contacts in the middle row Flat cable grey 1) AWG 28/7 grey grey colour coded twisted pair1) 50.00 m 150.00 m 30.48 m 30.48 m 64 64 64 64 09 18 064 7001 09 18 064 7004 09 18 064 7005 09 18 064 7006 Round flat cable2) 30 m 150 m 64 64 09 18 064 7007 09 18 064 7010 without screening 30 m 150 m 64 64 09 18 064 7008 09 18 064 7011 Bench press Base plate Important: always store reels vertically Wire (tinned) Cu Gauge AWG 28/7 Insulation material as per UL style PVC grey with screening 09 99 000 0114 09 99 000 0150 Cable cutter 09 99 000 0116 01 . 22 Spare parts Blade Cutting plate Termination area spacing = 508 mm 09 99 000 0179 09 99 000 0180 Further components and accessories for insulation displacement see interface catalogue, chapter 40 c) Connectors with coding see page 01.42 1) acc. to IEC 60 603-2 2) 0.089 mm² Termination area spacing = 100 mm colour coded DIN Signal to 2 A Injection moulding – state of the art engineering Complicated shapes are injected with upmost precision. Integrated handling robots guarantee that new injected parts are not damaged. 01 . 23 Pin shroud III Number of contacts DIN Signal to 2 A 96 I Pin shrouds/Locking levers for 0.6 x 0.6 mm wrap posts Identification II Part No. V Drawing IV Dimensions in mm for 13 mm wrap posts Pin shroud Type C I for 13 mm wrap posts 09 03 000 9912 II for 17 mm wrap posts 09 03 000 9915 III Locking lever for female connector type C* 09 03 000 9914 M 2.5 DIN EN ISO 4 036 for 17 mm wrap posts Type C M 2.5 DIN EN ISO 4 036 Pin shroud II IV V Type R for 13 mm wrap posts 09 03 000 9912 for 17 mm wrap posts 09 03 000 9915 Locking lever for female connector type R* 09 03 000 9913 Fixing brackets for shell housing C* 09 03 000 9921 M 2.5 DIN EN ISO 4 036 for 17 mm wrap posts Type R Height adjustment of the pin shroud for different pcb thickness with washers is possible. The mating length can be calculated as follows: 01 . 24 M 2.5 DIN EN ISO 4 036 mating length I for 13 mm wrap posts Mating length = 8.4 mm – pcb thickness – washers thickness pcb washers * order 2 pieces per connector Pin shroud · Application examples Female connector 09 03 296 6861 Backplane Pin shroud 09 03 000 9912 Locking lever 09 03 000 9914 Female connector 09 03 264 6828 Female connector 09 03 096 3214 Application 2 Female connector 09 03 296 6862 Backplane Pin shroud 09 03 000 9915 Locking lever 09 03 000 9913 Female connector 09 73 296 6801 Daughtercard Application 3 Female connector 09 03 296 6861 Backplane Pin shroud 09 03 000 9912 Fixing brackets 09 03 000 9921 Female connector 09 03 096 3214 Locking levers left 09 02 000 9902 right 09 02 000 9903 DIN Signal to 2 A Application 1 Shell housing C 09 03 096 0501 01 . 25 DIN 41 612 · complementary type 2C Number of contacts DIN Signal to 2 A 48, 32, 16 Male connectors Identification Male connector with angled solder pins Part No. Number Contact of contacts arrangement 48 32 Male connector with straight solder pins Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 23 148 6921 23 348 6921b) 09 23 148 2921 09 23 132 6921 23 332 6921b) 09 23 132 2921 09 23 148 7921 23 348 7921b) b)09 09 23 132 7921 23 332 7921b) b)09 b)09 b)09 16 09 23 116 7931 09 23 116 6931 09 23 116 2931 46 + 2s 09 23 148 7951 09 23 148 6951 09 23 148 2951 48 09 23 148 7922 09 23 148 6922 09 23 148 2922 32 09 23 132 7922 09 23 132 6922 09 23 132 2922 Dimensions Angled solder pins Straight solder pins Board drillings Mounting side 01 . 26 Dimensions in mm s Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a16] Other contact arrangements on request High temperature connector see chapter 05 b) Connectors with snap-in clips see chapter 00 DIN 41 612 · complementary type 2C Number of contacts Female connectors Identification Female connector with solder pins 2.9 mm Female connector with solder pins 4.5 mm Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 DIN Signal to 2 A 48 1 09 23 248 6824 23 448 6824b) 48 b)09 Performance level 3 on request Performance level 1 on request 09 23 248 6825 23 448 6825b) 48 b)09 Female connector with press-in pins Part Nos. and variants see chapter 04 Dimensions row position a 2.9 4.5 Solder pins Board drillings Mounting side all holes position row Dimensions in mm Other contact arrangements on request b) Connectors with snap-in clips see chapter 00 01 . 