SC16ML1S31
SC16ML1S31
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONTACT SOCKET 16-18AWG CRIMP
SC16ML1S31 数据手册
2,4±0,4 C COUPE B D-D C SECTION SC20M1* / SC20M1*REV SC16M11* / SC16M11*REV AREA 2 AREA 1 3,5±0,3 AREA 1 AREA 2 COUPE B-B 7 3,2±0,3 AREA 1 2,4±0,4 B C-C SC16M1* / SC16M1*REV AREA 2 3,7±0,2 7 D SC24M1* / SC24M1*REV 8 F G E-E A D 3,2±0,5 1,9±0,4 B 2,7±0,5 SECTION C SC16ML1* VIEW F H E D 8 E E SC16ML11* VIEW G 1,7±0,4 F SC20ML1* VIEW H 2,5±0,5 G H I J K L M N O P B.6; Validé SC24ML1* AREA 1 AREA 2 AREA 4 AREA 4 AREA 4 AREA 3 AREA 3 2,9±0,3 2,1±0,3 2,4±0,3 2,9±0,3 6 6 AREA 4 AREA 3 AREA 3 5 5 SC14ML1* 3,1±0,3 A FEMALE CONTACT CAT. N° WIRE SIZE Packaging WIRE INSUL. DIAM. IN MM. WIRE STRIP LENGTH IN MM. MM² 26/24 0.12/0.25 0.90/1.60 4.0 22/20 0.32/0.50 1.20/2.10 4.0 DIE SET HANDTOOL FOR LOOSE PIECE S16SCM20 SHANDLES 4 AWG HAND CRIMP TOOLING Loose contacts in platic bag Strip contacts on reel Loose contacts in platic bag Strip contacts on reel Loose contacts in platic bag Strip contacts on reel Loose contacts in platic bag Strip contacts on reel Loose contacts in platic bag Strip contacts on reel 18/16 0.82/1.50 3.0 Max 4.65 18/16 0.82/1.50 3.2 Max 6.35 14 2.10/2.50 3.2 Max 6.35 19 REF S16SCM20 SHANDLES S16SCML11 SHANDLES S16SCML1 SHANDLES * PLATING A-A SC14M1* / SC14M1*REV RX2025GE1 AREA 1 AREA 2 3 S16SCML1 SHANDLES CONSTRUCTION : 2 - S6 = 0.75µ GOLD MIN. OVER Ni GOLD FLASH OVER Ni (AREA 1) (AREA 2) - D70 = 0.13µ GOLD MIN. OVER Ni GOLD FLASH OVER Ni (AREA 1) (AREA 2) - TK6 = 0.5-2.5µ Sn PRE-PLATED (AREA 1+2) CONTACT BODY : HIGH CONDUCTIVITY COPPER ALLOY. OUTER SPRING : STAINLESS STEEL. For standard winding See View AREA 4 PACKING CONTACTS ON STANDARD STRIP : 3000 PCS. PER REEL, E.G. SC16M11* PACKING CONTACTS ON REVERSE STRIP : 3000 PCS. PER REEL, E.G. SC16M11*REV FOR WINDING DIRECTION ON REEL (STANDARD OR REVERSE) : SEE BS.C.200178.004 PACKING LOOSE PIECE CONTACTS : 100 PCS PER STD. PACKING E.G. SC16ML11* -S18 = 0.75µ GOLD MIN OVER Ni 1.3µ MINI Sn OVER Ni 1.3µ MINI Ni (AREA 1) (AREA 3) (AREA 4) -S31 = GOLD FLASH OVER Ni 1.3µ MINI Sn OVER Ni 1.3µ MINI Ni (AREA 1) (AREA 3) (AREA 4) CONNECTOR ACCOMMODATION See View For standard winding only (AREA 1) (AREA 3) (AREA 4) ECHELLE 7/1 N L K J I DATE 2 Update drawing Latest modification - by: COURTOIS L. Date: ROUILLARD Ch CUSTOMER DRAWING 03/04/2019 SC--M--Dimensions in mm General linear Tolerances: -- NPRDS / PROJECT TRIM TRIO www.esterline-connection-technologies.com H G F E A1 C B Country FR 1 This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° BS-C-200178-002 FORMAT D MOD N FEMALE FORMED TWO PIECE CONTACT 4/1 CURRENT RATING : 13 A CONTACT RETENTION IN BODY : 65 N MIN. CONTACT RESISTANCE :
SC16ML1S31 价格&库存
很抱歉,暂时无法提供与“SC16ML1S31”相匹配的价格&库存,您可以联系我们找货
