29-110
29-110
    GRAYHILLINC.
29-110 数据手册
Push Posts SERIES 29 FEATURES • Quick Connect/Disconnect • Only 7/8" Above Board Height • Standard, Insulated, or Banana Plug Styles • High Temperature Spring Style • Color-Coded Caps with Optional Additional Colors DESCRIPTION Press button and put lead in slot and release. Spring pressure assures firm, positive contact. DIMENSIONS In Inches (and millimeters) Standard Style Insulated Style .81 (20,57) .76 (19,30) #8-32 UNC-2A THREADED STUD FOR 11/64" (4,36) MOUNTING HOLE .25 (6,35) DIA. .25 (6,35) DIA. .25 (6,35) DIA. .06 (1,52) Banana Plug Style .06 (1,52) .06 (1,52) 1.44 (36,58) 1.39 (35,31) SPECIFICATIONS 1.75 (44,45) 1.44 (36,58) MOLDED WASHERS FIT 25/64" (9,92) MOUNTING HOLE Same as 29-100 with Black Thermoset Plastic Washers Part No. 29-104 Termination Hardware Red/Black cap Part No. 29-100 No cap Part No. 29-110 No cap, high temp. Part No. 29-125 .89 (22,61) Fits Standard Banana Socket Part No. 29-101 ORDERING INFORMATION Rating Criteria Rating: At 120 Vdc, 20A continuously, with a maximum temperature rise of 20°C. Materials and Finishes External Metal Parts: Nickel-plated brass Spring: Tinned music wire Button Caps: Polyethylene Washers (29-104): Black thermoset plastic High Temperature Spring: Stainless steel OPTIONS Green or White Caps Gold plate finish: Available on all but Banana Plug styles. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Description Part Number Standard, without cap Standard, with red cap Standard, with black cap High temperature standard, without cap Insulated, with black cap Insulated, with red cap Banana plug, with black cap Banana plug, with red cap 29-110 29-100 29-100 29-125 29-104 29-104 29-101 29-101 RED BLK BLK RED BLK RED Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com K-4
29-110 价格&库存
很抱歉,暂时无法提供与“29-110”相匹配的价格&库存,您可以联系我们找货
  • 1+74.276561+9.62142
