09140062733
09140062733
    HARTING(浩亭)
    MODULEFEMALE6POSPUSHINLOCK
09140062733 数据手册
Han® E Quick Lock module Han-Quick Lock® 500  V 16  A Number of contacts 8 Part number Identification Male insert (M) Female insert (F) Drawing Dimensions in mm Quick Lock termination M 09 14 006 26 33 09 14 006 27 33 F Contact arrangement  view from termination side Assembly manual Remove cable jacket and strip the fine stranded wires Removal manual Do not twist the fine stranded wires! Please insert the screw driver1) at an angle of 45° into the opening and lever the black slide out Push fine stranded wires into the Han-Quick Lock® contact and push the blue slide with a screw driver1) until it comes to a stop 1) Screw driver: 0.4 x 2.5 mm Han® Data Sheet 0616 Han® E Quick Lock module Han-Quick Lock® Features • Innovative Han-Quick Lock® termination technology • Field assembly without special tools • Compatible to Han® E module with crimp terminal • Reduced wiring times Technical characteristics Specifications DIN EN 60 664-1 DIN EN 61 984   Inserts Number of contacts Electrical data acc. to EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree Insulation resistance Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life - mating cycles 6 16 A 500 V 6 kV 3 16 A 500 V 6 kV 3 ≥ 1010 Ω polycarbonate -40 °C ... +125 °C V0 ≥ 500   Contacts Material Surface - hard-silver plated - hart gold plated Contact resistance Quick Lock termination - mm² - AWG copper alloy 3 µm Ag 2 µm Au over 3 µm Ag Ni ≤ 1 mΩ 0.5 ... 2.5 mm² 20 ... 14 HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Fon: +49 577247-97100 | Fax: +49 577247-495 Internet: www.HARTING.com | E-Mail: Electric@HARTING.com 2012-03-27
09140062733 价格&库存
很抱歉,暂时无法提供与“09140062733”相匹配的价格&库存,您可以联系我们找货
  • 1+182.188871+23.47010
  • 2+175.522362+22.61130
  • 10+158.1543310+20.37390
  • 20+150.6106420+19.40210
  • 26+147.8914026+19.05180
  • 40+143.4178240+18.47550
  • 50+141.1371750+18.18170
  • 60+139.3828260+17.95570
  • 80+136.4881580+17.58280
  • 100+134.29522100+17.30030
库存:6
09140062733
  • 1+107.96025
库存:18
09140062733
  • 2+116.14553
  • 10+104.52889
库存:4
09140062733
  • 1+204.257551+26.31306
    库存:98