27 DIN 41 612 · Type M Number of contacts DIN Signal to 2 A 78+2, 60+4, 42+6, 24+8 Male connectors Identification Male connector with angled solder pins Part No. Number Contact of contacts arrangement 78 + 2 Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 09 03 178 7901 09 03 178 6901 1 09 03 178 2901 03 378 2901b) b)09 (without special contacts)* 60 + 4 09 03 160 7901 09 03 160 6901 09 03 160 2901 42 + 6 09 03 142 7901 09 03 142 6901 09 03 142 2901 24 + 8 09 03 124 7901 09 03 124 6901 09 03 124 2901 Dimensions Angled solder pins Order high current, high voltage, coaxial and fibre optic contacts separately, see pages 01.30 and 01.31 Board drillings Mounting side all holes 01 . 28 ^ = Board drillings depend on type and special contact loading * Pre-loaded with special contacts on request Connectors with snap-in clips see chapter 00 b) Dimensions in mm DIN 41 612 · Type M Number of contacts Female connectors Identification Female connector with solder pins 2.9 mm (without special contacts) Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 78 + 2 09 03 278 6804 60 + 4 09 03 260 6804 42 + 6 09 03 242 6804 24 + 8 Female connector with solder pins 4.5 mm (without special contacts) DIN Signal to 2 A 78+2, 60+4, 42+6, 24+8 1 09 03 224 6804 Performance level 3 on request 78 + 2 09 03 278 6805 60 + 4 09 03 260 6805 42 + 6 09 03 242 6805 24 + 8 09 03 224 6805 Female connector with press-in pins Performance level 1 on request Part Nos. and variants see chapter 04 Dimensions row position a 2.9 4.5 Solder pins Order high current, high voltage, coaxial and fibre optic contacts separately, see pages 01.30 and 01.31 Board drillings Mounting side all holes position row Type 78 + 2 60 + 4 42 + 6 24 + 8 c 25 x 2.54 = 63.50 19 x 2.54 = 48.26 13 x 2.54 = 33.02 7 x 2.54 = 17.78 Dimensions in mm Other contact arrangements on request 01 . 29 DIN 41 612 · Special contacts type M I III V IV II VI VII DIN Signal to 2 A High current contacts High voltage contacts Part No. Performance level 2 Identification Drawing Dimensions in mm High current male contacts for male connectors1) I for straight crimp termination 10 A 20 A 40 A 10 A 20 A 40 A 09 03 000 6113 09 03 000 6114 09 03 000 6115 09 03 000 6123 09 03 000 6124 09 03 000 6125 ø A ø B wire gauge [mm²] AWG 10 A 1.85 2.55 1.5 16 20 A 2.80 3.70 4 12 40 A 4.40 5.60 10 8 10 A 20 A 40 A 10 A 20 A 40 A 09 03 000 6101 09 03 000 6102 09 03 000 6103 09 03 000 6111 09 03 000 6122 09 03 000 6133 ø 10 A 1.7 20 A 2.8 40 A 4.8 for angled pcb termination max. 40 A* 09 03 000 6104 Leading contact max. 40 A* 09 03 000 6134 Leading contact II for straight solder termination Leading contact * depending on the pcb design 1) High current female contacts for female connectors2) III for straight crimp termination 10 A 20 A 40 A 09 03 000 6213 09 03 000 6214 09 03 000 6215 IV for straight solder termination 10 A 20 A 40 A 09 03 000 6201 09 03 000 6202 09 03 000 6203 V for press-in termination for type M-flat 40 A 09 03 000 6250 High voltage male contact for male connectors3) VI for straight solder termination 2.8 kV 01 . 