09140153001
09140153001
    HARTING(浩亭)
    HAN15E-M-CMULTIPLIERBLOCK
09140153001 数据手册
Han-Yellock® Multiplier block Features Technical characteristics Suitable for: Specifications  - Hoods / housings sizes 10 B, 16 B, 24 B, 32 B, 48 B - Hoods / housings for Han-Eco®, sizes 6 B, 10 B, 16 B, 24 B Han-Snap®, - Hoods / housings for sizes 10 B, 16 B, 24 B - Han-Modular® Docking frame and Hinged frame size 10 B, 16 B, 24 B • U  p to 3 Han-Yellock® multipliers can be used in one multiplier block • B  y using the multipliers, the potential of one up to five contacts can be multiplied • Suitable only for use with Han® E male contacts DIN EN 60 664-1 DIN EN 61 984 Inserts Number of contacts Electrical data acc. to EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree Electrical data, pollution degree 2 Insulation resistance Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life - mating cycles 15 16 A 500 V 6 kV 3 16 A 500 V 6 kV 3 16 A 690 V 8 kV 2 ≥ 1010 Ω Polycarbonate -40 °C ... +125 °C V0 ≥ 500 Contacts Material Surface - hard-silver plated - hard-gold plated Contact resistance Crimp terminal - mm² - AWG Copper alloy 3 µm Ag 2 µm Au over 3 µm Ag Ni ≤ 1 mΩ 0.14 ... 4 mm² 26 ... 12 HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com Han® 2015-01-23 Data Sheet 0923 Han-Yellock® Multiplier block 500 V  16 A Number of contacts 1 – 15 Part number Identification Male insert (M) Female insert (F) Drawing Dimensions in mm Han-Yellock® Multiplier block M 09 14 015 3001 09 14 015 3101 F Wire gauge Identification mm² Part number male contact Drawing Dimensions in mm Crimp termination Power contacts silver plated Power contacts gold plated 0.14-0.37 0.5 0.75 1 1.5 2.5 3 4 09 33 000 6127 09 33 000 6121 09 33 000 6114 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6106 09 33 000 6107 0.14-0.37 0,5 0.75 1 1.5 2.5 4 09 33 000 6117 09 33 000 6122 09 33 000 6115 09 33 000 6118 09 33 000 6116 09 33 000 6123 09 33 000 6119 Identification Wire gauge no groove 0.14-0.37 mm² AWG 26-22 no groove 0.5 mm² AWG 20 0.75 mm² AWG 18 1 groove* 1 groove 1 mm² AWG 18 2 grooves 1.5 mm² AWG 16 3 grooves 2.5 mm² AWG 14 wide groove 3 mm² AWG 12 4 mm² AWG 12 no groove * on the rear crimp collar Stripping length 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm Han-Yellock® Multiplier Number of contacts 5 Identification Part number Drawing Han-Yellock® Multiplier Multiplier 1:1 Multiplier 2:3 Multiplier 3:2 11 05 105 2801 11 05 105 2802 11 05 105 2803 Multiplier 4:1 11 05 105 2804 Multiplier 5:0 11 05 105 2805 Multiplier 5:0 11 05 105 2815 Multiplier 2;3:0 11 05 105 2823 Dimensions in mm
09140153001 价格&库存
很抱歉,暂时无法提供与“09140153001”相匹配的价格&库存,您可以联系我们找货
  • 1+121.611021+15.74360
  • 10+103.3474910+13.37923
  • 25+96.8764325+12.54150
  • 50+92.2519150+11.94281
  • 100+87.84969100+11.37290
  • 250+82.35351250+10.66138
  • 500+78.42665500+10.15301
  • 1000+74.688141000+9.66903
库存:31
09140153001
    • 1+113.297961+14.66740
    • 10+77.4231810+10.02310
    • 100+65.90136100+8.53150
    • 250+61.97346250+8.02300
    • 500+61.36246500+7.94390
