MOC3052S-TA1
MOC3052S-TA1
    LITE-ON(光宝)
    SMD-6P
    单向光耦 Viso=5000Vrms VF(typ)=1.15V IF=50mA Vo=600V SMD-6P
MOC3052S-TA1 数据手册
Photocoupler Product Data Sheet MOC3052 SERIES Spec No.: DS70-2001-025 Effective Date: 04/28/2010 Revision: D LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only FEATURES * Isolation voltage between input and output Viso : 5,000Vrms * 6pin DIP photocoupler, triac driver output * High repetitive peak off-state voltage VDRM : Min. 600V * High critical rate of rise of off-state voltage ( dv/dt : MIN. 1000V / s ) January 2010 * Dual-in-line package : MOC3052 * Wide lead spacing package : MOC3052M * Surface mounting package : MOC3052S * Tape and reel packaging : MOC3052S-TA1 * Safety approval UL / CSA / FIMKO / VDE* approved *Required “V” ordering option APPLICATIONS * Incandescent Lamp Dimmers * Interfacing Microprocessors to 115 and 240 Vac Peripherals * Lamp Ballasts * Motor Controls * Solid State Relays * Static AC Power Switch * Solenoid / Valve Controls * Temperature Controls Part No. : MOC3052 SERIES BNS-OD-C131/A4 Page : 1 of 8 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only OUTLINE DIMENSIONS Dual-in-line package : Wide lead spacing package: *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Z : Taiwan, Y : Thailand, X : China-TJ, W : China-CZ) *4. Model No.: MOC3052 Part No. : MOC3052 SERIES BNS-OD-C131/A4 Page : 2 of 8 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only OUTLINE DIMENSIONS Surface mounting package : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Z : Taiwan, Y : Thailand, X : China-TJ, W : China-CZ) *4. Model No.: MOC3052 Part No. : MOC3052 SERIES BNS-OD-C131/A4 Page : 3 of 8 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only TAPING DIMENSIONS Tape and reel package : MOC3052S-TA1 Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Part No. : MOC3052 SERIES BNS-OD-C131/A4 Symbol W P0 F P2 P1 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) Page : 4 of 8 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only ABSOLUTE MAXIMUM RATING ( Ta = 25C ) PARAMETER SYMBOL RATING UNIT Forward Current IF 50 mA Reverse Voltage VR 6 V Power Dissipation PD 100 mW Off-State Output Terminal Voltage VDRM 600 V Peak Repetitive Surge Current ( PW=100s, 120pps ) ITSM 1 A PC 300 mW Ptot 330 mW Viso 5,000 Vrms Ambient Operating Temperature Range TA -40 ~ +100 C Storage Temperature Range Tstg -55 ~ +150 C TL 260 C INPUT OUTPUT Collector Power Dissipation Total Power Dissipation *1 Isolation Voltage *2 Soldering Temperature *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector, emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Part No. : MOC3052 SERIES BNS-OD-C131/A4 Page : 5 of 8 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only ELECTRICAL - OPTICAL CHARACTERISTICS ( Ta = 25C ) PARAMETER SYMBOL MIN. TYP. MAX. UNIT CONDITIONS Forward Voltage VF — 1.2 1.4 V IF=20mA Reverse Current IR — 0.05 10 A VR=6V *1 Peak Blocking Current, Either Direction IDRM — — 100 nA VDRM = 600V Peak On-State Voltage, Either Direction VTM — — 3.0 V ITM=100 mA Peak dv/dt 1000 — — V/s Led Trigger Current, Current Required to Latch Output, Either Direction IFT — — 10 mA Holding Current, Either Direction IH — 400 — A INPUT OUTPUT *2 Critical rate of Rise of Off-State Voltage *3 COUPLED Main Terminal Voltage = 3V *1 Test voltage must be applied within dv/dt rating. *2 This is static dv/dt. Commutating dv/dt is a function of the load-driving thyristor(s) only. *3 All devices are guaranteed to trigger at an IF value less than or equal to max IFT. Therefore, recommended operating IF lies between max 10mA for MOC3052 and absolute max IF (50mA) Part No. : MOC3052 SERIES BNS-OD-C131/A4 Page : 6 of 8 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only CHARACTERISTICS CURVES F ig .1 F o rw a rd C u rre n t vs. F ig .2 O n -sta te C u rre n t vs. A m b ie n t A m b ie n t T e m p e ra tu re T e m p e ra tu re 50 ITM , o n-state c urrent (A) Fo rw ard c urrent I F (m A) 60 40 30 20 10 0 -40 -20 0 20 40 60 0.10 0.05 0 -40 -20 80 100 120 o 20 40 60 80 100 120 Am b ient tem p erature Ta ( C ) F ig .3 M in im u m T rig g e r C u rre n t F ig .4 F o rw a rd C u rre n t vs. F o rw a rd vs. A m b ie n t T e m p e ra tu re V o lta g e 10 100 VP = 6V R L = 100 8 Fo rw ard c urrent I F (m A) M inim um trig g er c urrent I FT (m A) 0 o Am b ient tem p erature Ta ( C ) 6 4 2 0 o o 60 C 40 C 20 C 80 C 100 C o o o 10 1 20 40 60 80 100 0.4 o 0.8 1.2 1.6 F ig .5 O n -sta te V o lta g e vs. A m b ie n t F ig .6 H o ld in g C u rre n t vs. T e m p e ra tu re A m b ie n t T e m p e ra tu re 3.0 1 2.6 VP = 6V Fo rw ard c urrent I H (m A) O n-state vo ltag e V TM (V) I TM = 100m A 2.2 1.8 1.4 1.0 0.1 0.01 20 40 60 80 100 o Am b ient tem p erature Ta ( C ) Part No. : MOC3052 SERIES BNS-OD-C131/A4 2.0 Fo rw ard vo ltag e V F (V) Am b ient tem p erature ( C ) 20 40 60 80 100 o Am b ient Tem p erature Ta ( C ) Page : 7 of 8 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of Lite-on Only CHARACTERISTICS CURVES RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm Part No. : MOC3052 SERIES BNS-OD-C131/A4 Page : 8 of 8 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Lite-On: MOC3052M MOC3052S-TA1 MOC3052S MOC3052
MOC3052S-TA1 价格&库存
很抱歉,暂时无法提供与“MOC3052S-TA1”相匹配的价格&库存,您可以联系我们找货
MOC3052S-TA1
  • 161+4.70722161+0.60645
  • 500+4.26828500+0.54990
  • 1000+2.818281000+0.36309
  • 2000+2.441752000+0.31458
  • 3000+2.236373000+0.28812
库存:2933
MOC3052S-TA1
  • 5+1.34260
库存:15
MOC3052S-TA1
  • 1+1.03180
  • 50+0.79310
  • 1000+0.73040
库存:28279
