09140009901
09140009901
    HARTING(浩亭)
09140009901 数据手册
Coding of inserts in hoods/housings Identification Part number Drawing Coding system with code pins Dimensions in mm for hoods/housings with one insert/one frame standard for hoods/housings with tho inserts/two frames Han-Modular® 09 30 000 "https://b2b.harting.com/ebusiness/en/ 99011) " 09 14 000 99011) "https://b2b.harting.com/ebusiness/en/ " Code pin + Normal mounting screw Coding system with guide pins/ bushes M - Male insert F - Female insert This system is used to guard against angled coupling and decoupling of the connector. The maximum permitted angle according to DIN EN 175 301-801 is ± 5° (longitudinally). standard Guide pin2) 09 33 000 99081) "https://b2b.harting.com/ebusiness/en/ " Guide bushing2) for hoods/housings with one insert/one frame 09 33 000 99091) "https://b2b.harting.com/ebusiness/en/ " Han-Modular® Guide pin for hoods/housings with tho inserts/two frames 09 14 000 99081) "https://b2b.harting.com/ebusiness/en/ " Guide bushing 09 14 000 99091) "https://b2b.harting.com/ebusiness/en/ " ● Guide pin ○ Bush + Normal mounting screw Coding pins Accessories for Han E®, Han® EE, Han® Q 5/0, Han® Q 8/0 Use of the coding pin prevents incorrect mating to other connectors of the same type. The male pin should be omitted from the opposing cavity in the male insert. 09 33 000 9954 "https://b2b.harting.com/ebusiness/en/ 95 . 08 for Han D®, Han DD® with loss of contact 09 33 000 9915 "https://b2b.harting.com/ebusiness/en/ 1) 2) Order 4 pieces for one connector for application "insert in hood/housing" M - Male insert F - Female insert " " Stock items in bold type
09140009901 价格&库存
很抱歉,暂时无法提供与“09140009901”相匹配的价格&库存,您可以联系我们找货
    • 10+15.31980
    • 20+14.98239
    • 30+14.65956
    库存:420
    09140009901
      • 50+16.12583
      • 100+15.72282
      • 200+15.48121
      库存:150
      09140009901
        库存:250
