BS2-IC
BS2-IC
    PARALLAXINC.
    PDIP
    BS2-IC
BS2-IC 数据手册
BASIC Stamp Module Comparison Chart ® Name of module BASIC Stamp 1 BASIC Stamp 2 BASIC Stamp 2e BASIC Stamp 2sx BASIC Stamp 2p24 BASIC Stamp 2p40 BASIC Stamp 2pe BASIC Stamp 2px Stock Code BS1-IC BS2-IC BS2E-IC BS2SX-IC BS2P24 BS2P40 BS2PE BS2PX24 Processor Speed 4 MHz 20 MHz 20 MHz 50 MHz 20 MHz Turbo 20 MHz Turbo 8 MHz Turbo 32 MHz Turbo Execution Speed (instructions/ Sec.) ~2,000 ~4,000 ~4,000 ~10,000 ~12,000 ~12,000 ~6,000 ~19,000 RAM Size 16 Bytes (2 I/O, 14 Variable) 32 Bytes (6 I/O, 26 Variable) 32 Bytes (6 I/O, 26 Variable) 32 Bytes (6 I/O, 26 Variable) 38 Bytes (12 I/O, 26 Variable) 38 Bytes (12 I/O, 26 Variable) 38 Bytes (12 I/O, 26 Variable) 38 Bytes (12 I/O, 26 Variable) Scratchpad RAM N/A N/A 64 Bytes 64 Bytes 128 Bytes 128 Bytes 128 Bytes 128 Bytes EEPROM (Program) Size 256 Bytes, ~80 instructions 2K Bytes, ~500 instructions 8 x 2K Bytes, ~4,000 instructions 8 x 2K Bytes, ~4,000 instructions 8 x 2K Bytes, ~4,000 instructions 8 x 2K Bytes, ~4,000 instructions 16 x 2K Bytes (16K for source), ~4,000 instructions 8 x 2K Bytes (16K for source), ~4,000 instructions Voltage Requirements 5-15 VDC 5-15 VDC 5-12 VDC 5-12 VDC 5-12 VDC 5-12 VDC 5-12 VDC 5-12 VDC Current Draw @ 5 V (Run/Sleep) 1 mA/25 µA 3 mA/50 µA 25 mA/200 µA 60 mA/500 µA 40 mA/350 µA 40 mA/350 µA 15 mA/150 µA 55 mA/450 µA # of I/O Pins 8 16 + 2 Serial 16 + 2 Serial 16 + 2 Serial 16 + 2 Serial 32 + 2 Serial 16 + 2 Serial 16 + 2 Serial Source/Sink Current per I/O 20 mA/25 µA 20 mA/25 mA 30 mA/30 mA 30 mA/30 mA 30 mA/30 mA 30 mA/30 mA 30 mA/30 mA 30 mA/30 mA Source/Sink Current per Unit 40 mA/50 µA 40 mA/50 mA per 8 I/O pins 60 mA/60 mA per 8 I/O pins 60 mA/60 mA per 8 I/O pins 60 mA/60 mA per 8 I/O pins 60 mA/60 mA per 8 I/O pins 60 mA/60 mA per 8 I/O pins 60 mA/60 mA per 8 I/O pins PBASIC Commands 32 42 45 45 61 61 61 63 BASIC Stamp 1 Module - Affordable yet capable; perfect for smaller projects or tight spaces. BASIC Stamp 2sx Module - Supports the BS2 command set with more data and program space at more than twice the execution speed. BASIC Stamp 2 Module – Ideal for beginners yet quite powerful, with a vast resource base and sample code. The BS2 is the core of our Stamps in Class program. BASIC Stamp 2p24/40 Modules - In addition to more speed and data space, special commands support I/O polling, character LCDs, and I2C and 1-Wire protocols. The BS2P40 has these features plus 16 additional I/O pins. BASIC Stamp 2e Module - Perfect for those who have experience with the BASIC Stamp 2 and would like more data and program space. BASIC Stamp 2pe Module - BS2p command set paired with lower power consumption and more memory for battery-powered data logging applications. BASIC Stamp 2px Module - Our fastest BASIC Stamp microcontroller supports the BS2p command set as well as special I/O configuration features.
BS2-IC 价格&库存
很抱歉,暂时无法提供与“BS2-IC”相匹配的价格&库存,您可以联系我们找货
