02-21
02-21
    GRAYHILLINC.
02-21 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Test Clips SERIES 02 FEATURES • Rapid, Easy Connections • Hex Nut for Adjusting Tension • Choices of Sizes and Styles Ultra-Miniature DIMENSIONS Miniature Standard Size In Inches (and millimeters) Ultra Miniature Miniature 02-41 and 02-42 02-20 Threaded Stud .125 (3,18) .125 (3,18) .406 (10,31) .218 (5,54) .406 (10,31) PANEL AREA EXCLUSIVE OF NUTS: FOR 1 CLIP 3/16" X 1/8" (4,76 X 3,17) FOR DOUBLE 1/4" X 1/8" (6,35 X 3,17) 02-24 Insulated .406 (10,31) All dimensions are reference. A Max. panel thickness .250 (6,35) Termination Hardware Standard Size Threadless #6-32 UNC-2A THREAD HEX NUTS .250 (6,35) ACROSS FLATS, .094 (2,39) THICK Panel thickness .062 (1,57) to .187 (4,75) All dimensions are reference. Standard Size 02-60 02-0 Threaded Stud .312 (7,92) .312 (7,92) 02-4 Insulated .550 (13.97) 02-1 Standard Banana Plug .550 (13.97) 1.250 (31,75) 1.250 (31,75) 1.144 (29,06) 1.125 (28,58) .312 (7,92) TAPPED FOR #8-32 UNC-2A THREADED SCREW TO ADJUST TENSION .312 (7,92) A HEX NUTS .344 (8,74) ACROSS FLATS, .125 (3,18) THICK B .937 (23,80) .375 (9,53) DIA. .500 (12,7) DIA. #8-32 UNC-2A THREAD SCREW NOT INCLUDED All dimensions are reference. .550 (13.97) A = .063 (1,60) B = .094 (2,39) .187 (4,75) .576 (14,63) .937 (23,80) B .250 (6,35) DIA. .375 (9,53) DIA. #6-32 UNC-2A THREAD HEX NUTS .250 (6,35) ACROSS FLATS, .094 (2,39) THICK .625 (15,88) .360 (9,14) .360 (9,14) #2-56 UNC-2A THREAD HEX NUTS .187 (4,75) ACROSS FLATS .062 (1,57) THICK .406 (10,31) A = .062 (1,57) B = .093 (2,36) .719 (18,26) .719 (18,26) .375 (9,53) 02-21 Standard Banana Plug #8-32 UNC-2A THREAD HEX NUTS .344 (8,74) ACROSS FLATS, .125 (3,18) THICK Max. panel thickness .250 (6,35) All dimensions are reference. STANDARD OPTIONS SPECIFICATIONS ORDERING INFORMATION Standard Size Threaded Stud Clip can be made of Stainless Steel or Inconel X material. Not available through Distributors. Materials and Finishes Order using part numbers shown in dimensions. Studs: Nickel-plated steel except for 02-41 and 02-42 which are nickel-plated brass Rivets and Nuts: Nickel-plated brass Spring Clips: Nickel-plated brass except for 02-41 and 02-42 which are nickel-plated beryllium copper Insulators: Thermoset plastic Termination Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 5 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
02-21 价格&库存
很抱歉,暂时无法提供与“02-21”相匹配的价格&库存,您可以联系我们找货