30 for straight solder termination 2.8 kV Crimping tool for high current contacts 2) 3) Contact resistance max. 1.5 mΩ Contact resistance internal wire max. 3 mΩ ø A ø B wire gauge [mm²] AWG 10 A 1.85 2.55 1.5 16 20 A 2.80 3.70 4 12 40 A 4.40 5.60 10 8 ø 10 A 1.7 20 A 2.8 40 A 4.8 09 03 000 6140 09 03 000 6240 09 99 000 0196 x 17.7 18.4 Solder pins for hole ø 1 ± 0.1 mm Wire gauge max. 0.5 mm² High voltage female contact for female connectors3) VII … 6104 … 6134 Wire gauge max. 0.5 mm² DIN 41 612 · Special contacts type M I IV II V DIN Signal to 2 A III Coaxial contacts Identification Part No. Performance level 2 Drawing Dimensions in mm Male coaxial contacts for female connectors I for straight solder and/or crimp termination 09 03 000 6160 *09 03 000 6181* II for angled solder and/or crimp termination 09 03 000 6161 Assembly instruction for contacts I and III solder Female coaxial contacts for male connectors III IV for straight solder and/or crimp termination angled for pcb termination with/without knurled area crimp without knurled area 09 03 000 6260 *09 03 000 6281* with knurled area 09 03 000 6274 for contacts II 09 03 000 6262 *09 03 000 6269* 1) Solder pins for hole ø 1 ± 0.1 mm solder crimp Crimping tool for coaxial contacts solder solder 09 99 000 0194 Removal tool incl. removal jacket V for contact replacement 09 99 000 0174 Replacement removal jacket 09 99 000 0243 Electrical characteristics of 50 Ω coaxial contacts and wires 50 Ω Impedance Max. working frequency 2 up to 10 GHz VSWR-value 1.07 + 0.02 f [GHz] Proof voltage 750 V / 50 Hz Working voltage 250 V / 50 Hz Insulation resistance ≥ 1 GΩ Contact resistance – Center contact – Outer contact 10 mΩ 3 mΩ Contact current max. 1.5 A Admissible power (depends on: frequency, application, VSWR, environmental characteristics) Data on request 75 Ohm versions Data on request Cable group 2 flexible wires RG 174 A/U RG 188 A/U RG 316 U * Coaxial contact 75 Ω Fibre optic contacts on request Insert insulator, press-in or solder closing-washer Shell ø Screening ø Dielectric ø 2.5 2.6 2.5 2.0 2.0 2.0 1.5 1.5 1.5 Internal wire Hexagonal crimp Spanner width ø 0.48 0.54 0.54 3.25 3.25 3.25 01 . 31 DIN 41 612 · complementary type M-flat Number of contacts DIN Signal to 2 A 78+2, 60+4, 42+6, 24+8 Female connectors Identification Female connector with solder pins 2.9 mm (without special contacts)* Female connector with solder pins 4.5 mm (without special contacts)* Number Contact of contacts arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 78 + 2 09 03 278 6864 60 + 4 09 03 260 6864 42 + 6 09 03 242 6864 24 + 8 78 + 2 09 03 224 6864 Performance level 3 on request 09 03 278 6865 60 + 4 09 03 260 6865 42 + 6 09 03 242 6865 24 + 8 09 03 224 6865 Female connector with press-in pins Performance level 1 on request Part Nos. and variants see chapter 04 Dimensions a 2.9 4.5 Solder pins row position Order high current, high voltage, coaxial and fibre optic contacts separately, see pages 01.30 and 01.31 Board drillings Mounting side all holes position row Type 78 + 2 60 + 4 42 + 6 24 + 8 01 . 32 * Pre-loaded with special contacts on request c 25 x 2.54 = 63.50 19 x 2.54 = 48.26 13 x 2.54 = 33.02 7 x 2.54 = 17.78 Dimensions in mm DIN Signal to 2 A HARTING for Telecomms 01 . 33 DIN 41 612 · Type R Number of contacts DIN Signal to 2 A 96, 64, 32 Male connectors Identification Male connector with solder pins 2.5 mm Part No. Number Contact of contacts arrangement 96 94 + 2I 64 32 Male connector with solder pins 4.0 mm 96 94 + 2I 64 Male connector with wrap posts 13 mm Performance levels according to IEC 60 603-2. Explanation chapter 00 3 09 73 196 7902 2 1 09 73 196 6902 73 396 6902b) 09 73 196 6952 09 73 196 2902 b)09 09 73 196 7952 09 73 164 7902 09 73 164 6902 73 364 6902b) b)09 09 73 132 7902 09 73 196 7903 09 73 196 2952 09 73 164 2902 73 364 2902b) b)09 09 73 132 6902 09 73 132 2902 09 73 196 6903 73 396 6903b) 09 73 196 6953 09 73 196 2903 09 73 164 6903 73 364 6903b) 09 73 164 2903 b)09 09 73 196 7953 09 73 164 7903 09 73 196 2953 b)09 32 09 73 132 7903 09 73 132 6903 09 73 132 2903 96 94 + 2I 09 73 196 7907 09 73 196 7957 09 73 196 6907 09 73 196 6957 09 73 196 2907 09 73 196 2957 64 09 73 164 7907 09 73 164 6907 09 73 164 2907 32 09 73 132 7907 09 73 132 6907 09 73 132 2907 Male connector with press-in pins Part Nos. and variants see chapter 04 Dimensions a b 2.5 ø 0.7 4.0 a 13 Panel cut out b l 0.6 Solder pins Wrap posts Contact arrangement View from termination side Board drillings Mounting side 01 . 