Push Posts
SERIES 29
FEATURES
• Quick Connect/Disconnect
• Only 7/8" Above Board Height
• Standard, Insulated, or
Banana Plug Styles
• High Temperature Spring Style
• Color-Coded Caps with
Optional Additional Colors
DESCRIPTION
Press button and put lead in slot and release.
Spring pressure assures firm, positive contact.
DIMENSIONS
In Inches (and millimeters)
Standard Style
Insulated Style
.81
(20,57)
.76
(19,30)
#8-32
UNC-2A
THREADED
STUD FOR
11/64" (4,36)
MOUNTING
HOLE
.25
(6,35)
DIA.
.25
(6,35)
DIA.
.25
(6,35)
DIA.
.06 (1,52)
Banana Plug Style
.06 (1,52)
.06 (1,52)
1.44
(36,58)
1.39
(35,31)
SPECIFICATIONS
1.75
(44,45)
1.44
(36,58)
MOLDED
WASHERS
FIT 25/64" (9,92)
MOUNTING
HOLE
Same as 29-100 with Black Thermoset Plastic
Washers Part No. 29-104
Termination Hardware
Red/Black cap Part No. 29-100
No cap Part No. 29-110
No cap, high temp. Part No. 29-125
.89
(22,61)
Fits Standard Banana Socket
Part No. 29-101
ORDERING INFORMATION
Rating Criteria
Rating: At 120 Vdc, 20A continuously, with a
maximum temperature rise of 20°C.
Materials and Finishes
External Metal Parts: Nickel-plated brass
Spring: Tinned music wire
Button Caps: Polyethylene
Washers (29-104): Black thermoset plastic
High Temperature Spring: Stainless steel
OPTIONS
Green or White Caps
Gold plate finish: Available on all but Banana
Plug styles.
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
Description
Part Number
Standard, without cap
Standard, with red cap
Standard, with black cap
High temperature standard, without cap
Insulated, with black cap
Insulated, with red cap
Banana plug, with black cap
Banana plug, with red cap
29-110
29-100
29-100
29-125
29-104
29-104
29-101
29-101
RED
BLK
BLK
RED
BLK
RED
Available from your local Grayhill Distributor.
For prices and discounts, contact a local Sales
Office, an authorized local Distributor or Grayhill.
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Termination
4
很抱歉,暂时无法提供与“29-125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+82.011481+10.62336