34 Dimensions in mm I Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a32] Other contact arrangements as well with lagging pins on request b) Connectors with snap-in clips see chapter 00 DIN 41 612 · Type R Number of contacts Female connectors Identification Female connector with angled solder pins Part No. Number Contact of contacts arrangement 96 64 Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 73 296 6801 73 496 6801b) 09 73 296 2801 09 73 264 6801 73 464 6801b) 09 73 264 2801 09 73 296 7801 73 496 7801b) b)09 09 73 264 7801 73 464 7801b) b)09 b)09 b)09 32 09 73 232 7801 09 73 232 6801 09 73 232 2801 32 09 73 232 7811 09 73 232 6811 09 73 232 2811 DIN Signal to 2 A 96, 64, 32 Dimensions row position Board drillings Mounting side all holes position row Dimensions in mm Other contact arrangements on request High temperature connectors see chapter 05 b) Connectors with snap-in clips see chapter 00 01 . 35 DIN 41 612 · complementary to type R (HE 11) Number of contacts DIN Signal to 2 A 96, 64, 32 Male connectors Identification Male connector with solder pins 2.5 mm Male connector with solder pins 4.0 mm Part No. Number Contact of contacts arrangement 2 96 09 79 196 7902 09 79 196 6902 64 09 79 164 7902 09 79 164 6902 32 09 79 132 7902 09 79 132 6902 96 09 79 196 7903 1 09 79 196 6903 79 396 6903b) b)09 09 79 164 7903 09 79 164 6903 b)09 79 364 6903b) 32 09 79 132 7903 09 79 132 6903 96 09 79 196 7907 09 79 196 6907 64 09 79 164 7907 09 79 164 6907 32 09 79 132 7907 09 79 132 6907 64 Male connector with wrap posts 13 mm Performance levels according to IEC 60 603-2. Explanation chapter 00 3 Performance level 1 on request Dimensions a b 2.5 ø 0.7 4.0 a 13 Panel cut out b l 0.6 Solder pins Wrap posts Contact arrangement View from termination side Board drillings Mounting side 01 . 36 Dimensions in mm Other contact arrangements on request = deviating dimensions from standard male connectors (see page 01.34) b) Connectors with snap-in clips see chapter 00 DIN 41 612 · complementary to type R (HE 11) Number of contacts Female connectors Identification Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 DIN Signal to 2 A 96, 64 1 Female connector with angled solder pins 09 79 296 7801 96 09 79 296 6801 79 496 6801b) b)09 09 79 264 7801 64 09 79 264 6801 79 464 6801b) Performance level 1 on request b)09 Dimensions row position Z Board drillings Mounting side all holes position row Dimensions in mm Other contact arrangements on request = deviating dimensions from standard female connectors (see page 01.35) b) Connectors with snap-in clips see chapter 00 01 . 37 DIN 41 612 · Type Q Number of contacts DIN Signal to 2 A 64 Male connectors Identification Male connector with solder pins 2.5 mm Male connector with solder pins 4.0 mm Male connector with wrap posts 13 mm Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 64 62 + 2I 09 72 164 7902 09 72 164 7952 09 72 164 6902 09 72 164 6952 64 62 + 2I 09 72 164 7903 09 72 164 7953 09 72 164 6903 09 72 164 6953 64 62 + 2I 09 72 164 7907 09 72 164 7957 09 72 164 6907 09 72 164 6957 Male connector with press-in pins 1 Performance level 1 on request Part Nos. and variants see chapter 04 Dimensions a b 2.5 ø 0.7 4.0 a 13 b l 0.6 Solder pins Wrap posts Panel cut out Board drillings Mounting side 01 . 38 Dimensions in mm I Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a32] Other contact arrangements as well with lagging pins on request DIN 41 612 · complementary type 2Q Number of contacts Male connectors Identification Male connector with solder pins 2.5 mm Male connector with solder pins 4.0 mm Male connector with wrap posts 13 mm Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 32 30 + 2I 09 27 132 7902 09 27 132 7952 09 27 132 6902 09 27 132 6952 32 30 + 2I 09 27 132 7903 09 27 132 7953 09 27 132 6903 09 27 132 6953 32 30 + 2I 09 27 132 7907 09 27 132 7957 09 27 132 6907 09 27 132 6957 Male connector with press-in pins DIN Signal to 2 A 32 1 Performance level 1 on request Part Nos. and variants see chapter 04 Dimensions a b 2.5 ø 0.7 4.0 a 13 b l 0.6 Solder pins Wrap posts Panel cut out Board drillings Mounting side Dimensions in mm I Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a16] Other contact arrangements as well with lagging pins on request 01 . 39 DIN 41 612 · complementary type 2R Number of contacts DIN Signal to 2 A 48, 32 Male connectors Identification Male connector with solder pins 2.5 mm Male connector with solder pins 4.0 mm Male connector with wrap posts 13 mm Part No. Number Contact of contacts arrangement Performance levels according to IEC 60 603-2. Explanation chapter 00 3 1 09 28 148 2902 46 + 2I 09 28 148 7952 09 28 148 6902 28 348 6902b) 09 28 148 6952 32 09 28 132 7902 09 28 132 6902 09 28 132 2902 09 28 148 2903 48 09 28 148 7902 2 b)09 46 + 2I 09 28 148 7953 09 28 148 6903 28 348 6903b) 09 28 148 6953 32 09 28 132 7903 09 28 132 6903 09 28 132 2903 48 46 + 2I 09 28 148 7907 09 28 148 7957 09 28 148 6907 09 28 148 6957 09 28 148 2907 09 28 148 2957 32 09 28 132 7907 09 28 132 6907 09 28 132 2907 48 09 28 148 7903 09 28 148 2952 b)09 Male connector with press-in pins 09 28 148 2953 Part Nos. and variants see chapter 04 Dimensions a b 2.5 ø 0.7 4.0 a 13 Panel cut out b l 0.6 Solder pins Wrap posts Contact arrangement View from termination side Board drillings Mounting side 01 . 40 Dimensions in mm I Male connectors with 2 leading contacts [(0.8 mm) pos. a1 and a16] Other contact arrangement on request b) Connectors with snap-in clips see chapter 00 DIN 41 612 · Type Q – complementary types 2Q, 2R Number of contacts Female connectors Identification Contact Number of contacts arrangement Part No. Performance level 2 according to IEC 60 603-2. Explanation chapter 00 DIN Signal to 2 A 64, 48, 32 Female connector with angled solder pins Type Q 64 09 72 264 6801 Type 2Q 32 09 27 232 6801 Type 2R 48 09 28 248 6801 Dimensions Types Q / 2Q Type 2R row row position position Type a b c d e f Q 85.0-0.2 88.90±0.1 94.0-0.2 31 78.74 32 2Q 44.4-0.2 48.26±0.1 53.9-0.2 15 38.10 16 Board drillings Mounting side all holes all holes position row position row Dimensions in mm Other contact arrangements on request 01 . 41 DIN 41 612 · Coding systems Identification Part No. DIN Signal to 2 A Coding system without contact loss Drawing Dimensions in mm To avoid accidental and incorrect mating of adjacent connectors a coding system is required.This coding system is an integral part of both male and female connactors. A comb with 12 coding pins, which is supplied under a single part number, allows over 900 coding variations. The pins are to be locked into the male and female connectors. Male and female connectors The connectors with the integrated coding facility are supplied for types B, C, D and E and are available for all variants. Please contact us. Types B, C, D and E see product pages or on request Coding pins 12 pins on a comb 09 02 000 9928 Mounting example Coding system with contact loss B Code pin for types B, 2B, C, 2C, M, M-flat, Q, 2Q, R, R (HE 11), 2R, har-bus 64 09 02 000 9901 01 . 42 Removal tool for male contacts 09 99 000 0133 C D Type D E E To avoid accidental and incorrect mating of adjacent connectors a coding system is required. The coding is achieved by means of a code pin which is inserted into the selected chamber of the female connector (the contact cavity must be filled with a female contact!). The opposite male contact must be removed with the help of the specially designed tool. Plastic
09022326825 价格&库存
很抱歉,暂时无法提供与“09022326825”相匹配的价格&库存,您可以联系我们找货
